Old 04-07-2010, 07:41 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default My DIY endlink thread
Was planning to buy a real set but after doing my taxes, it's a no go. so here's my attempt at endlinks.
I'm planning on doing a front and rear set, but started with the rear cus they're harder.
Here's what I did so far:
More to come as I make progress
Bad Noodle is offline   Reply With Quote
Old 04-09-2010, 06:39 AM   #2
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
i would strip that down with a wire wheel. it will weld like crap because it's coated
indytruckboy is offline   Reply With Quote
Old 04-09-2010, 03:48 PM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
yea, you might want to grind off the galvanizing off that. toxic fumes
also, being that you easly bent those pieces i am willing to bet that they will bend farly easy once installed. also what bushings are you planing on using?
i love DIY stuff as i am always willing to try it. so keep up the good work.
PARANOID56 is online now   Reply With Quote
Old 04-09-2010, 09:52 PM   #4
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
So here's today's progress:
Looks like poop for now, but the dimensions are good. Next will be grinding everything down, cleaning it up, painting, then making the bushings.
I know they're not the best welds but I do suck at welding and these were done with a $180 welder and a harbor freight welding mask that just sucks balls. Can't see anything that's going on while welding and tend to move off the path I should be following
Old 04-10-2010, 08:13 AM   #5
iluvdrt
Member#: 46248
82 Brat
Tan
I had thought about using some heim joints and making some adjustable ones for the front. Not sure how I would do the rear yet.
iluvdrt is offline   Reply With Quote
Old 04-10-2010, 09:06 AM   #6
DZnutz
Member#: 91837
soo much work for something thats so cheap to buy?
DZnutz is offline   Reply With Quote
Old 04-10-2010, 01:14 PM   #7
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
getting ready for bushing molds:
clean up step 1
Old 04-10-2010, 08:27 PM   #8
DJSuperSoul
Member#: 120004
2xx8 STI
grey
utilizing Heim joints for the fronts yields a clean result. pretty straightforward and painless via mcmaster carr.
DJSuperSoul is offline   Reply With Quote
Old 04-11-2010, 12:45 PM   #9
syndromeofthedown
Member#: 190627
Ummm... please don't do that. That's very poor quality steel. You'd be doing yourself a huge disservice by continuing on. Just my 2 cents. Be better off with stock crap.
syndromeofthedown is offline   Reply With Quote
Old 04-14-2010, 03:09 PM   #10
freetors
Member#: 195982
white
I'm pretty sure you could use straight end links on the rear if you take your lateral links and flip them to the opposite side.
freetors is offline   Reply With Quote
Old 04-14-2010, 05:58 PM   #11
WhiteHawkSTi
Member#: 208416
If you are looking for a cheap alternative. instead of welding I have heard of guys using these from McMaster:
http://www.mcmaster.com/#rod-ends/=6nujra
WhiteHawkSTi is offline   Reply With Quote
Old 04-14-2010, 08:27 PM   #12
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
You need to be extreemly careful buying rod ends from a place like that. You don't really know what brand they are, and it is easy to order something that sucks.
For automotive applications like this you really need a joint with a good self lubricating Teflon lined race, stainless steel or hard chromed ball, and a chromoly housing. They are not cheap. Aurora makes good joints. The line that would be best here is the AM-T, AB-T, AW-T, and AG-T series. FK Bearings also makes great joints that are similar in quality to Aurora but a bit cheaper. The JMXT is the one to look at.
FourOnTheFloor65 is offline   Reply With Quote
Old 04-15-2010, 09:22 AM   #13
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
before you install them, can you test them under load to see the deflection difference between yours and the stock ones? use a long bar in the hole and some weights for repeatable testing.
WC LATHE WERKS is offline   Reply With Quote
Old 04-15-2010, 10:01 AM   #14
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ great idea. Any idea what kind of forces they see?
Everything's going well with the project, I just can't find a 5/16" ID tube locally that I need for the front arm bushing.
Old 04-15-2010, 10:26 PM   #15
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
DIY's are awesome but come on man, endlinks are cheap. Those are going to be worse than stock, and probably cost more in materials and definitely time.
Good luck
Wintershredder is offline   Reply With Quote
Old 04-15-2010, 11:26 PM   #16
DrSaabaru
Member#: 183225
2005 Saab 9-2x Aero
There's a whiteline tech paper floating around that estimates the maximum load on endlinks to be somewhere in the 2.7kN - 3.5kN range, which is equivalent to 275kg - 357kg.
So, if you happen to have an 800lb weight around the shop, hang that off your endlink and see if it bends!
DrSaabaru is offline   Reply With Quote
Old 04-16-2010, 11:40 AM   #17
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
The end links look cool, but they are not ganna work. Try again man, dont sweat it. I have as many failed fab projects as ones that turned out good.
Try improving the endlink mounts, very easy to do. Just weld a bar or pipe between the two ends. I used some old bike frame.
RS_to_WRX_swap is offline   Reply With Quote
Old 04-16-2010, 01:10 PM   #18
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ wow those are good.
I think you guys are right about the endlinks not working. I'm having trouble finding the correct size piece of pipe to use in the middle of the bushings. but at this point, it would probably be easier to get some whitline ones and call it a day
Old 04-16-2010, 01:15 PM   #19
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
I think you guys are right about the endlinks not working. I'm having trouble finding the correct size piece of pipe to use in the middle of the bushings. but at this point, it would probably be easier to get some MSI or Kartboy ones and call it a day
Fixed
boost junkie is offline   Reply With Quote
Old 04-16-2010, 01:47 PM   #20
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I was opting for whiteline because they make ones that look like:
Those look like they would fit a cobb sway bar the best on a wrx wagon
Old 04-16-2010, 02:44 PM   #21
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
They look like they fit exactly the same as the others, only they aren't made nearly as well.
Old 04-16-2010, 02:50 PM   #22
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I'm on spt springs and with a cobb sway bar, the endlinks look like they're bent 30 degrees off verticle when the car is down. My stock endlink busing wore out because of that. Those whitelines looks like they can take it though
Old 04-16-2010, 02:54 PM   #23
wrxracer519
Member#: 149890
09 Forester
Green
Run a spacer between the bar and endlink so they are not angled.
wrxracer519 is offline   Reply With Quote
Old 04-16-2010, 02:58 PM   #24
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Well that coulda saved me a **** load of effort and a thread
Old 04-16-2010, 02:59 PM   #25
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
This. Kartboy sells spacers for this purpose.
WRC DIY camera pod, and pic of my DIY rollbar. nottofast Member's Car Gallery 44 03-07-2012 05:36 AM
It's out! My DIY swap thread... lancelucas North West Impreza Club Forum -- NWIC 71 11-28-2010 02:00 AM
DIY Endlink Mod WRX03 Brakes, Steering & Suspension 5 01-14-2007 01:23 PM
another endlink thread 03 rear endlinks prometheum Brakes, Steering & Suspension 5 03-20-2006 11:41 AM
The DIY audio thread. mattjk Off-Topic 29 06-21-2005 07:45 PM
