Old 05-22-2010, 03:15 PM   #1
djc1827
Member#: 238618
11.82 stock 5sp/eng vf52
Default New record on vf52
I was shooting for 11.7s so i could beat the sti record too but i dont think its gonna happen without some smaller wheels, better rubber, colder temps, exh wastegate etc. Here are the pics and i will have videos up soon on youtube. Dont ever let anyone tell you spt cbe are restrictive on small turbos cause this is proof the work just fine. Plus i dont attract cops.
Videos suck because my video camera battery died, used crappy camera and iphone
Back to back 12.01s
DETAILS
STOCK TRANS/INTERNALS
A.C.T. HD street clutch
Spt CBE
Invidia 3" catless dp
GTspec equal length header/uppipe
650s
Walbro
ks tech 83mm cai
perrin inlet/tmic
18" ninja rims
wanli s1088 235-40-18
Grimspeed EBCS
AEM 3.5 map sensor
Defi boost gauge
Coolingmist Meth kit
Cobb AP
PROUD MEMBER OF OVERBOOSTN.COM
Dyno tuned by INNOVATIVE TUNING 315whp 359tq at 23psi (heart breaker MUSTANG DYNO)
Fully loaded with nav/moonroof/heated seats/3250lbs minus spare/jack/pass seat
Weather details are located in pics
Track elevation 900ft
Esta Park Dragstrip, Cicero NY
[u] proof
Subaru Perf tech exh
baby turbo
More ice
2.4" inlet
Ice between runs
djc1827 is offline   Reply With Quote
Old 05-22-2010, 03:18 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Good job, great driving
Old 05-22-2010, 03:39 PM   #3
chongl
Member#: 187694
2009 GTX3076 WRX
520whp on E85
That's some great driving there.
chongl is offline   Reply With Quote
Old 05-22-2010, 03:44 PM   #4
KurtP
Member#: 44836
1999 Fozzy
Why did you choose to use a 80mm intake anda 3.5 bar map sensor?
Old 05-22-2010, 05:13 PM   #5
djc1827
Member#: 238618
I went 83mm cause 73mm wasnt in stock lol I was getting tuned that weekend. I figured what am i gonna do flow too much air? Prob overkill, i noticed the throttle response is a bit slower sometimes. I bought a 3.5 map sensor because stock sensor only logs 22.5psi and what if i hit boost spike? Didnt want to run into boost cut issues etc To be honest i was hoping to run more boost like 24+ but i think with my tmic, the vf52 is just blowing hot air and working overtime. Although i might experiment with some kinda spray for my tmic to cool it down. Maybe co2 etc. It doesnt bother me that much unless its 75degrees+ which isnt very often here in central ny. A part of me wishes i had a fmic but i dont think its necessary unless you live in a hot climate, i would rather spend $300 on a nice co2 kit. But i knew from the start i wasnt gonna upgrade my turbo, i like fast spool, and being able to go back to stock in a weekend if ever needed.
Old 05-22-2010, 07:44 PM   #6
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
i got to admit, nice driving and based on your 1/4 times from before and your new tune numbers, a .3 second drop is right where you should be. wheels and better weather could defiantly help next time!
you gotta be kidding, a brand new ACT and you think its slipping? i hope not.
synolimit is offline   Reply With Quote
Old 05-22-2010, 08:41 PM   #7
sopmoney
Member#: 146031
03 tomei ftw!
psm
that track looks like someones backyard lol. nice driving man keep it up
sopmoney is offline   Reply With Quote
Old 05-22-2010, 09:26 PM   #8
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Nice driving!!
08EJ25 is offline   Reply With Quote
Old 05-22-2010, 10:11 PM   #9
djc1827
Member#: 238618
Yeh i hope its not slipping, i glazed it real bad racing cars back to back on street using launch control the night before....called it quits it feels fine when its cold but once i heat it up with sick launching she feels weird in 3rd...who knows maybe my rpms are just climbing so slow cause of the hot humid air and tmic. You would think it would slip real bad and my 60ft would suffer so ill prob be alright. I would rather burn a clutch out every year or two than have to put a new trans in tho. Organic street discs always come back to life most of the time.
Old 05-22-2010, 10:34 PM   #10
synolimit
Member#: 225225
11 WRX
how did you tuner set up the LC. i thought LC wasnt out for are cars. better question how do you use it?
Old 05-23-2010, 01:19 AM   #11
djc1827
Member#: 238618
Yea some tuners have beta version, like a demo. You set it at whatever rpms you want. I run 4500 on street and 5-5500 at track. Just hold clutch in and put gas to floor. Stutters and you build like 10psi out of the hole. Release clutch kinda fast tho or u will glaze your clutch bad and will have to wait 1-2 hours for it to cool down
Old 05-23-2010, 01:26 AM   #12
synolimit
Member#: 225225
11 WRX
ur able to switch the launch because you have an AP right? i need Romradier and a tactrix cable. sounds easy enough and good consistent times.
Old 05-23-2010, 01:27 AM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
great run there - try lighter wheels/tires. You will definitely be in 11s!
Old 05-23-2010, 12:28 PM   #14
djc1827
Member#: 238618
ill hit 11s when the weather cools down. I will go back to the track and run 11.8s 11.9s when its 50-60degrees...maybe ill bump the LC up to 5500 and drop tire pressure to 25psi I was running 30 all the way around out of fear of breaking something
Old 05-23-2010, 02:43 PM   #15
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Everybody was shocked at the autocross at how quiet your car is! It definitely has a unique sound, but it's not a screamer like so many modified cars are.
ESTA (dragstrip) definitely looks like someone's backyard! It's some seven miles from my house, and while I'm on the civilized outskirts of Syracuse, ESTA is a step into the sticks. I've only got Maple Grove (SE PA) to compare it to, but it's as much track as you need.
LetItSnow is offline   Reply With Quote
Old 05-23-2010, 02:56 PM   #16
Speed
Member#: 67371
05 BUILT 2.4L STI
Nice time and driving. Congrats on the record, 114 with the stock turbo is nothing to sneeze at, it should definitely hit 11's with better weather and/or tires.
Speed is offline   Reply With Quote
Old 05-23-2010, 03:28 PM   #17
red06rex
Member#: 246914
2006 wrx
awesome time and definately real good launch man
red06rex is offline   Reply With Quote
Old 05-23-2010, 06:20 PM   #18
djc1827
Member#: 238618
Yea i like my subaru perf tech catback, its throaty but not too obnoxious like most aftermarket mufflers. Cops dont mess with me and the dual exh looks sharp and more sleek to me. Most people disagree with me for getting rid of the rumble but its just a flaw in exh technology if you ask me. 75% of tuners will tell you to go equal length anyways. Esta isnt the best track for sure, but its only 20 min away from me so if i break something I dont have to tow my car 100 miles
Old 05-23-2010, 06:40 PM   #19
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
Nice driving for sure, Thanks for posting
boost4life is offline   Reply With Quote
Old 05-24-2010, 11:02 AM   #20
SoLo OnE
Member#: 9941
www.djforums.com
Nice!
SoLo OnE is offline   Reply With Quote
Old 05-24-2010, 11:22 AM   #21
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
nice job
BUILTSTI is offline   Reply With Quote
Old 05-24-2010, 02:10 PM   #22
tuner_ready
Member#: 210642
'07 Built WRX #187
'16 CWP WRX Daily
congrats man! I was at cherry valley last weekend, now i understand why you were saying you'd rather be at the drag strip, haha.
tuner_ready is offline   Reply With Quote
Old 05-26-2010, 12:04 PM   #23
SoLo OnE
Member#: 9941
www.djforums.com
Stock Block and Stock Trans Makes me happy
Old 05-27-2010, 07:24 PM   #24
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
As a tuner it's always nice to see a car is running consistently, but two 12.01s...I guess all you can do is laugh.
I agree that you'll get your 11's this year. The 60 foot has some room for improvement with better track prep and tires, and the car will definitely be quicker on a cooler day. I'd say you did awesome considering the conditions.
What's the fastest stock turbo and engine time for the WRX in general, not just VF52?
What shift knob did you use?
Innovative Tuning is offline   Reply With Quote
Old 05-28-2010, 11:33 AM   #25
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Congrats my friend! You should wait for cooler weather and take another shot. It definitely has 11's in it!
I'm happy your using the ks-tech 83mm maf as well. Im going to be doing a lot of tuning with that unit.
I recently came upon a video of a young gentleman knocking Innovative's preference on the intake. Even though I respect the man behind the camera, I felt the guy on camera was an idiot.
I feel that if your going to mod a car at all, do the 83mm and ID 1000s/2000's. If you know how to tune the setup, those mods never have to be changed (only modified for fittment with fmic). You can run those without problem on the stock turbo, through c16 on a 35r setup.
I've had 3 intakes, and three sets of injectors in my car.. Stupid. Do it once, do it right.
Good job guys!
PhatBotti Tuning TKR is offline   Reply With Quote
New Record on ICS '08 STI 568 WHP 579 TQ - Thanks Cobb Tuning AP2! Dyno Flash Proven Power Bragging 78 03-02-2008 01:58 AM
412.7 wheel HP on stock sti 2.0 litre - No NOS - new record at Pruven Performance ! alfriedesq Proven Power Bragging 353 07-12-2006 03:09 PM
New speed record on 2222 andrewt461 Texas Impreza Club Forum -- TXIC 5 04-30-2006 01:11 PM
New Record! 407 WHP on 93 octane! Tuning Factory Inc. Proven Power Bragging 61 07-29-2004 08:22 AM
