Old 04-22-2010, 07:34 AM   #1
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
Default speed sensor, need help asap
hey whats going on. so im having a big issue with my speed sensor. my swap is a 02 wrx into a 96 legacy. im running the legacy tranny so its a legacy speed sensor. its only 2 wires so i had to tap into it to run back to the ecu. in the past couple days over 45mph my speed sensor pretty much shuts off. when the speed sensor isn't working the ecu thinks im not moving. so im pretty sure it puts it in fail-safe mode or whatever you call it.
is my speed sensor on its way out or something? why only after exactly 45mph?
any help, thoughts, ideas, anything would be much appreciated
07xtreme is offline   Reply With Quote
Old 04-22-2010, 01:23 PM   #2
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
back from lunch bump
Old 04-22-2010, 02:18 PM   #3
johnny p
Member#: 141232
02 v7sti wagon
signal green
ecu gets the vss signal from the cluster.
johnny p is offline   Reply With Quote
Old 04-23-2010, 08:03 AM   #4
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
haha, yea i know. i have that hooked up, but for some reason my speedo is dieing at 45mph every time. im getting a speed sensor from a j-yard tomorrow so we'll see if that changes anything
Old 04-28-2010, 07:23 AM   #5
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
so back to my speed sensor issue. i went to the junk yard last night, got a speed sensor outta a 97 legacy wagon. plopped it into my car got on the high way. 45 - check, 50 - check, 55 - check......60....crap. 60mph my speedo dies and falls to zero. so i added 15mph but it still isn't working right. did i get another crappy speed sensor? or is my wiring messed up?
Old 04-28-2010, 10:20 AM   #6
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
You are tapping into the wrong wire. You need to leave the two wires that run from the cluster to the VSS alone. There is one other wire that runs from the cluster to the ECU and this is the wire that should be spliced in. Typically this is a Green/Black wire, it needs to be a straight run from the cluster to the ECU to pin A1 (Green/Yellow). This circuit also will provide a signal to the CC unit which I'm sure you've already removed.
Zephyr is offline   Reply With Quote
Old 05-08-2010, 12:49 AM   #7
pearlSubie21
Member#: 185575
2007 wrx 351whp368tq
pearl white
i have a 2007 Subaru wrx and i blew the 5 speed last may with 370 wtq it was only a matter of time over the last 11 monts I have managed to get Exedy stage 1 clutch,Exedy Lightweight flywheel, 2006 Sti 6 speed Transmission, Sti driveshaft, Sti r-180 rear diff, Custom Chromolly axles from the driveshaft shop and know all that i need is throughout bearing and trani bolts and shifter linkage. to make a long story short I have financially exhausted my bank account and am looking for the full 2006 sti shifter linkage assembly because the transmission I bought didn't come with it because It came out of a 2006 wrecked sti. I called my local Subaru dealership and they want over 500 for the shifter linkage all the bushings nuts and washers etc...and i am not trying to pay that kind of money
pearlSubie21 is offline   Reply With Quote
04 STI Knock Sensor Need info ASAP, supposed to race 2moro! frsh13 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-05-2008 10:31 AM
!!help help ! i need help ASAP yuboyus Mid West Subaru Owners Club Forum -- MWSOC 3 10-17-2006 03:16 PM
Map sensor Need advice asap b690467 Engine Management & Tuning 1 10-13-2005 02:14 PM
NEED HELP ASAP!!! With 02 sensors. impreza4show Normally Aspirated Powertrain 2 09-19-2005 10:01 PM
need help asap. i need a really good subaru dealership to work on my car. need info! bubba03wrx Southern California Impreza Club Forum -- SCIC 12 02-25-2004 03:31 AM
