Old 05-31-2010, 10:50 PM   #1
miketheskibum
Member#: 244892
2001 Outback Limited
Default Outback EJ251 to Baja Turbo EJ255
I'm new to the forum, so if I say/ask stupid things, I'm sorry.
Someday I would like to turbo my 2001 Outback. I've considered installing a turbo, but then there's the exhaust mods, fuel system mods, TMIC or FMIC, BOV, Waste Gate, tune, and whatever I'm forgetting. I figured it would be a heck of a lot easier and more reliable to swap in a Baja Turbo engine. Does anyone know if these would share engine mounts since they are basically the same engine, cept one has been modded to use a turbo? Also, could I just toss the Baja's ECU in and hope for it to work? I'm not looking for something that's gonna make tons of power, it's not gonna be a track car, I was just hoping for a little something extra when I put the pedal down. Do you guys (in your infinite wisdom) think this would be a fairly straight-forward swap? And if anyone knows where I could find an engine, that would be really cool. Thanks!
miketheskibum is offline   Reply With Quote
Old 06-01-2010, 03:04 AM   #2
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Haha I'm thinking of doing something similar but maybe a 06 outback engine... Do you know if it's plug and play minus the ecu
azn0boi04 is offline   Reply With Quote
Old 06-01-2010, 03:02 PM   #3
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
the baja is FAR FAR more dooable
you would swap everything under the dash then re wire the back half of the car to match up with the baja harness
the 06 is can bus
Old 06-01-2010, 04:37 PM   #4
miketheskibum
Member#: 244892
Cooool. Thanks. Anyone know about the engine mount question?
Old 06-01-2010, 05:30 PM   #5
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
mounts aren't the issue
you would need the baja sub frame
basically swapping every thing from the behind the dash to the front of the car over
Old 06-01-2010, 08:23 PM   #6
miketheskibum
Member#: 244892
Sounds like a lot of work. Should be a nice project. thanks.
Confirmation? Baja Turbo rear swaybar fit '01 Outback? Siper2 Brakes, Steering & Suspension 0 06-28-2005 08:47 AM
difference between Baja turbo and Outback? 10.5sec1992AWDtalon Baja Forum 10 03-13-2005 08:55 PM
Baja-T, Forester FXT and Outback XT shares same turbo wikidwrx Baja Forum 13 02-26-2005 04:27 AM
03 Baja + Turbo Kit or 04 Baja Turbo notbob Baja Forum 4 12-10-2003 12:24 AM
Baja Turbo to come on sale in new Gen. Legacy shape? FuJi K News & Rumors 21 08-22-2003 06:08 PM
Message Board Statistics All times are GMT -4. The time now is 06:44 PM.
