Old 05-22-2010, 08:36 PM   #26
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Originally Posted by GEE-OTTO View Post
OH NOOESSSSSS! boosted EZ30R or better yet a EZ36R
what happened the money black hole was too great (the build) or you got tired of it and the work ahead
Both. After I didn't finish it by my original planned deadline and it sat for a couple years I dreaded the work ahead and money required to finish it. I became a little more financially responsible as well and realized the money sitting in the car doing nothing wasn't really helping me either.
The ideal scenario would be if I could get people to pay me to do that on THEIR cars instead. Unfortunately no current time for that, but once I do get time and a garage I'll get started again. I already have laid out what I would like to do.
Ben
PHATsuby is offline   Reply With Quote
Old 05-24-2010, 04:13 PM   #27
GEE-OTTO
Member#: 201277
2008 Legacy
Originally Posted by Twiztidunreal View Post
Start with mine..
Gt-spec UEL headers(2 bolt flange)
2bolt rotated up-pipe with 44mm EWG
Rotated 3in Downpipe
Custom 3in Catback
Dual Burnt Tip muffler
i ordered a 3in flange and muffler with a 3in inlet offline, and took it to my friends shop where we used the pipe bender and welder to make my exhaust..
(will get more pics when i pull it off to paint the pipes black)
i think i might need to put a resonator in there to kill that raspy sound, what do you think?
I think you may need a a nice long glasspack resonator like a Thrush unit or Vibrant one. But it looks very nice i envy you
GEE-OTTO is offline   Reply With Quote
Old 05-25-2010, 10:40 PM   #28
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
7"? That's more than I would have expected. They barely hang below the x-member. Skidplate definitely makes good sense, a nice solid one (although I would incorporate some slotting to vent heat. Those nice hunks of superheated cast iron next to your oil pan...). I'm wondering how that would work for the SVX, I'm a bit shorter on ground clearance (and will only be losing more). It definitely makes for a very efficient layout and easy exhaust routing though.
Originally Posted by PHATsuby View Post
If I were to do it again I would model a mini manifold in solidworks and have it CNC'd. I could likely pick up another 1" of ground clearance. I was planning to have a skidplate on there as well for safety.
Ben
Crazy_pilot is offline   Reply With Quote
Old 05-31-2010, 08:16 AM   #29
rstinut
Member#: 143993
1999 2.5RS
white
5zigen catback with a varex welded on the end with a slashcut tip = <3 my exhaust lol.
sound clipage. I swaer to god if someone says somthing about the condensation im going to cry lmao.
John
rstinut is offline   Reply With Quote
Old 05-31-2010, 08:18 PM   #30
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Here is my custom setup. The muffler is a Twin Tip vibrant muffler with a single 4" inlet and dual 3" outlets. The tubing is 4" 304 Stainless. Header and uppipe is Full Race Ver 1 with twin Tial 44mm wastegates. The turbo is a GT42R.
More pictures can be found here
wrx_driver_2002 is offline   Reply With Quote
Old 06-04-2010, 06:07 AM   #31
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
anybody have a DIY DP and mid pipe with brand name axel back?
Strobe Media is offline   Reply With Quote
Old 06-04-2010, 06:08 AM   #32
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
YouTube- Varex on subaru impreza turbo
John
i would pay $$$ to have you make me one of those.....i've been looking for something raspy instead of deep
Old 06-04-2010, 01:00 PM   #33
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
I'm running a APS cast turbo elbow, and a DIY downpipe to attach to the BPM mid and tail sections.
NitroTrike is offline   Reply With Quote
Old 06-05-2010, 03:46 AM   #34
rstinut
Member#: 143993
1999 2.5RS
white
its actualy deep sounding. if you want raspy i recomend this setup.
Old 06-05-2010, 12:41 PM   #35
NitroTrike
Member#: 62408
Downpipe being made to bolt to an APS turbo outlet
Old 06-14-2010, 06:50 AM   #36
Storm
Member#: 5218
96L Most Over-
Developed Beater
Throwing my hat in the ring here. This is my 2nd version of a custom EJ22 singleport header. This one is based on the Cobb/Brullen/OBX equal length header for the NA EJ25's. Nobody makes one for the singleport, so I made my own.
On the jig, tacking things up.
Initial fitment showed that I put a reference point in the wrong spot on the jig, so my 45* tube had to be rerouted to go straight back and over toward the collector before merging in. The finished piece ended up like this.
Primaries are 1.8" ID 304SS collected into a 2.25"ID section. Primaries seem large because they're each handling 2 cylinders right from the head. Runner lengths are within 0.5" of being equal at about 44" long. Butt dyno says this one is at least as good as the MRT style longtube header I made a couple years ago, both of which are head and shoulders better than the OEM manifold.
Might as well show my 1st attempt at custom header fabrication. Complete with fluxcore welded 304SS!!! It never broke on me, which is alot more than I can say for the couple Borlas I've had through the years....
Jay Storm
Old 06-14-2010, 12:56 PM   #37
GEE-OTTO
Member#: 201277
2008 Legacy
look just make me a UEL for my 2008 2.5i Just one nobody has to know
Old 06-14-2010, 02:26 PM   #38
dubRexn
Member#: 16100
GD
i'm surprisied there are no side exit EWG dump tubes, maybe I'll be the first
dubRexn is offline   Reply With Quote
Old 06-14-2010, 03:18 PM   #39
chuds
Member#: 245141
07 2.5i
cgm
Going to make a mid pipe for my 07i with a Stromung axel back. I will be adding a resonator. Think a 5" round 14'' length will work? There is also a 4'' round 18'' long. Either way I don't want to be super loud for DD.
chuds is offline   Reply With Quote
Old 06-15-2010, 09:51 AM   #40
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
anyone know what the DB levels are on the vibrant performance 1153 muffler compared to the stock sti exhaust? Ive got a CSS turbo back right now, and it performs great...but its a bit too loud. I'm looking to fab up something quieter than the css but still louder than stock. Something around borla hush terrtory. The vibrant muffler is the only one Ive found so far that seems to be what I want. If anyone else has any suggestions im open to those too...
timeXlost is offline   Reply With Quote
Old 06-15-2010, 05:01 PM   #41
sauuce
Member#: 109253
2006 STi
SGM
The GST L has side exit exhaust and dump tubes. I think it's one exhaust pipe and one ewg pipe that goes out each sideskirt. Courtesy of Tommy aka porkchop.
sauuce is offline   Reply With Quote
Old 07-07-2010, 06:30 AM   #42
stidoc
Member#: 147579
Anyone have experience with any of the Burns Stainless mufflers? Wondering if they sound fart canny.
stidoc is offline   Reply With Quote
Old 07-20-2010, 12:04 PM   #43
strawe510
Member#: 251454
This is the downpipe I made for my Datsun 510 with a SR20DET in it.
strawe510 is offline   Reply With Quote
Old 07-20-2010, 04:17 PM   #44
Badler
Member#: 133597
Here is my axleback. Magnaflow race series w/dual wall tip.
Badler is online now   Reply With Quote
Old 07-22-2010, 06:00 PM   #45
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
how loud is the race series?
Old 07-22-2010, 06:48 PM   #46
Badler
Member#: 133597
It's sorta loud but not too crazy. I have a resonator in the mid pipe too. I don't have any sound clips.
Old 07-29-2010, 03:28 AM   #47
Kfly04
Member#: 252005
2004 STI
Java Black
post #3 and #10 thats awesome I've been thinking and planning on fabricating my own bellmouth cattless down pipe for a while I think Im gonna build my own out of 3" tubing!
Kfly04 is offline   Reply With Quote
Old 07-29-2010, 03:37 AM   #48
bjm
Member#: 87090
Found this on another forum, it's for an EZ30R
bjm is offline   Reply With Quote
Old 07-29-2010, 03:20 PM   #49
sidewayz
Member#: 5810
2001 S366 2.5RS
built this today. Mazdaspeed Protege downpipe for a t3/t4 system.
lots o pie cuts here.
sidewayz is offline   Reply With Quote
Old 07-29-2010, 07:28 PM   #50
PERRIN_Jarid
Member#: 214449
Downpipe I made for my turbo Mazda MX3. Boost sensitive exhaust cutout with divorced wastegate.
PERRIN_Jarid is offline   Reply With Quote
FS: 2 STI hood scoops, stock STI exhaust, 2.5RS/TS/OBS custom exhaust, and more! dlong27 NESIC Private Classifieds 18 03-12-2010 03:11 PM
Another Exhaust thread, sorry:Building a custom performance exhaust? agilitymaneuver Normally Aspirated Powertrain 1 09-02-2008 12:59 AM
Custom intake thread Machine Age Victim Member's Car Gallery 4 04-27-2004 02:25 PM
Custom Exhaust - Skips Exhaust Plaistow NH WRXBanish New England Impreza Club Forum -- NESIC 3 11-14-2003 06:50 PM
Trade! my custom Exhaust on your RS Exhaust! SONofSAM Bay Area Impreza Club Forum -- BAIC 7 04-13-2002 02:15 PM
Message Board Statistics All times are GMT -4. The time now is 07:30 PM.
