#1 |
Member#: 8399
Vehicle:GC8 JDM STI V swap cardinal red |
I think it's time to replace the oxygen sensor for my JDM Sti V conversion done by Rallispec. I replaced the MAF sensor a couple times and it fixed the intermittent rhythmic idle and cutting out when boost started to climb but now it appeared again where it hunts up and down at idle and then when it warms up it goes away. No other symptoms.
I did a search just now on the forums and came up with part Bosch A24-A71 028 92010 that I found in here http://forums.nasioc.com/forums/show...nsor+jdm+sti+V Any one have any ideas of where I can order this sensor I did a google search and not too much came up specific on buying a part. How is the part number laid out ... is the whole number an actual part or the 92010 is just a serial number ? Please any compatible parts or leads to this part would be great so I can get one on order and installed. Best Regards, Jason
#2 |
Member#: 130623
Vehicle:1998 Legacy GT Silver |
If your sensor is 3-wire, then you can use the o2 sensor from the 98RS.
If your sensor is 4-wire, use the one for the 2002 WRX. |
| Thread Tools | |
| Display Modes | |
| FS -- (SoCal) Front Oxygen Sensor for STi | singlefin | Engine/Power/Exhaust | 1 | 04-19-2010 03:33 AM |
| WTB: Front o2 oxygen sensor for 2004 sti | kevinh211 | Private 'Wanted' Classifieds | 2 | 11-18-2009 10:12 PM |
| Alternator for a jdm sti v5 motor in a 98 rs? | 2-7offsuit | Subaru Conversions | 13 | 12-17-2005 11:59 AM |
| Rear Oxygen Sensor for Link? | cpu77 | Normally Aspirated with bolt-on Forced Induction Powertrain | 15 | 04-11-2003 09:49 AM |
| oxygen sensor for o2 gauge. | veedubaholicvr6 | Factory 2.0L Turbo Powertrain | 4 | 10-06-2002 10:20 PM |
