#1 |
Member#: 233276
Vehicle:2009 2.5i Hatch SWP |
Is it bad to redline your engine on a daily basis? How would it affect long term engine life? Will I see 150k-200k miles?
#2 |
Member#: 168129
SCIC
Vehicle:2013 WRX WRBP |
IMO it doesn't hurt the engine one bit, that's what a rev limiter is for.
#3 |
Member#: 151079
MAIC
Vehicle:2005 2.5RS RBP s-techs mad tyte yo |
I agree with subyroo.
#4 |
Member#: 233276
Is there anyone on here that has high mileage on a hard driven subie?
#5 |
Member#: 167943
NWIC
ya rev limiter is set at a safe limit for your car. But maintainting your car is all on how often you check or change your oil and such.
#6 |
Member#: 141373
E. Canada
Vehicle:2008 2.5i-hatch - now with a HID retrofit |
Engine wear - or the expected mileage out of a car is a function of mileage, nr of winters, maintenance, average RPM, peak RPM, the distribution of engine load over total engine's operating time, number of startups, minimum temperature, maximum temperature, commute distance and hours, traffic conditions, intervals between consecutive startups, quality of roads driven, altitude, elevation, air pressure, and humidity.
Add to that the impact of the driver's age, health, skill, marital status, temper, the personnality of your significant other and the number of kids. To make things worse, a lot of the aforementioned variables are mysteriously correlated with the others (a temperamental driver with a bitchy wife and screaming quadruplets might vent on the gas pedal more than a 85yo zen retired hippie). Bottom line is that you won't get a satisfactory answer. Search the forum for mileage tales. Lot of cars driven like they've been stolen with litle problems and big mileages. Lot of stories of babied cars which kept having issues too. |
#7 | |
Member#: 120386
South East
Vehicle:2000 BRP 2.5RS Coupe Wow the 89 Civic is fast |
#8 | |
Member#: 231058
South East
Vehicle:2012 Hyundai Sonata terbo |
#9 | |
Member#: 168129
SCIC
Yeah dude that's a bit much. |
#10 |
Member#: 134005
MAIC
Vehicle:2004 WRX Premium PSM |
In general, I'd assume if you treat it right through regular maintenance and even some preventive maintenance (replacing things before they call to be replaced) you should get a good 150-200K out of a Subaru engine, or really any car. Pair that with babying it, and I think you have a good recipe for success.
Now, no maintenance and babying it... yep, gonna lead to problems. Maintenance and gunning it all the time means more maintenance, which if you're following Subaru's guidelines maybe be not enough maintenance for the driving conditions... hence why engines sometimes fail. |
#11 |
Member#: 120386
South East
#12 |
Member#: 243664
NWIC
Vehicle:1999 Legacy GT Quicksilver Metallic |
simple rule to engines: Higher rotational speed - higher friction
treat your car accordingly, just make sure you have an adequate amount of clean (enough) oil, for the most part that is all i would worry about with a stock set-up |
#13 |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
#14 |
Member#: 151079
MAIC
Please just make sure you do your high revving when the engine is warmed up. Cold, thick oil is what destroys engines.
#15 |
Member#: 112759
MWSOC
Vehicle:02 Srp STi... R ur Boltz to long???? |
The engine only produces power to a certain rpm, anything after that is just wasting gas & creating friction
#16 |
Member#: 38474
MWSOC
Vehicle:1998 Impreza Wagon L Brilliant Red |
120K on my 98 2.2L... drag raced, Road Coarsed, Auto-x, and wangan (lots of it). i have a 4EAT and yes i shift it like a manual when driving hard.
replaced Head Gaskets (due to them being blown) at 78K miles. replaced with cometics, no problems since. transmission works just fine while on the highways doing high speed runs yes i have pinged the rev limiter a bit... but i never ride it. car revs to 6200RPM |
#17 | ||||
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
![]() Quote:
![]() Quote:
Pat Olsen |
#18 |
Member#: 151079
MAIC
#19 |
Member#: 207074
BAIC
Vehicle:2001 Impreza Outback Silver -180k and counting |
#20 |
Member#: 187936
MAIC
Vehicle:97 Legacy w12:1CR 05 LL Bean outback |
i try not not bounce of the limiter but i get very close to it every day
#21 | |
Member#: 153476
NESIC
Vehicle:2005 Forester XT Aspen White |
Also: A redline a day keeps the carbon away! ![]() There's a difference between driving spirited, which will help keep things inline, and genuinely beating on it, which will just bend crack crush and destroy your expensive toy. |
#22 |
Member#: 2272
BAIC
Vehicle:95 L AWD LIFTED!!! 1970 Subaru FF-1 Coupe |
More issues arise when a car is driven irregularly (IE not often, and not hard) than if a car is driven hard regularly.
#23 |
Member#: 120386
South East
I know I should have short shifted in my video but I was against the dreaded 89 civic and once I was in the slalom I was not shifting.
The motor that was damaged is in for a DSP build, with a higher limiter on the tune ![]() |
#24 | |
Member#: 38474
MWSOC
figured i would get a little flame for that use of word but oh well.. basically yes I-94 at about 2-3AM in the morning having a little high speed fun (though 114 limited isnt exactly high speed) the main point i am trying to make is that i have in my opinion beat the piss out of both my trans and motor and have suffered very little. though mind you i do not promote nor condone street racing and/or its lifestyle Quote to get flamed for "if they didnt want or expect me to drive over the posted speed limit they wouldnt have allowed my vehicle to do it in the first place" |
#25 | |
Member#: 134005
MAIC
I can attest to this. My car's been sitting for about 1-2 weeks. It's leaking oil kinda bad. If I drive it, it doesn't leak. It makes no sense. |
| Thread Tools | |
| Display Modes | |
| High HP high reving subarus, what oil pump & thoughts on aftermaket oil pan & baffle? | D Money | Built Motor Discussion | 66 | 05-17-2009 12:13 PM |
| high-reving built 2.0L | ImprezaRSfan! | Built Motor Discussion | 20 | 07-16-2006 12:57 AM |
| High reving Honda owners, explain something. | Rev | Off-Topic | 148 | 01-03-2006 04:36 AM |
| Is it any harmful for car to take off the front grill? | cinemaster | Interior & Exterior Modification | 24 | 02-23-2005 04:41 PM |
| Is this normal/harmful | notraceready | Factory 2.0L Turbo Powertrain | 3 | 01-23-2005 02:41 PM |
