Welcome to the North American Subaru Impreza Owners Club Wednesday August 5, 2015
Old 04-30-2010, 11:48 PM   #26
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
Originally Posted by vinxH View Post
the only real benefit is having a wider wheel selection.
true if your dding the car but the 5x114.3 hubs are a much stronger design and is worth the trouble if you plan on tracking it
jdmboy is offline   Reply With Quote
Old 05-01-2010, 01:17 AM   #27
Molotov
Member#: 211488
2014 MB C300
1990 Mazda Miata
thx guys, looks like i will keep 5x100 for a while unless ill find a smoking deal for full swap
now I'm thinking about rim size and offset, i'm looking for 250whp for now, and 300-350 after engine swap & turbo upgrade, guess there is no practical need for 245+ tires
Molotov is offline   Reply With Quote
Old 05-01-2010, 01:32 AM   #28
Ioku
Member#: 164864
95 Impreza coupe
The main difference in the 5x114.3 sti hubs is that the front bearing is much stronger than the 5x100, and once the bearing dose wear out its much easyer to replace because you done have to press it out, its just 4 bolts and you replace the whole hub and bearing as an assembly. But the rear bearing is still the same just the spline count on the hub thats pressed into it it different to work with the bigger axles used with the R180 and thats why you need the whole rear end off an STi to swap to 5X114.3.
Ioku is offline   Reply With Quote
Old 05-01-2010, 02:02 PM   #29
sc00by4life
Member#: 97135
Originally Posted by domestic_abuser View Post
Keep in mind if you plan on using the rear STi Brembo setup you will have to swap to either JDM STi rear hubs or 04 STi rear hubs.
04 sti is not 5x114. Thats why I said hell need the entire rear end out of the same year sti.
Old 05-05-2010, 09:08 PM   #30
vinxH
Member#: 159796
2006 WRX
its not really worth the trouble until your current ones fail due to tracking.
vinxH is offline   Reply With Quote
Old 05-05-2010, 09:25 PM   #31
jdmboy
Member#: 240161
87 bmw e30
true unless of course your hub catastrophically fails as you hit the apex of a turn at 90mph.
Hub adapter 5x100 to 5x114.3 chucktoo Tire & Wheel 16 11-30-2009 03:51 PM
5x100 vs 5x114.3 Kaldar142 Tire & Wheel 15 04-22-2008 12:51 PM
Convert 5x100 to 5x114.3 P.C.D. chucktoo Brakes, Steering & Suspension 2 11-13-2005 08:48 PM
5x100 to 5x114.3 conversion Fitz Brakes, Steering & Suspension 2 06-25-2005 11:09 AM
Can we convert 5x100 to 5x114.3? awdlifestyles Subaru Conversions 1 04-01-2005 07:02 PM
