Old 05-09-2010, 03:31 AM   #1
davidsti1
Member#: 210923
2001 RSTI Twinscroll
FullRace BW8374 ripper
Default any diy for tapping the header for egt?
would like to see some diy if there is any
thanks
davidsti1 is offline   Reply With Quote
Old 05-10-2010, 02:56 AM   #2
teiva-boy
Member#: 22825
Look in the 2.0 and 2.5 forums, it's been done and documented as far back as 2002 if not further back. I'd start with the stickies in each forum.
teiva-boy is offline   Reply With Quote
Old 05-10-2010, 12:27 PM   #3
PERRIN_Jarid
Member#: 214449
Drill a hole and weld in a bung. Not enough material to tap.
PERRIN_Jarid is offline   Reply With Quote
Old 05-10-2010, 12:47 PM   #4
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
True dat! Not to mention the possibility of tapping too deep.
kharris4 is offline   Reply With Quote
Old 05-10-2010, 04:25 PM   #5
tobylazur
Member#: 150289
2006 SV650, 05 CTSV
1972 Travelall
depends on the header. I drilled and tapped my factory header and have had no problems.
tobylazur is offline   Reply With Quote
Old 05-10-2010, 04:41 PM   #6
PERRIN_Jarid
Member#: 214449
Factory exhaust manifold yes? If so there is much more material there to drill thru than an aftermarket stainless header.
Old 05-11-2010, 06:18 PM   #7
piddster
Member#: 144285
1993 UHEV Legacy
About 1/8" minimum material thickness is the general rule of thumb. I like it thicker myself.
piddster is offline   Reply With Quote
Old 05-14-2010, 04:29 PM   #8
steverx05
Member#: 128269
'15 STi
[CWP]
There's a little raised up casting button on the stock driver's side portion of the manifold that most people use for tapping on the stock headers for an EGT gauge. There's plenty of material for tapping and threading in an EGT probe and I did this on my old WRX and it work great. I'm sure a welded bung would be ideal but, it's not necessary.
steverx05 is offline   Reply With Quote
Old 05-14-2010, 07:54 PM   #9
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
i drilled and tapped my stock exhaust manifold. it's been fine, and does not leak.
i also didn't want to remove anything, so i did it when the car was running.
did it that way with no ill effects on my Legacy and my old Eagle Talon..
Z0rr0 is offline   Reply With Quote
Old 05-14-2010, 09:05 PM   #10
norexyet
Member#: 39149
11 elantra
yea i said elantra
Vibrant makes a 1/8-27 bung which should accomodate most egt sensors. Drill hole and weld said bung
norexyet is offline   Reply With Quote
Old 05-26-2010, 04:14 PM   #11
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
GET TOOLS
GET Manifold
DRILL
TAP
INSTALL
WC LATHE WERKS is offline   Reply With Quote
Old 05-26-2010, 11:06 PM   #12
davidsti1
Member#: 210923
thank you ^^
any 2.5 non turbo headers for sale? bailey suby Private 'Wanted' Classifieds 1 03-25-2008 01:16 PM
FS: Stock headers w/ egt tap lugee SCIC Private Classifieds 11 09-18-2007 02:52 PM
diy for tapping into the cig lighter hocman99 Electrical & Lighting 0 07-12-2006 10:16 PM
Can you drill and tap the manifold for an EGT with it still installed?? eightballrj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 03-20-2003 12:38 AM
tapping the manifold for EGT guage = dead warranty? ants wrx Warranty Issues & SOA Problems 2 07-19-2002 05:06 PM
