![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1376 |
Member#: 235744
VIC
Vehicle:07 2.5i Sedan Ltd Newport Blue |
can anyone pshop my wheels for the pics above with white, bronze, black or metallic silver?
any suggestions for the color? thanks!
#1377 |
Member#: 95337
Tri-State
Vehicle:2008 Spec.B |
There's a photoshop thread for requests like that. They'd be happy to help you there.
http://forums.nasioc.com/forums/showthread.php?t=165301 |
#1378 |
Member#: 214121
TXIC
Vehicle:2005 562WHP twns 35r custom black |
![]() sealed with ppg ncp271 two coats of gold basecoat toner then two coats of pegan gold candy concentrate and two coats of clear |
#1379 |
Member#: 4574
NESIC
Vehicle:2011 Legacy 2.5i LMT Silver |
Got any full car views with the wheels?
#1380 |
Member#: 238956
NWIC
Vehicle:6480 bug platinum |
Before
![]() ![]() After ![]() ![]() End ![]() ![]() |
#1381 |
Member#: 101188
Vehicle:MY07 WRX Wagon Black |
#1382 |
Member#: 238734
South East
Vehicle:2010 WRX Hatch Spark Silver |
Has anyone painted a spark silver 08+ wrx hatch's rims black? because I wanna do mine but not sure how it'd look yet. thanks.
#1383 |
Member#: 218964
MWSOC
Vehicle:2009 WRX Rally Blue |
Here are mine, these are from an 09. Same rim, they just started out as a dark grey. Painted flat black.
![]() Last edited by MNGman; 04-22-2010 at 10:12 AM. Reason: picture |
#1384 |
Member#: 218964
MWSOC
#1385 |
Member#: 238358
NESIC
Vehicle:2004 Impreza 2.5 TS San Remo Red |
I painted my first wheel today,
Cleaned and dried the wheel, then sanded with 400 grit followed by 1500 grit. Used alcohol and microfiber cloth then rewashed it and dried again. Finally I hit it up with a duplicolor prep wipe and then got down to painting. I used rustoleum primer, paint and wheel clear coat. It's almost too sparkly looking up close but from a few feet back I don't mind the look at all, and for under 35 bucks for everything I bought for the project , I'm happy with the results. I just painted one as a test wheel so hopefully I can bang the rest out over the next few days. The pictures aren't shot under an ideal lighting situation but I'll get some better ones up once I finish the other 3 wheels. Before : ![]() Primer : ![]() ![]() Painted and Cleared : ![]() sorry about the glare..but I did another coat of clear on my center caps. ![]() |
#1386 |
Member#: 70730
NWIC
Vehicle:2006 WRX ltd AW 02 WRX, 00RS - sold :( |
what paint is that? i'm thinking of going back to silver.
#1387 |
Member#: 238358
NESIC
it's rustoleum silver high performance wheel coating..i used all rustoleum products for this project
I finished up the other three wheels today: ![]() ![]() ![]() ![]() ![]() Last edited by 2004imprezaTS; 04-25-2010 at 05:15 PM. |
#1388 |
Member#: 219560
E. Canada
Vehicle:2007 Impreza SE Newport Blue Pearl |
Stock rims from my 2007 2.5i "SE"
Sanded down, primed 3 coats, painted 3 coats, clear 2 coats. installed, and pointed at! Hot pink (Outdoor paint). ![]() ![]() Some random spray got all over the tires, so I just used a little bit of carb cleaner on a rag to take it off. Followed by tire cleaning foam afterwards! |
#1389 |
Member#: 235744
VIC
^ haha, nice! i have the same car and thinking of painting mine as well. :P
hey what exhaust do you have there? how is it? (sound wise?) what's your setup? tnx. |
#1390 |
Member#: 241929
Make sure you have a full day to dedicate to this process and don't underestimate the work!! Clean...sand with 1000grit....prime....four coats of color of preference with 2000 grit sanding in between...two coats of clear coat, let all dry overnight and your good to go!!
#1391 |
Member#: 241929
Purple!!
#1392 |
Member#: 238358
NESIC
My paint job feels rather rough; probably because I didn't sand in between coats. I applied another can of clearcoat on top of the first because I thought they looked like could use another layer. I like the way they came out, even though they are still a bit rough to the touch.
![]() and I photo shop hacked them on just to get an idea of how they'll look ![]() |
#1393 |
Member#: 201924
MAIC
Vehicle:07 L.L. Beaner |
17x7.5 Rota Downshift
Used to be an ugly faded bronze turned greenish with a polished flaking gold lip... So I painted them Sanded with 320 Primmed with Glasurit 285-500 HS Primer Grey -3 coats Sanded with 400 Self-etching Primer on bare metal spots Plum Crazy Purple Metallic (paint code C7) -5 coats BASF RM DC5600 CTR Production Clear -1 coat The clear is a little rough and when I had the new tires mounted the guy was retarded and chipped up all four wheels Any way I'm going to touch them up and then re-clear them.![]() ![]() ![]() A little dirty in this last picture Pictures do not do this color justice! |
#1394 |
Member#: 243821
TXIC
Vehicle:1997 Infiniti J30 Pearl White |
Just did these right now so figured I would post the pics....
MB Weapon Wheels 18' Primer with filler, 2 Coats of gold on each rim, 3 coats of clear coat.... ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#1395 |
Member#: 164797
Tri-State
Vehicle:'10 STi EWG'd Loud & Fast |
#1396 |
Member#: 225790
Vehicle:2005 LGT |
I'm debating on doing my stock rims on my LGT but..... I'm not too fond on the whole spray paitig the rims thing. Guess if I do end up doing it I will have to put like 5 coats of clear coat on it do to lovely NY roads.
#1397 |
Member#: 88501
BAIC
Vehicle:2006 WRX Wagon CGM |
Anyone dare to paint 2 wheels one color on one side, and 2 wheels a different color on the other?
... because seriously no one can ever see both sides at the same time. I may just try this. |
#1398 |
Member#: 209231
MAIC
Vehicle:2008 WRX, 95 leggy White to the both of them |
^^ been done sorta, but a step further, a guy had two volks one color, and the other two on the other side a different color,
Baller????? |
#1399 |
Member#: 88501
BAIC
#1400 |
Member#: 230559
SCIC
Vehicle:2005 Subaru WRX PSM |
| Thread Tools | |
| Display Modes | |
| re-painting already painted stock wheels | subiedriver4444 | Interior & Exterior Modification | 14 | 12-04-2012 08:13 PM |
| WANTED: Pics of painted stock wheels on PSM Bugeye.. | vipernj | Member's Car Gallery | 1 | 10-10-2005 07:40 AM |
| WTT painted stock wheels for non painted stockers | ErikAnderson | North West Impreza Club Forum -- NWIC | 19 | 05-04-2005 07:47 AM |
| Any pictures of painted stock wheels (WRX)?? | eightballrj | Member's Car Gallery | 31 | 11-15-2004 12:08 PM |
| Painted stock wheels | WRBlueMeanie | Interior & Exterior Modification | 8 | 04-23-2003 02:35 PM |
