Old 03-31-2010, 01:54 AM   #51
Halfaed
Member#: 241658
2010 WRX
Lightning Red
Badass wheels!!!!!!!
Can't wait to see this car finished!
Halfaed is offline   Reply With Quote
Old 04-02-2010, 02:23 PM   #52
Member#: 234245
Default Hydra Ems
Hey guys the car is pretty much done, we have a couple more small things to be done, and then it will be off to the dyno to get her tuned. Once we have that done we will be hitting the track to shake her down, and dial her in.
Speaking of tuning, we just got our Hydra EMS from our friends over @ Element Tuning. We chose Hydra for a few simple reasons. The Hydra EMS should allow us to fine tune the engine so we don’t run into any tuning issues and will allow us to dial in the motor at each event we participate in. Function for function, the Hydra EMS is the best bang for the buck as it is almost 4 times cheaper than most EMS’s out there and offer the same tuning capabilities. The new software is much more user-friendly than the previous versions and is much faster to tune. Element Tuning provides pre-programmed base maps for most Subaru applications making this a TRUE plug-and-play EMS. The Hydra EMS is also the only EMS that offers full DBW support for 2004-2010 Subaru’s and fully closed loop AVCS control for both intake and exhaust cam timing.
Big thanks to Phil over @ Element Tuning for getting us the HYDRA in record time!
Here are the pics!
PR@THMotorsports is offline   Reply With Quote
Old 04-09-2010, 08:41 PM   #53
Member#: 234245
Default WP Pro Big Brake Kit
Fresh from the factory, our WP Pro big brake kit arrived just in time. We will be running one of the freshest braking systems out there, for any car, hands down! Our WP Pro system consists of the following.
Front Axle:
336mm x 30 x 46mm rotors with L8 Calipers
Rear Axle:
334mm x 30 x46mm rotors with S6 calipers.
Thats right boys and girls, 8 pistons up front, with a lightweight forged caliper, and a 6 piston setup in the rear! This was a custom set, specifically built for our time attack car. Some of the modifications include:
-Lightened calipers, heat treatment, carbon nitride treament and cross drilling for ventilation
-Balanced rotors up the the equivalent of 224mph
-Lightened rotor hat assembly, with the front rotors weighing in UNDER 13lbs.
-Air grooves in the pad backing plates for increased cooling
-Custom color
Above all, these brakes are built for superior performance on the track. With the backing of race proven technology, WP Pro will aide us in being the leader on the track.
Old 04-09-2010, 09:52 PM   #54
Halfaed
Member#: 241658
2010 WRX
Lightning Red
You said update /pics? Where is the car pics?
Old 04-10-2010, 01:10 PM   #55
CIS
Member#: 243691
^yeah that
CIS is offline   Reply With Quote
Old 04-10-2010, 09:03 PM   #56
gr8
Member#: 163375
Unfortunately, there are not many updates have been made to the car mainly because we are still missing an engine. I'm sad to say that we won't be make the New Jersey event because of this. If it finally goes our way, we should be tracking and testing the car in 2 weeks.
The good news is we have all the other major components minus wing( should be in next week).
Don't forget to check out http://www.thmracing.com for updates as well. We have pics of the wheels and brakes on and getting ready to make some custom over fenders. The splitter and diffuser are being custom made out of carbon fiber and curing as we speak at Project X!
Cheers
gr8 is offline   Reply With Quote
Old 04-12-2010, 03:08 PM   #57
Member#: 234245
Default WP Pro x Forgeline x Toyo
Hey Guys,
We just installed our WP Pro Big Brake kit, and the Toyo R888 wrapped Forgeline EV3R's. Now keep in mind when you see these pics, that our Stance coilovers have yet to be installed, and our over fenders are in the process of being made. We will post updated pics once we have all that.
Check out the pics and let us know what you guys think!
Old 04-14-2010, 07:13 PM   #58
Darcros
Member#: 196496
2006 STI
should of done your cage to a scca,nasa or fia spec. that looks like poop and has no chassis strength to it
Darcros is offline   Reply With Quote
Old 04-14-2010, 07:15 PM   #59
Darcros
Member#: 196496
2006 STI
and you not even on the A pillar . seems really unsafe.
Old 04-17-2010, 01:04 PM   #60
billy boi
Member#: 19714
.... front cover of
MODIFIED MAG Sept. 2006
I think the VARIS wide body kit would definately be a nice touch ! What do you think ?
billy boi is offline   Reply With Quote
Old 04-18-2010, 04:10 PM   #61
Member#: 234245
That looks so hot! We tried to connect with the guys @ Varis USA, we got no response. The Version Select guys have been very supportive of this project, I think everyone is going to fall in love with this car when they see it finished!
Old 04-18-2010, 04:36 PM   #62
Member#: 234245
Default Engine Build Pics
Hey guys I know you have all been waiting a while to see these. We finally got some pics of our engine build, while the process has been slightly delayed, we wanted to make sure this engine assembled perfectly. Our setup will consist of the following parts:
Block: EJ257
Brian Crower Billet Steel Crank 83mm stroke
Brian Crower Pro Seires Steel Billet Rods
Darton Sleeves
Ductile Iron Plasma Top Rings
Nickel Carbon Steel Alloy Wrist Pins
JE Custom Pistons
Cometic Headgasket
Brian Crower Race Cams
…Beastly, we know
These are the awesome JE Pistons thats were custom built for our Brian Crower 2.7 L Stroker Kit. Big thanks to Sean Crawford @ JE. JE has been a huge supporter of our Time Attack program. Be sure to check out their site and show them some support - www.jepistons.com
Old 04-25-2010, 11:32 AM   #63
Mr Peter
Member#: 244918
i just realized you guys are located in glenview! is your shop online only?
Mr Peter is offline   Reply With Quote
Old 04-26-2010, 10:39 PM   #64
Darcros
Member#: 196496
2006 STI
all those great parts and engine internals with a weak sause chassis
Old 04-27-2010, 09:57 AM   #65
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
No we are not , swing by
TH motorsports is offline   Reply With Quote
Old 04-29-2010, 08:15 AM   #66
Mr Peter
Member#: 244918
i might pick up some parts for my forester
Old 04-29-2010, 10:21 AM   #67
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Sounds good. Our engine came back. This week time to break in!
Old 04-29-2010, 01:49 PM   #68
Badler
Member#: 133597
That's what I was thinking. Looks really unsafe. Are those eBay brakes too?
Badler is online now   Reply With Quote
Old 04-30-2010, 09:33 AM   #69
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Brakes by WP. They manufacture for AP Racing.
Cage will be getting re-done to SCCA spec as that's where the car will be racing. You can blame RTA for their cage rules on that one.
Old 04-30-2010, 10:16 AM   #70
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
April 15th marked the arrival of our long awaited custom wing from Kognition Design. Mike @ Kognition produced our wing with the precision of a surgeon, and from the pics, you’ll see the dedication that went into making this wing for yourself. The quality of this piece far surpasses anything on the market, and the chassis mounted design ensures absolute structural integrity. The addition of this wing to our STi is two fold, increasing both safety and performance. We cant wait to feel the difference this masterpiece makes on our car.
Shout out to Mike @ Kognition Designs
Old 04-30-2010, 10:17 AM   #71
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Current progress. Yes it looks very funny and has no rear brakes. Also can be called the McDonalds look:
Old 04-30-2010, 01:39 PM   #72
Darcros
Member#: 196496
2006 STI
you guys are pretty close to Detroit. I have built SCCA,NASA cages in the past if you guys need any help let me know. We have in house a full hydraulic mandrel bender and some really tight radius dies.We are actually doing a SCCA STI Chassis right now chromoly tube normalized/full Seam weld.I can email you some pics.
Old 04-30-2010, 05:19 PM   #73
Joevr4
Member#: 173425
1999 3000gt VR4
Pearl White {1 of 56}
Looks great.
Joevr4 is offline   Reply With Quote
Old 05-02-2010, 03:15 AM   #74
JDM_cb7_tx
Member#: 243821
1997 Infiniti J30
Pearl White
Damn!!!! This car is making alot of progress. Definatly gonna keep chiming in...
JDM_cb7_tx is offline   Reply With Quote
Old 05-03-2010, 02:38 PM   #75
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Email us some pics to [email protected]. I actually would love to work with you after our first RTA event, as this car will see SCCA races and not that much RTA. We are going to have the cage re-done regardless, so it would be great to work with ya to go by the rules.
Edward
FS : (LA) 2006 Subaru WRX STi Aspen White PRICE DROP $19000 obo More Pics page 3 Dustin77 Private Vehicle 'For Sale' Classifieds 68 06-16-2010 02:43 PM
Zero/sports 06 STi - Time Attack Car - For Sale! EAT Motorsports Vehicle Sales 10 04-23-2010 11:32 PM
Any updates on COBB's full carbon body Time Attack car? WRblueX_Guy Motorsports 31 07-07-2009 04:05 PM
SoCal: FS: 2004 WRX STi gauge cluster, in great condition, with shift light & buzzer jcu1276 Private 'For Sale' Classifieds 27 05-05-2006 05:54 PM
