Old 04-28-2010, 12:27 AM   #1
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
Default Custom Exhaust Thread
No disrespect to any exhaust manufactures out there, but let see the custom exhaust.. Catback, axlebacks, etc...
Twiztidunreal is offline   Reply With Quote
Old 04-28-2010, 12:33 AM   #2
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
Start with mine..
Gt-spec UEL headers(2 bolt flange)
2bolt rotated up-pipe with 44mm EWG
Rotated 3in Downpipe
Custom 3in Catback
Dual Burnt Tip muffler
i ordered a 3in flange and muffler with a 3in inlet offline, and took it to my friends shop where we used the pipe bender and welder to make my exhaust..
(will get more pics when i pull it off to paint the pipes black)
Muffler
Sound (reving to maybe 3k, camera about 3 ft away from exhaust)
i think i might need to put a resonator in there to kill that raspy sound, what do you think?
Old 04-29-2010, 01:45 AM   #3
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Old pic from about 5 years ago. This was way too loud for a daily driver at the time so i changed it. But now that its not i might make another one.
RS_to_WRX_swap is offline   Reply With Quote
Old 04-29-2010, 06:09 PM   #4
PERRIN_Jarid
Member#: 214449
Does this count? Quick custom side exit exhaust I made for a buddies Mazda.
PERRIN_Jarid is offline   Reply With Quote
Old 05-01-2010, 11:05 PM   #5
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Yay, I have something for this one:
Y-pipe:
Into 2 of these:
With some 2.5" piping:
All held in place:
Welded up:
Aaaaand with tips on it:
Crazy_pilot is offline   Reply With Quote
Old 05-02-2010, 03:09 AM   #6
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Nice work! got a video of how it sounds?
Old 05-04-2010, 01:29 AM   #7
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
I actually don't have one. I'll see what I can do about that.
Old 05-16-2010, 07:28 AM   #8
bjm
Member#: 87090
It's a set of Tomei copy equal length single scroll headers cut just before the merge collector and custom twinscroll up pipe. Has two tial 38mm external gates off the up pipes that go down and loop back under the gearbox just in front of the oil pan. Dump pipe expands to 4" off he back of the turbo and stays 4" to the back of the car. There is a 5" body metalcat just under the seat that is fitted with 4" v-bands for easy removal. Only muffler is an 8" x 5" box on the back.
The setup isn't quite finished in some of the pictures and some of the others are a little fuzzy because of bad light and phone camera.
bjm is offline   Reply With Quote
Old 05-16-2010, 07:40 AM   #9
alloutSTI
Member#: 241552
2015 GMC Sierra Z82
Subterranean Metallic
sound clips! this build looks insane!^
alloutSTI is offline   Reply With Quote
Old 05-16-2010, 11:30 AM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
I'm going to keep whoring these photos out for nostalgia sake. It's depressing...
4" exhaust anyone?
Ben
PHATsuby is offline   Reply With Quote
Old 05-16-2010, 11:43 AM   #11
fobiawrx
Member#: 91074
04 sti
white
do you have the ebay knock off header? i built a kit for a guy once that wanted to use that header and did the same thing as you. cut it at the collector and made it twin scroll all the way. it ended up exploding the flex sections and cracked down the middle of one of the runners with it a month.
fobiawrx is offline   Reply With Quote
Old 05-16-2010, 12:00 PM   #12
TheNailman
Member#: 133676
2005 WRX
this thread delivers
TheNailman is offline   Reply With Quote
Old 05-17-2010, 03:16 AM   #13
bjm
Member#: 87090
I have ebay knock off headers but the welding is good. There is no flex section in them, or do you mean the sliding expansion joint?
There are several different quality ebay knock offs. Do you know which ones you used?
The fabricator seems to think the quality and build is as good as GTSpec. Certainly has the same casting marks on the flanges, welds are all robot welds and they were hand ported before delivery.
The car is quite a way off starting yet so there won't be any sound clips for a while.
Old 05-18-2010, 11:08 AM   #14
sidewayz
Member#: 5810
2001 S366 2.5RS
I'll bite.
custom side exit exhaust for a customers Baja. 3" round tube going into a Vibrant resonator to 3" oval tubing.
sidewayz is offline   Reply With Quote
Old 05-18-2010, 11:18 AM   #15
sidewayz
Member#: 5810
2001 S366 2.5RS
Old 05-18-2010, 11:49 AM   #16
fobiawrx
Member#: 91074
04 sti
white
they must be different then. the one i used had flex sections and the weld didn't break, the metal did. right in the middle of a tube.
Old 05-18-2010, 04:47 PM   #17
bjm
Member#: 87090
They had the choice of either of these and chose the top set because of the larger primary pipe diameter.
Same two sets here. The set they used is on the left
here is the logo cast onto the flanges
Old 05-19-2010, 03:49 PM   #18
GEE-OTTO
Member#: 201277
2009 Legacy GT
Is that boosted EZ30R !!!????!!!
GEE-OTTO is offline   Reply With Quote
Old 05-19-2010, 09:51 PM   #19
PHATsuby
Member#: 13617
2001 Legacy GT back
It was going to be yes...it was nearly finished then sat for two years and then I sold off the Motor and tranny out of anger/frustration. I highly regret it now but I'll do something better/improved in the future.
Who knows maybe I'll make a kit for the 2010 3.6R
Ben
Old 05-19-2010, 11:33 PM   #20
XplicitRacingDesign
Member#: 242434
2004 WRX STi
Blue/Charcoal Grey 2 tone
does it have to be for a Subaru?
if not... here... Honda Civic Turbo Header.
XplicitRacingDesign is online now   Reply With Quote
Old 05-19-2010, 11:39 PM   #21
XplicitRacingDesign
Member#: 242434
2004 WRX STi
...and 1 more, atleast this one is a Turbo AWD vehicle, just not a Subaru.
1991 GMC Syclone #2200. (motor and turbo set up was sold and is still around somewhere, but the truck itself was destroyed in a house fire in Feb.)
Old 05-20-2010, 10:19 AM   #22
GEE-OTTO
Member#: 201277
2009 Legacy GT
how dare you pollute this forum with HONDA pics j/k thats a nice header clean welds and that cyclone is just insane. I had a decent setup for welding but I moved to a place that doesnt have a garage (condo) so I sold it all in a moving sale but I miss it daily and finding a fellow welder buddy is difficult
Old 05-20-2010, 10:33 AM   #23
GEE-OTTO
Member#: 201277
2009 Legacy GT
Ben
OH NOOESSSSSS! boosted EZ30R or better yet a EZ36R
what happened the money black hole was too great (the build) or you got tired of it and the work ahead
Old 05-22-2010, 02:38 PM   #24
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
I like that idea... Do you have a shot of how much ground clearance there was for the turbos?
Old 05-22-2010, 08:28 PM   #25
PHATsuby
Member#: 13617
2001 Legacy GT back
If I were to do it again I would model a mini manifold in solidworks and have it CNC'd. I could likely pick up another 1" of ground clearance. I was planning to have a skidplate on there as well for safety.
Ben
FS: 2 STI hood scoops, stock STI exhaust, 2.5RS/TS/OBS custom exhaust, and more! dlong27 NESIC Private Classifieds 18 03-12-2010 03:11 PM
Another Exhaust thread, sorry:Building a custom performance exhaust? agilitymaneuver Normally Aspirated Powertrain 1 09-02-2008 12:59 AM
Custom intake thread Machine Age Victim Member's Car Gallery 4 04-27-2004 02:25 PM
Custom Exhaust - Skips Exhaust Plaistow NH WRXBanish New England Impreza Club Forum -- NESIC 3 11-14-2003 06:50 PM
Trade! my custom Exhaust on your RS Exhaust! SONofSAM Bay Area Impreza Club Forum -- BAIC 7 04-13-2002 02:15 PM
