Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 05-10-2010, 09:54 PM   #1
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
Default The Sin' is not in!!!
Those who know me I have been waiting far too long to get this project on the roll so here is a few pics.
Info,
BC 2.71L stroker SB with darton sleeves 102mm bore, coated CP pistons in 9.2-1 comp, fluid damper, moroso pan and pickup, ported oil mains through out the block, ported 11mm pump, Dynamicly balanced to 1/10th of a gram on the rotating assy, and many others...
Flowtech ported and flowbenched heads, 1mm oversized intake/exhuast valves, MUCH larger seats and HUGE bowls (the seat had to be scalloped because they touch LOL), BC springs and retainers, slippery skirt ceramic coating on the cam guides, BC 272 cams with avcs, ceramic coated valves and combustion chamber along with exhuast ports.
ACT heavy duty preasure plate, ACT sprung 6 puck, ACT streetlight fly.
And for the hairdrier, a HTA GT3586 with a .82 housing (this is the large 86mm HTA not the common 82mm HTA)
Fueling is 2000cc injectors, twin 044's, plus much more.
PICS...
And my new bad arse shift knob thanks to WC Lathe Werks BLING fo me!!!
Sinister redlines is offline   Reply With Quote
Old 05-10-2010, 09:54 PM   #2
jagr_200
Visiting NASIOC Timeout
Member#: 230710
2004 STi John Tuned!
04 AW Shwagon
Holy hell batman! Sooooo sick!
jagr_200 is offline   Reply With Quote
Old 05-10-2010, 09:57 PM   #3
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
Well its only taken me over 2 years to get this pig together. I will upload more pics as I go...
Old 05-10-2010, 10:05 PM   #4
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
2+ years!
good to see you are making some great progress
BREWPUBEAVER is offline   Reply With Quote
Old 05-10-2010, 10:14 PM   #5
twigg107
Member#: 119718
2008 STI
next month will be 3 years there buddy.
twigg107 is offline   Reply With Quote
Old 05-10-2010, 10:28 PM   #6
Loubaru
Member#: 155489
07 STi
Congrats! I think you started this when I first bought my Subie, lol (<--look at my join date). Looks like it will be a beast.
Loubaru is offline   Reply With Quote
Old 05-10-2010, 10:37 PM   #7
boostdsuby8
Member#: 139739
2.7 stroker
boostdsuby8 is offline   Reply With Quote
Old 05-10-2010, 10:40 PM   #8
twigg107
Member#: 119718
2008 STI
Here is acouple of pictures of his heads before they were coated and everything was installed.
Old 05-11-2010, 12:32 AM   #9
DD04
Member#: 232091
2004 Impreza WRX STi
WHoa!
DD04 is offline   Reply With Quote
Old 05-11-2010, 12:41 AM   #10
06WHTWRX
Member#: 173690
2005 Ferd
F-TeenThousand
Those are some grande valves.
That is all.
06WHTWRX is offline   Reply With Quote
Old 05-11-2010, 02:14 AM   #11
Enlefo
Member#: 235627
07 STI
Daaaamn. Keep us posted.
Enlefo is offline   Reply With Quote
Old 05-11-2010, 03:01 AM   #12
subieracer07
Member#: 155084
91 leggy wagon
tower we a clear for take off!!
subieracer07 is offline   Reply With Quote
Old 05-11-2010, 03:21 AM   #13
Frankenboost
Member#: 209766
2007 STI limited
UGM - 547WHP / 471TQ
You're running the same fuel set up as I am then. Twin 044's feeding the main rails and 2k cc injectors with a walbro feeding a surge tank right?
Did you go with the low impedence Injector Dynamics injectors?
That motor appears very well built.
Cheers to you and let us know how it turns out.
Frankenboost is offline   Reply With Quote
Old 05-11-2010, 05:42 AM   #14
Dena
Member#: 134874
Dena is offline   Reply With Quote
Old 05-11-2010, 08:49 AM   #15
ScoobyhitApex
Member#: 217524
ripn the
wrx up son
Sweet man, congrats! I know what it's like to finish a build that sometimes can take longer than expected.
ScoobyhitApex is offline   Reply With Quote
Old 05-11-2010, 11:50 AM   #16
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
Yes we have the same setup, what kind of power/IDC are you seeing with those injectors and setup on E85?
And thanks, many here from this site have helped me from time to time and they all know who they are and I do apprciate all thier support...
Old 05-11-2010, 11:55 AM   #17
kyleblix
Member#: 73495
E90 M3, '11
Forester, Viper GTS
Awesome build, congrats on the progress!!!!
kyleblix is offline   Reply With Quote
Old 05-11-2010, 05:59 PM   #18
Frankenboost
Member#: 209766
2007 STI limited
We overbuilt the fuel system just in case i itched for a larger turbo than the 35R... which has happened.
IDC - 70 - 72% at 547 whp on Surgelines dyno with a conservative ( detonation free ) tune.
Boost - 27psi max
I am running E85 on the car exclusively. Yours should make the same power or more however at less boost i would assume since the 35R will run out of air around here. Hence why I may go with the new 37R to push me over 600whp.
I really want a ride when you get done because I think your boost response is going to make me drool due to the larger displacement.
I am very jealous at the moment!!!!
Waiting patiently for you to complete it
Old 05-11-2010, 06:09 PM   #19
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
Frankenboost, My gt35 isnt a ordinary 35R. I had the HTA86mm (big not the smaller HTA82mm) conversion done to it which now lives a 75lb/min wheel instead of the 62-65lb/min wheel (couldnt remember which was stock).
So in retrospect this thing should breath just fine up top, but I think my hold up will be the T31 .82 exhuast housing. I believe most of the gt37's use a t4 housing and breathing out isnt a problem.
Hopefully Tim will be tuning it, I may have to find him and wrestle him to the ground to do it, or he will probably just beat me a and walk away. Either way he has only done the best for me with my previous tune so I hope I can wait for him again. LOL Dude probably needs a vacation (I havent talked to him but sounds like he never stops).
Old 05-11-2010, 06:13 PM   #20
Frankenboost
Member#: 209766
2007 STI limited
Tim is a great guy and he loves his work.
I plan on stopping in to see him in the next week or so due to my work taking me to Portland regularly.
Let me know when you plan on getting it tuned as I want to be there to see this thing in action. Then we can go hunting the freeways of Portland for prey.
As for your turbine housing I noticed that and breathing for the exhaust will be fantastic. I am just wondering about the ability for the compressor to move air. I am actually running it out of airflow at the top.
Old 05-11-2010, 06:17 PM   #21
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
It will be nice to see how much if any difference that .21L may make LOL. I do have a question, what engine management did you use?
Old 05-11-2010, 07:57 PM   #22
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
awesome project!
WC LATHE WERKS is offline   Reply With Quote
Old 05-11-2010, 11:54 PM   #23
Frankenboost
Member#: 209766
2007 STI limited
Accessport and some great tuning by Tim.
Thought about stand alones but just isn't worth it to me. Not trying to go for any records. Just wanted to build myself a reliable high HP street car that could pass Time attack track inspection as is. Ha ha =)
I am curious as well to see the diff it will make in your whole power curve.
You need to keep me posted.
PM me and I will give you my phone # so I can come see this beast.
I am in Silverdale a couple times a quarter and a trip out there is coming up. Not like it's far or anything.
The whole development behind your build is top notch man.
Old 05-12-2010, 12:38 AM   #24
mr soul
Member#: 58037
05' LGT Wagone
98' RS, hybrid 2.2T - RBP
I think it will be a significant difference. I've gone 2.2 to 2.4 to 2.5, each step it felt better. Torque with the stoker I think is where you see the most gain but I've never messed around with big HP turbos like you have.
Congrats on getting to this point, seems like an really top notch build! Now you've put the pressure on to get it broke in and post plots
mr soul is offline   Reply With Quote
Old 05-12-2010, 12:47 AM   #25
matty2hotty
Member#: 145838
01 B4 LGT "Sedan"
DR
Wow! Look at that Moroso oil pan, 1st thing that caught my eye. Great build, every good built takes longer then exspected!
matty2hotty is offline   Reply With Quote
Does the turbo spin up when the clutch is in or in neutral? mmiller2002 Newbies & FAQs 14 11-26-2008 08:59 AM
How do you get the jackstands under when the jack is in the way? perret318 Newbies & FAQs 25 03-12-2006 05:38 PM
okay so the MR is out, the STi is in trouble, are they gonna make the S202 for the v8 03boxer4 General Community 47 11-04-2004 04:43 PM
Well the STi is in the shop grknss New England Impreza Club Forum -- NESIC 4 11-13-2003 01:12 PM
The cage is in the Impreza...new Tim O'Neil/Brent Hatch design. Thoughts? Sean Motorsports 21 05-03-2003 10:31 AM
