Old 04-06-2010, 06:35 PM   #1
genkidama20
Member#: 73635
04 WRX
WRB Wingless
Default A/C Compressor Squeaks and Stops
Ok, it's warming up in NC so I started using my A/C today. Well, turns out I'm having some issues.
The Problem
With air conditioning turned on, the vehicle chirps and loses power for a split second. This concerned me, so today after work, I took pictures and video to see if anyone could help me figure out what's going on.
At first I thought it was because my belts were lose. Since I had just replaced my worn belts with new Gates A/C and Alternator belts.
This video shows the belt with lots of vibration. Is that too loose? Should the belt not vibrate that much?
But then, as I was watching the belt, I noticed something. The part with the red arrow stops spinning, as if it gets stuck.
Here's a video of that part stopping (I think it's the A/C Compressor):
Is this bad? Is it something I can fix myself?
UPDATE
I'm a doofus. The compressor stops normally. LOL.
But, I did find out what was wrong. My A/C slider bolt bracket was broken. Thus, nothing was left to keep tension on the belt but the pulley. Need to buy a new bracket.
Part #24 in this picture... anyone know where to get it?
genkidama20 is offline   Reply With Quote
Old 04-06-2010, 10:33 PM   #2
joec wrx
Member#: 112359
14 Challenger RT
I've ordered OEM parts from here a few times and never had any problems.
http://www.trademotion.com/partlocat...?siteid=214857
joec wrx is offline   Reply With Quote
Old 04-07-2010, 12:51 AM   #3
Dans Rex
Member#: 227583
at my local dealer, when i replaced my accessory belts, i had to get the new #22 which included 23 and 24.
oh and I have used subarugenuineparts (dot) com, and use their OEM catalog
side note: it was crazy, i had the original from factory #22 which had worn and caused the belt to jump and grind into my timing cover so when replacing both belts, i had to buy the updated #22.
Dans Rex is offline   Reply With Quote
Old 04-07-2010, 01:40 AM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
A lot of people seem to be having similar issue - common fix is replacing #22-24.
Old 04-07-2010, 09:25 AM   #5
genkidama20
Member#: 73635
04 WRX
WRB Wingless
I just bought #24 for now.
#22 was spinning perfectly fine. I probably should have bought it too. But, I will have to take a look at it again.
Old 04-11-2011, 09:48 PM   #6
2002Dubx
Member#: 177337
1 Dirty Old
Bugeye and an Xterra
Sorry to bump an old thread, but I took a quick video of the sound. (Sorry for the crappy quality) All belts are newly installed by a local Subaru dealer as of a year ago. The whine started about a month ago and it seems to be getting slightly worse. A/C compressor, compressor bearings, idler pulley? Any conclusions???
- My a/c blows cold and hard.
- WD-40 has been tried
- A/C is blowing strong
- Like a supercharger sound with any acceleration
2002Dubx is offline   Reply With Quote
Old 04-15-2011, 08:19 PM   #7
2002Dubx
Member#: 177337
1 Dirty Old
Mine was the idler pulley. I took the idler pulley off and the belt so I will be without A/C for a couple of days, but it's better than the A/C compressor being the problem and costing way more.
Old 04-25-2011, 10:38 PM   #8
C_Wood
Member#: 102234
14 WRX
Yep, sounds like the idler pulley. Mine did the same thing.
C_Wood is offline   Reply With Quote
Ac Compressor squeaks at cold engine temps p8baller07 Service & Maintenance 1 07-25-2007 08:53 PM
A/C Compressor squeak ?? !! Number231 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-13-2007 01:05 PM
A/C compressor Squeak??? jaysant1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-23-2006 11:37 AM
Calling the Mechanically Inclined: A/C Compressor Squeak. WRXedUSA Off-Topic 6 11-29-2004 09:27 PM
a/c compressor squeaks? TKRbeast Newbies & FAQs 4 03-21-2004 10:54 PM
