Old 04-29-2010, 10:41 PM   #1
Molotov
Member#: 211488
2014 MB C300
1990 Mazda Miata
Default 5x100 vs 5x114.3
Wonder if 5x114.3 has any advantages over 5x100 worth doing the conversation.
I'll be doing 06-07 sti tranny swap and wonder if I should also convert to 5x114.3.
I can get rims/struts I want in 5x100, cusco has lsd rear diffs for WRX, you can get bbk in 5x100 as well.
My car is currently dd but it will be a track car in a long shot.
Molotov is offline   Reply With Quote
Old 04-29-2010, 10:45 PM   #2
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
5x114.3 is a stronger hub design as far as a dd as long as you dont have an outrageous set up 5x100 should be fine however you may find that there are more wheel options for 5x114.3
jdmboy is offline   Reply With Quote
Old 04-29-2010, 10:54 PM   #3
sc00by4life
Member#: 97135
for a daily, like jdmboy said, the only real advantage is a wider selection of wheel sizing options....and even for your use, thats probably not that much of a "plus" to the conversion.
keep in mind that if you do the 5x114.3 conversion, you'll need the entire rear end from the same year sti as well.
sc00by4life is online now   Reply With Quote
Old 04-29-2010, 11:00 PM   #4
Molotov
Member#: 211488
2014 MB C300
1990 Mazda Miata
^^ yeah, I know, and its not cheap, thats why I'm wondering if its worth it
Well, basically the main purpose of this thread is to determine if I should buy 5x100 TE37 via Kami group buy going on now. I really LOVE TE37 and once I get them (in 5x100 or 5x114.3) I won't be looking any further. So I don't really care about "more wheel options".
And what is that stronger hub design is all about? I'll have to replace bearings e.g. every 50k instead of 25k or does it have more important impact?
Old 04-29-2010, 11:04 PM   #5
davidsti1
Member#: 210923
2001 RSTI Twinscroll
FullRace BW8374 ripper
if you dont care about more wheel options then you got the answer
my 0.02 cents.
davidsti1 is offline   Reply With Quote
Old 04-29-2010, 11:06 PM   #6
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
You're looking at spending ~$1,000 to do the conversion.
Byzantium is offline   Reply With Quote
Old 04-29-2010, 11:07 PM   #7
jdmboy
Member#: 240161
87 bmw e30
ok here we go
bolt patterns are just circles 5x100=5 bolt spaced around a 100mm circle
as opposed to 5x114.3 which = 5 bolts spaced around a 114.3mm circle
this extra 14.3mm cuts down on the leverage that the wheel has on the hub. get it?
Old 04-29-2010, 11:09 PM   #8
Molotov
Member#: 211488
2014 MB C300
1990 Mazda Miata
Byzantium, much more than $1000
Old 04-29-2010, 11:11 PM   #9
Molotov
Member#: 211488
2014 MB C300
1990 Mazda Miata
jdmboy, thx for the comments, but I do know the theory, what I care about is it's impact on practice.
Old 04-29-2010, 11:14 PM   #10
jdmboy
Member#: 240161
87 bmw e30
its not going to have much impact at all what wheel and tire specs do you plan on running?
Old 04-29-2010, 11:20 PM   #11
Molotov
Member#: 211488
2014 MB C300
1990 Mazda Miata
currently considering 17x9 +22 & 255-65/45/17
yeah, i suppose this offset may be considered as outrageous
Old 04-29-2010, 11:23 PM   #12
Byzantium
Member#: 207826
85k 2002 WRX
So is the width of the wheel and the size of that side wall. You're gonna have a lot of fun trying to get that to work on a wagon.
Old 04-29-2010, 11:24 PM   #13
Molotov
Member#: 211488
2014 MB C300
1990 Mazda Miata
yeah, I know man)))
Old 04-29-2010, 11:26 PM   #14
jdmboy
Member#: 240161
87 bmw e30
yea thats getting to the point that it would probably be a good idea to do the swap if your going to track the car.
Old 04-29-2010, 11:27 PM   #15
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Keep in mind if you plan on using the rear STi Brembo setup you will have to swap to either JDM STi rear hubs or 04 STi rear hubs.
This really isn't to bad, there are plenty of guys running setups like this for a good while now without any wheel bearing issues. You can also look into the 6gun setup that allows you to use the 05+ wheel bearings.
domestic_abuser is offline   Reply With Quote
Old 04-29-2010, 11:28 PM   #16
jdmboy
Member#: 240161
87 bmw e30
+1 the off set is what worries me though i would try and go with a 35
Old 04-30-2010, 12:24 AM   #17
sc00by4life
Member#: 97135
you'd HAVE to run a 35 sidewall. I have a lower offset, and am loww. I could MAYBE squeeze a 245/40 with my monster of a pull..on a sedan.
On a wagon, its going to be pretty much impossible. You need less tire with that low of an offset.
Old 04-30-2010, 11:05 AM   #18
jdmboy
Member#: 240161
87 bmw e30
^^^agreed i have 17x8 48mm off set with 245/45/17s on my wagon an had to do a good amount of work to the rear fenders, and im on h&r springs and tokico d-specs.
Old 04-30-2010, 11:18 AM   #19
Molotov
Member#: 211488
2014 MB C300
1990 Mazda Miata
Hmmm... I was looking to do shagon style rolling 18x10 +30
http://forums.nasioc.com/forums/show...&postcount=122
18x9.5 +26 255/35/18
http://forums.nasioc.com/forums/show...&postcount=228
Old 04-30-2010, 11:47 AM   #20
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
wasn't there a "knock back" problem with the 04 brembo set up also?
crampfan is offline   Reply With Quote
Old 04-30-2010, 11:50 AM   #21
Byzantium
Member#: 207826
85k 2002 WRX
And what type of driving where you planning on doing to justify such and obnoxious/extravagant wheel/tire setup? How much power are you making?
Those aren't wagon fenders btw.
Old 04-30-2010, 03:19 PM   #22
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
Originally Posted by jdmboy View Post
ok here we go
I'm not sure if what you said is what you meant. The bolt circle will have no effect on the hub in and of itself. Think if the wheel had no bolts and was glued on with some super duper glue. The forces to the hub and bearings would not change.
What does change is the lateral forces near the center of the wheel itself. The closer to the center of the wheel the bolts are, the more lever arm the tire cornering forces can exert on the wheel between it's outer edge and the bolts. Everything within the bolt circle has essentially zero force. So the farther out the wheel is bolted to the hub, the less force is exerted to "bend" the wheel.
The short answer is that the STi hub assembly is stronger. If you're tracking the car, the added strength will help. If the cost is exorbanant for a street car and you're buying aftermarket wheels anyways......it's probably not at all worth it.
Old 04-30-2010, 10:24 PM   #23
sc00by4life
Member#: 97135
Shagon's fenders are far from stock. Custom rear quarters + sedan front fenders.
Old 04-30-2010, 11:43 PM   #24
jdmboy
Member#: 240161
87 bmw e30
yes this is what i ment basically my understanding is that the farther the bolts are away from the center of the wheel the less amount of leverage on the bolts and also the hub. sorry for the bad wording of my original post
Old 04-30-2010, 11:47 PM   #25
vinxH
Member#: 159796
2006 WRX
the only real benefit is having a wider wheel selection.
vinxH is offline   Reply With Quote
Hub adapter 5x100 to 5x114.3 chucktoo Tire & Wheel 16 11-30-2009 03:51 PM
5x100 vs 5x114.3 Kaldar142 Tire & Wheel 15 04-22-2008 12:51 PM
Convert 5x100 to 5x114.3 P.C.D. chucktoo Brakes, Steering & Suspension 2 11-13-2005 08:48 PM
5x100 to 5x114.3 conversion Fitz Brakes, Steering & Suspension 2 06-25-2005 11:09 AM
Can we convert 5x100 to 5x114.3? awdlifestyles Subaru Conversions 1 04-01-2005 07:02 PM
