Old 04-19-2010, 04:44 PM   #1
blakeM.U.R.T
Member#: 208575
2004 wrx
Default hybrid install
so i pulled the motor out of my car yesterday due to a broken connecting rod. Ive decided to take the route of a hybrid motor. i purchased an refurbished 07 sti block (by Subaru mechanic) and i plan to start the swapping later today. this is the fist time i have ever pulled a motor out of a car. i have read the threads time and time again, i have the OEM gasket set, and a torque wrench. dumb question but what is FSM and any advice at this point will help. thanks
blakeM.U.R.T is offline   Reply With Quote
Old 04-19-2010, 06:49 PM   #2
corzy666
Member#: 177840
2000 swapped RS
White 330whp
FSM is Factory Service Manual.
And do you intend to use AVCS? Are you using cometic gaskets to help out the compression ratio?
If you don't know what your doing it could be a costly mistake... search for some threads here in the built motor section.
corzy666 is offline   Reply With Quote
Old 04-19-2010, 09:14 PM   #3
blakeM.U.R.T
Member#: 208575
2004 wrx
Old 04-20-2010, 11:22 PM   #4
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Fred Beans is cheaper gasket-set You will have to buy STI head gaskets as well.
slowmike is offline   Reply With Quote
Old 04-21-2010, 01:02 AM   #5
lcjarrett
Member#: 133814
2008 AW STI
How much did you buy the engine for?
Go to flatironstuning.com or call them talk to Jon Cooley he has some knowledge about this swap.
lcjarrett is offline   Reply With Quote
Wrx spring install instructions? subwrx23 Newbies & FAQs 12 12-26-2012 09:11 AM
FS/PA 2004 EJ257/55 longblock Hybrid bcooper22 Engine/Power/Exhaust 25 08-12-2010 05:15 PM
FS : PA/DE: Hybrid APS/Precision FMIC kit, TXS Stealthback + Catpipe + Racepipe Merp Engine/Power/Exhaust 15 07-27-2010 02:25 PM
Hybrid Install issue WRXbrother Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-07-2008 12:17 AM
NEED HELP! hybrid install issue WRXbrother Newbies & FAQs 12 02-06-2008 09:59 PM
