Old 06-01-2010, 04:19 PM   #1
tirkish
Member#: 171886
16 STi Limited
MurderShine
Default What is that noise?
When I punch into boost, I get a strange squeal.
Sounds like a cross between a boost leak and a squealing belt. Doesn't happen every time, but I'd say 80% of the time.
Happens right around 4K rpm.
Some notes about the car:
TMIC never removed.
ZERO mods whatsoever under hood.
Only mod is a CBE.
under 30K miles.
Sound in't great in the video, but you'll hear it clearly on the second pull.
tirkish is offline   Reply With Quote
Old 06-01-2010, 04:24 PM   #2
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Do you have the a/c on? lol
NitroTrike is offline   Reply With Quote
Old 06-01-2010, 04:26 PM   #3
tirkish
Member#: 171886
16 STi Limited
MurderShine
Forgot to mention that.
No, the A/C compressor is not on.
Old 06-01-2010, 04:55 PM   #4
Omega79
Member#: 244020
99 OBW
Blue-ish
From the video that sounds very much like belt squeal. Maybe idler pulley issue? GR with under 36k miles? Why not take it to the dealer?
Omega79 is offline   Reply With Quote
Old 06-01-2010, 05:21 PM   #5
tirkish
Member#: 171886
16 STi Limited
MurderShine
Dropping it off in the AM at my dealer. Just hoping for some forum feedback.
Old 06-01-2010, 08:17 PM   #6
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Definitely sounds like a belt. There's nothing else I can think of that would cause such a noise. Boost leak doesn't sound like that at all.
Exhaust leaks make a hissing, air-blowing-in-a-plastic-bag type of noise.
Sounds like a beat from an old 80's rap song.
ejicon is offline   Reply With Quote
Old 06-01-2010, 08:25 PM   #7
simonella_virus
Member#: 183875
2007 WRX STi Stg2
sounds like someone's slowly squeaking air out of a balloon.
simonella_virus is offline   Reply With Quote
Old 06-01-2010, 08:27 PM   #8
etothen
Member#: 221885
09 Ivory Tower
Ivory...duh
+1 for belt squeal.
BTW you do a great RW emoticon.
etothen is offline   Reply With Quote
Old 06-01-2010, 08:38 PM   #9
tirkish
Member#: 171886
16 STi Limited
MurderShine
Originally Posted by etothen View Post
+1 for belt squeal.
Yes, that was what I was going for! ""
Well, the belt scenario was my immediate gut feeling, but some others led me to believe it was potentially a leak. Being that I'm bone stock, I'm hoping it's just a matter of adjusting/replacing a belt as apposed to tracing a leak somewhere.
I'll know tomorrow and post the results. Thanks all!
Old 06-01-2010, 08:41 PM   #10
andrius
Member#: 211519
2007 wrx
wrb
ya def a belt.
andrius is offline   Reply With Quote
Old 06-02-2010, 12:33 AM   #11
Omega79
Member#: 244020
99 OBW
Blue-ish
So you're paranoid lol! It sounds the same as when my friends idler pulley went bad, I wouldn't sweat it. Let us know how it goes.
I concur very good unamused face btw.
Old 06-02-2010, 12:34 PM   #12
tirkish
Member#: 171886
16 STi Limited
MurderShine
Dropped the Rex at the Dealer this morning to investigate my boost leak/belt squeal sound.
They ran the fog test on her respiratory system and found no leaks. A good sign. They couldn't, however, duplicate the noise. I had to go there, drive the car on 95 with a tech in the car to show him. Luckily it made the noise (it sometimes doesn't), and I also played the above vid on my sound system for the whole shop.
Still a mystery, but he thinks it might be the A/C belt, being that it's a fixed belt with no adjustment... so if it should stretch a bit, it's done. They're replacing now, so we'll see by end of day.
Fingers crossed
Old 06-02-2010, 12:35 PM   #13
RideAllnight
Member#: 248264
lol i was thinking the same thing
RideAllnight is offline   Reply With Quote
Old 06-02-2010, 02:55 PM   #14
NitroTrike
Member#: 62408
Fingers crossed
A fixed belt with no adjustment? When did they start using auto tensioners?
Old 06-02-2010, 06:34 PM   #15
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
keeping fingers crossed for ya.
Old 06-02-2010, 06:53 PM   #16
tirkish
Member#: 171886
16 STi Limited
MurderShine
Not auto tension... from Soobie Shop Manual:
"NOTE: Because the rear side belt is a stretch type belt, it is
not necessary to check deflection and tension."
Old 06-02-2010, 06:56 PM   #17
tirkish
Member#: 171886
16 STi Limited
MurderShine
UPDATE
It's not the Rear Side Belt (going up to the Compressor), since that was replaced.
After replacing the belt, there is still a sound, albiet slightly different. Now there is a definite "wooshing" when turbo is spooled.... it's a leak. I think, at least.
The dealer ordered new gaskets for the TMIC, which they will install when they come in next week. Hoping that solves it. Another tech remembered a similar problem on a newer car and that did the trick. We'll see.
Got a free belt and install out of it
Old 06-09-2010, 05:11 PM   #18
tirkish
Member#: 171886
16 STi Limited
MurderShine
UPDATE :: RESOLVED! (for now)
Throddle Body to Intake Manifold O-Ring was defective
Old 07-07-2010, 12:29 AM   #19
beverett82
Member#: 251298
2006 Impreza WRX
I am getting the exact same noise on my 2002 WRX, only it is starting much sooner, pretty much anytime during acceleration. I started hearing it after my car had been repaired from hitting a deer. When I took the car back to the dealer, I was told that the noise was the turbo going bad. SO, I replaced the TD04L with a brand new one, and guess what.. Still getting the exact same noise. I have GOT to get this noise fixed, as it is very annoying and very audible from outside the cab. Was the mentoined repair difficult to do yourself, or did you have the dealer do it? Any help/advice is appreciated.
beverett82 is offline   Reply With Quote
Old 07-08-2010, 03:44 PM   #20
beverett82
Member#: 251298
2006 Impreza WRX
Just found out today that the source of my car's noise was mostly due to the fact that the last shop to work on it failed to tighten anything on or around the IC. Luckily, I believe I've FINALLY found a good Subaru mechanic in downstate IL.
What is that noise? Vicious LSD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-05-2008 07:16 PM
What is that noise?!?! awdity Off-Topic 6 09-23-2004 12:34 PM
What is that noise? jacksonww1 Normally Aspirated Powertrain 5 07-06-2004 02:47 AM
F1 cars, what is that noise? jeffg Off-Topic 53 10-25-2003 02:23 AM
What is that noise? Chode_boy Service & Maintenance 15 09-26-2002 04:24 PM
