#1 |
Member#: 4498
Vehicle:WRX H6-3.0 Turbo www.surgelinetuning.com |
There has been some discussion over the PPB about the 08 transmission in
the 08 STI. Here is a look at the tranny parts from each model year. ![]() First and Second Driven are new parts, as is 6th Drive. However the other side of 1st, 2nd, and 6th are UNCHANGED. So the ratio's must be the same as 07. ![]() And here is a look at the tranny numbers for all of the US Spec WRXs and STIs. Cheers, Jeff
#2 |
Member#: 1549
BAIC
Vehicle:04 Impreza WRX Wingless White |
This is great info!
Would you be able to create a similar list cross-referencing tranny part numbers for WRXs? I'm looking to do a rebuild with new synchros and curious to see what has changed over the years. Thanks! |
#3 |
Member#: 112433
E. Canada
Vehicle:06 WRX.stage2 OBP |
#4 |
Member#: 1549
BAIC
Bumping to prevent this thread from slipping through the cracks.
#5 |
Member#: 103232
Vehicle:MY05 GDA, MY04 FXTI 2.5ltr,PPG,Front LSD,4.44 |
Thank You!
#6 |
Top Scoob 006
Member#: 14424
South East
Vehicle:BugI w/ 07 STi Swap www.TriStateTuners.com |
great info...
i had heard that although the gearing is the same, the gears, synchros, and oiling system had been revamped for the better. does anyone have any information on this or experience comparing the 08 to earlier models? thanks... edit: comparing info from www.cars101.com which says the 2008 STi gearing is: 2008 STi 6 speed manual 1st 3.636 2nd 2.235 3rd 1.521 4th, 1.137 5th 0.097 6th 0.756 Front final gear ratio: 3.9 Rear final gear ratio: 3.545 and according to the Transmission Gear Ratio thread here on NASIOC which states: 2004-2006 manual transmission gear ratios: 1st - 3.636 2nd - 2.375 3rd - 1.761 4th - 1.346 5th - 0.971 6th - 0.756 reverse - 3.545 final drive ratio - 3.90 2007+ manual transmission gear ratios: 1st: 3.636 2nd: 2.375 3rd: 1.521 4th:1.137 5th:0.971 6th: 0.756 reverse - 3.545 final drive ratio - 3.90 there is some confusion there. i'm thinking that the 2nd gear ratio for the 2007 STi is listed wrong here on NASIOC and thats where the confusion is? Last edited by Wrinkleboi; 02-19-2008 at 07:02 PM. |
#7 |
Member#: 19820
Vehicle:2007 NINJA ZX-10R |
The 2008 STi trans does not have a oil pump assembly. It now uses oil guides.
Another few notes: They is no longer a dipstick on the 08 trans and the 08 no longer uses the speedometer sensor. I still need to check if I can install a 07-earlier Speedometer driven gear shaft so that the 08 trans can be swapped into an older car and still have the speedo work. 07 and 08 gearing: 1)3.636 2)2.235 3)1.521 4)1.137 5)0.971 6)0.756 Last edited by Nitro Don; 02-19-2008 at 09:17 PM. |
#8 |
Member#: 108051
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
http://forums.nasioc.com/forums/show....php?t=1518667
Here something I'm looking into doing as far as upgrading the stock gears goes Last edited by spoolinsti05; 05-18-2008 at 05:26 PM. |
#9 | |
Member#: 180925
#10 |
Member#: 193835
Vehicle:10 Forester XT silver |
does anyone know what mods would need to be done to swap a 5sp for a sti's 6 sp tranny for a 08wrx?
#11 |
Member#: 103202
International
Vehicle:09 sti09&00gc8 black&grey |
1st 3.636 2nd 2.235 3rd 1.521 4th, 1.137 5th 0.097 6th 0.756 Front final gear ratio: 3.9 Rear final gear ratio: 3.545 are you sure about the rear final drive ratio ? if yes we can use 2008 r180 directly with wrx 5mt. |
#12 | |
Member#: 114530
Vehicle:2005 LGT 6MT wagon |
So what's better oil pump or oil guides? Eliminating oil pump sounds like a downgrade. I found some old material when 6 speed was introduced and the oil pump was mentioned as a big deal to improve oiling over 5 speed trannies. |
#13 |
Member#: 81409
Vehicle:2004 Impreza WRX STi Platinum Silver Metallic |
In my opinion, an oil pump in the tranny is over engineering. As the gears spin oil is already lubricating the gears. The 08 STi does not have an oil pump and neither does it have a dipstick. You check oil level by literally opening a bolt on the passanger side of the tranny and filling it up to the specified level.
#14 | |
Member#: 114530
Here is what I found about the oil pump: "It has an internal oil pump for pressure lubrication. The change to pressure lubrication assures that local temperatures in the gear box are kept under control, a valid criticism of the 5-speed design under racing conditions. The 3.9 final drive unit has a separate oil galley, isolating possible gear chips and further managing internal thermal loads." http://www.spdusa.com/6-speed_conversion.htm Btw, the dipstick is very convenient. Not only for checking the oil level but also for filling the tranny. Getting under the car to check level is not quite convenient.... |
#15 |
Member#: 103202
International
in edm cars user manual, the gear ratio seen as
3.636 2.235 1.590 1.137 0.891 0.707 3.90 3.54 maybe there is a diffrence between edm and usdm as usual. |
#16 |
Member#: 114530
EDM STI ratios are like USDM LGT SpecB ratios.
#17 |
Member#: 49979
Vehicle:11 dgm wrx hatch 08 black TA STI |
#18 | |
Member#: 114530
Rallispec told me that they can convert 07+ STI tranny to SpecB ratios by using 5-6th gears from JDM STI Forester tranny. |
#19 | |
Member#: 49979
Frank |
#20 |
Member#: 49979
Thanks to a poster over on IWSTI, the following site gave me the part numbers for the EDM taller 5th and 6th gears:
http://opposedforces.com/parts/ 6th drive: 32363AA100 5th drive: 32341AA350 5/6th driven: 32364AA070 at least I believe these are them- I chose "europe, left hand drive" in the menu structure. There was an alternate listed for the 6th drive gear as well, but no alternates for 5th and the driven gearset. Here's the 6th alternate: 32337AA030. Note that it did not call it a supercede. Frank |
#21 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 WRX Wagon |
There's two versions for the 07 STI trans. Which part # is the one with the pump (the other I presume is splash lubricated)?
#22 |
Member#: 206376
Vehicle:2006 GMC 2500HD Black |
Since the 08 does not have a dip stick anymore there is a female 6 point (allen) bolt on the top. I'm assuming this is the fill location?
#23 |
Member#: 114530
#24 |
Member#: 166324
Vehicle:02 V8 Spec C 03 V9 Limited 2013 Legacy |
Do 08 STi axles fit/work in other transmissions? If so, which years?
#25 |
Member#: 196882
Vehicle:08 WRX |
Nope. 08+ STi axle bars are longer than 07 and earlier STi bars. The outer CV ends, splined end, is also longer than previous years, so they wont work with older hubs/unit-bearings. Havent looked at the inner CV stub, but Im sure its the same as 07 and earlier.
| Thread Tools | |
| Display Modes | |
| FS (WA) 2008 STi GT Spec Front Strut Tower Bar | CO WRX | Suspension/Brakes/Handling | 3 | 04-26-2009 06:05 PM |
| Help with EDM 2008 STI tranny part numbers? or gear swap? | Frank A | International Forum | 0 | 07-04-2008 12:31 AM |
| 2008 WRX, 2007-2008 LGT and SPEC-B, 2007-2008 FXT and 2008 STi .COBB ACCESS PORT! | RallySport Direct | Engine/Power/Exhaust | 2 | 12-12-2007 01:34 PM |
| Preliminary non-JDM 2008 STI specs | Jon [in CT] | News & Rumors | 557 | 11-27-2007 02:09 PM |
