Old 05-25-2010, 03:36 PM   #1
bertune
Member#: 107290
Default Help! How do U get the romraider logger to log the LC1 AFR?
Searched and didn't find anything about it.
HELP!!!
bertune is offline   Reply With Quote
Old 05-25-2010, 03:40 PM   #2
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
do you already have the cable to connect the lc1 to the computer? It's a serial to usb adapter. I bought mine at best buy for like $35.
codesoccer is offline   Reply With Quote
Old 05-25-2010, 03:42 PM   #3
bertune
Member#: 107290
My computer has a serial port
Old 05-25-2010, 03:43 PM   #4
codesoccer
Member#: 179573
2002 MBP Bugeye
Oh well then nvm, mine didn't so I had to buy the adapter.
Old 05-25-2010, 03:58 PM   #5
bertune
Member#: 107290
Help!
Old 05-25-2010, 04:19 PM   #6
codesoccer
Member#: 179573
2002 MBP Bugeye
When you go to plugins then innovate lc1, does it let you choose the port?
Old 05-25-2010, 05:42 PM   #7
bertune
Member#: 107290
Yes it does
Old 05-26-2010, 04:33 AM   #8
coldturbo
Member#: 168900
2002 Impreza WRX
Vf-39 Grp.N luv
Have you installed Logworks and the LM programmer?
Check your version of RR, the newest has improved support.
http://www.innovatemotorsports.com/s...orks3Setup.exe
Both will help you start with the LC-1.
Make sure the fuel type is set to gasoline in the LMP.
coldturbo is offline   Reply With Quote
Old 05-26-2010, 08:12 AM   #9
quazimoto
Member#: 70395
Old 05-26-2010, 09:42 AM   #10
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
This what you need to do assuming the LC1 is connected correctly:
1) Connect your serial cable to your labtop
2) Launch LM Programmer and set it to gasoline
3) Launch Log Works and set it to gasoline
4) Select the correct comport in Log works
5) Calibrate the 02 sensor (free air)
6) Install the 02 sensor
7) fire up the car and make sure that log works gives you good data (14.7 at idle
8) close log works
9) Open RR logger
10) go to plugins and select Innovate Wide Band (not LM2) and the correct port
11) go to external switches and select Innovate AFR
12) go to the dashboard and make sure it's reading
Sometimes you have to click the Innovate external switch box multiple times so that it reads.
Is a long list but after doing a couple of times you get use to it.
Wil
wil06STI is offline   Reply With Quote
Old 05-26-2010, 11:40 AM   #11
bertune
Member#: 107290
8) close log works
9) Open RR logger
Wil
Thanks for the input guys, i pretty much had already done all mentioned above and went over it again and no readings. The LC1 only works on com1 and when i open RR and do the steps the reading stays at 0, when i close logworks (not minimize) and do the steps in RR the reading is at 20.+ but doesn't move.
Old 05-26-2010, 12:47 PM   #12
quazimoto
Member#: 70395
I don't use Logworks at all. I run the LC-1 straight from Romraiders logger. It has to be hooked up before the LC-1 is powered on. The just select LC-1 as a plug in and then in the data menu on the let of the logger select LC-1. Make sure you have the shunting plug inserted in the "in" connection for the Lc-1.
Old 05-26-2010, 02:48 PM   #13
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
You need to double check that both the LM programmer and log works are set to gasoline. I like using log works before launching RR because i can see if the calibration was done correctly and also to make sure if its reading properly. You should try that and check and uncheck the LC1 box a few times.
Wil
Old 05-26-2010, 04:38 PM   #14
bertune
Member#: 107290
O.K. had some other problems but got that part working again, other part still not working.
Got it working, Thanks for the help guys, i really appreciated it!
Old 06-14-2013, 02:19 PM   #15
qtr_wrx
Member#: 109567
I know its old thread, but I now have the same problem with my lc1. In my rr it always show 0 and in logworks it always give me a message that my lc1 is not connected? Any idea how to get it works with my rr as I need to record my afr logs for my tuner?
qtr_wrx is offline   Reply With Quote
Old 06-14-2013, 07:49 PM   #16
JonnyV2889
Member#: 197384
2006 WRX Ltd
You need to to get it working with log works before it'll ever work with romraider. What are you using for a serial to USB adapter? It's likely either a baud rate issue or driver/port issue. Mines still finicky but works.
JonnyV2889 is offline   Reply With Quote
Old 06-14-2013, 08:03 PM   #17
codesoccer
Member#: 179573
2002 MBP Bugeye
Are you using a serial to usb adapter? I couldn't get mine to work because of a driver issue. The pl2303 driver on this page solved the issue for me.
http://prolificusa.com/pl-2303hx-drivers/
Old 06-15-2013, 09:31 AM   #18
qtr_wrx
Member#: 109567
yah I'm using serial to usb adapter, but I think its not driver issue (its already identified in my pc) but it could be a baud rate issue. Gonna try adjusting the rate. it's 19,200 right?
Old 06-15-2013, 03:50 PM   #19
JonnyV2889
Member#: 197384
2006 WRX Ltd
Should be determined by the serial adapter, but I'll let you know when I get home since I need to do some pulls.
Putting the dock in
Edit: what brand serial adapter.
Old 06-16-2013, 03:52 PM   #20
qtr_wrx
Member#: 109567
IT WORKS IT WORKS MUHAHAHAHA
thanks alot guys really big help you gave me... awesome now I can proceed. What went wrong is the baud rate is set to 9,000 instead of 19,200
Thanks alot guys
Please help, how do you get rid of moisture in the car? BrysImpreza Interior & Exterior Modification 13 12-30-2004 04:33 PM
HELP! How do I get the DEEP REACH Adpt. our of engine! makofoto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-16-2004 05:03 AM
Help! How do I get part numbers from the Subaru Technical Manuals? Corn-Picker Service & Maintenance 2 03-24-2004 03:50 PM
Help! How do I get satisfaction? czo79 Off-Topic 2 10-24-2003 02:13 PM
How do i get my new wrx to dominate the road? Donaldson395 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 06-28-2001 09:01 AM
