Old 02-21-2010, 10:08 PM   #401
Daishi00
Member#: 78952
2005 WRX
He's been doing this the entire thread. Compares track setups as suitable for street use. It's quite hilarious.
Daishi00 is offline   Reply With Quote
Old 03-09-2010, 03:19 PM   #402
BMWidmer
Member#: 205427
2000 RSTI w/ hta68
Army Green
Originally Posted by williaty View Post
That's actually really dangerous. If the suspension goes to full droop in a situation like that, there's no way to be sure you'll actually seat the spring properly as it re-compresses. Baaaad news.
I know all about this! But luckily it happened on the way to the track and not at the track.
BMWidmer is offline   Reply With Quote
Old 03-10-2010, 08:54 AM   #403
MSI
Member#: 95419
I think everyone needs to take what they are seeing with a grain of salt as well. You cannot compare travel limits on an EVO front vs REAR or a SUBARU vs a GT3.
They are not the same layout, motion ratios, or even setup from the design board.
A 430 challenge ... seriously, how can you compare the travel on a car that was built and designed from the drawing board to do one thing : GO FAST AROUND THE TRACK to an OEM evo or subaru?
-mark
MSI is offline   Reply With Quote
Old 03-10-2010, 10:02 AM   #404
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Not reading the thread at all, how do stiff swaybars affect the first pictures?
edit: looks like none since both fronts are off the ground
wcbjr is offline   Reply With Quote
Old 03-10-2010, 11:35 AM   #405
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It's been covered, beaten to death, and covered again.
Don't be a lazy noob. Read the thread before you post.
Old 03-10-2010, 12:08 PM   #406
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I did go back and look. Noob.
Old 03-10-2010, 12:15 PM   #407
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Heheh, Ty is starting to sound like Uncle Scotty.
Arnie is offline   Reply With Quote
Old 03-10-2010, 01:00 PM   #408
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Starting? Dude, I've been old and cranky since the days of the 300 baud acoustic coupler!
Old 03-10-2010, 01:26 PM   #409
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Too funny!
Old 05-08-2010, 01:35 AM   #410
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That's a GD STi with RCE T1 with the 500/500lbf/in springs. The track is Streets of Willow Springs. Note the amount of travel used. The damper is cycling through its full range of travel repeatedly.
Old 05-08-2010, 01:43 AM   #411
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I should also mention that this was his first outing on the Tarmacs at Willow. Compared to his previous coilovers, he dropped 3 seconds off his lap time with no other changes.
His previous coilovers? Megan Racing.
Old 05-08-2010, 02:07 PM   #412
littlewhitewagon
Member#: 103068
11 STI sedan
I hope I can see 3 seconds of improvement from my new kw v3s compared to my jic flt-a2 setup. Since I have kept the same tires, wheels, brakes and alignment settings, it will be interesting to see at buttonwillow. I can say that ride comfort and stability is better so far. The difference in braking on bumpy surfaces is amazing. The spring rates of the linear springs is unchanged, 8kg/6kg.
littlewhitewagon is offline   Reply With Quote
Old 05-08-2010, 02:16 PM   #413
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
So, basically, the only change is damper. I for one am VERY interested in seeing the changes in time. Please post them up when you get a chance.
Old 05-09-2010, 01:00 PM   #414
littlewhitewagon
Member#: 103068
11 STI sedan
The actual springs are different as well. The jic had their springs on them and the kw has swift in the rear and kw stock ones up front. I got the STi fitment since I liked the front being an 8kg+ helper spring.
The track temps look to be similar to last events so I will definitely post the data. The event is in June, I'm still doing shakedown right now with ride height adjustment. The jic were much lower and the car looks funny to me now.
Old 05-09-2010, 10:28 PM   #415
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Using dspecs and ground controls i should have the ability to dial sufficient enough drooop to warrant helpers wouldnt u think?. i think this setup would be stiff street but still managable. im thinking of using 8" springs all the way around, 400f/350r 99 impreza/gdsubframes control arms etc.. im also using lowering camber plates upfront with a roll center kit
Dubstar112 is offline   Reply With Quote
Old 05-13-2010, 03:22 AM   #416
MRF582
Member#: 48219
. Always drive
the race line .
Originally Posted by Mind View Post
How useful is droop travel that is not acted on by the force of the main spring?
And finally on the 8th page, the most pertinent question (rhetoric ) is asked.
Have a vehicle that can generate enough lateral grip to transfer its entire weight to the outside tires and droop travel does not freaking matter! Also, it really is amazing how a thread on suspension went on for so long with no talk of weight transfer.
Also, discussing how one suspension setup is better than another without full knowledge of the track surface is just... One set of compromises for a particular track might not work for another. To distill it down, one must juggle ultimate steady-state grip over flat surfaces with that over bump surfaces.
So we should change the thread title to "cheap coilvers are good for smooth tracks".
MRF582 is offline   Reply With Quote
Old 05-13-2010, 03:33 AM   #417
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
First of all, take a look at the video in comment 410. Car on smooth track. Car using more travel than cheap crap coilovers have. End of that line of discussion.
As far as Mind's question that you quoted, that's largely down to the kind of diffs the car is using. As long as the inside wheels are touching the ground, the car has not transferred 100% of the load to the outside wheels. Depending on what kind of diffs you're running, this can be the difference between the diff acting like it's open and it continuing to act like a LS diff. Additionally, so long as the as the inside wheels is touching the ground, it's contributing some to the lateral grip of the car. It may not be huge, but we're chasing after fractions here anyway.
Old 05-13-2010, 07:07 PM   #418
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
I know, but some people just argue and say that stiffer springs=les required travel. I dont know whats best for the track, but I beleive I am staying with a strut on the street for a reason.
However, no matter how lightly sprung it may be, an inside wheel which has been unloaded 99.9999 percent has got to be better than one who is 100% in my line of thought. Does anyone have thoughts there?
Old 05-13-2010, 07:47 PM   #419
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That car on the smooth track in post 410 had 500lbf/in springs. How much stiffer are people talking about? You're already in non-street-legal tire territory there.
Old 05-13-2010, 07:49 PM   #420
STi-MAN
Member#: 70252
05 STI
blue
Your argument here is sorta flawed here and im gonna throw it up as the driver getting more experience then the dampers for the 3 seconds..
in the video hes averaging around the 1:40-1:44 range at sow cw... most stock sti's will run a 1:35 range at this track. so you can see that if we're using your example a lightly sprung stock shock is better then a coilover on the track.
If this was a car running 1:25 and shed 3 seconds.. different story. Altho i do love my kw's.
STi-MAN is offline   Reply With Quote
Old 05-13-2010, 07:51 PM   #421
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I'm not sure it's an STi. I'm fairly sure he's got a WRX but I'll have to ask. Being down considerably on HP would raise his overall times.
Old 05-14-2010, 09:51 PM   #422
Vaughn Performance
Member#: 170489
If that's Saul_Good's (not sure of his real name) car in the SOW video it's actually an 05 LGT. Thus not comparable to stock STi lap time. The switch from Megans to proper coilovers at that track could definitely net you that sort of time. Anyone that ever exited the bowl there flat out and crested the small hill that comes after it just before dropping into the next set of turns can tell you how nice it is to have some droop travel there.
Subtracting the mechanical grip advantage of proper working coilovers from the equation for a second lets not forget how important it is just to have a suspension that gives you confidence to find more speed. It's hard to go flat out in a car that feels skittish and nervous everywhere.
A really good driver can be pretty damn quick in anything, but even quicker in something that's working well.
-Anthony
Vaughn Performance is offline   Reply With Quote
GC Kit and droop jeisen Brakes, Steering & Suspension 7 02-15-2010 09:18 AM
back to stock sale coilovers and other parts cheap mrguppy MAIC Private Classifieds 14 10-13-2008 03:46 PM
Springing options for coilovers - attacking stroke and droop travel Scooby921 Brakes, Steering & Suspension 7 05-10-2007 12:41 PM
FS: Brand New Coilovers and Shocks Cheap! wildchild Private 'For Sale' Classifieds 2 08-01-2004 08:46 PM
Cheap coilover kits on eBay B-Kerr Brakes, Steering & Suspension 11 05-31-2003 01:40 AM
