Old 06-06-2010, 05:32 PM   #1
maruksai
Member#: 233276
2009 2.5i Hatch
Default Is High Reving Harmful?
Is it bad to redline your engine on a daily basis? How would it affect long term engine life? Will I see 150k-200k miles?
maruksai is offline   Reply With Quote
Old 06-06-2010, 05:45 PM   #2
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
IMO it doesn't hurt the engine one bit, that's what a rev limiter is for.
Subyroo2.5 is offline   Reply With Quote
Old 06-06-2010, 06:18 PM   #3
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I agree with subyroo.
chazly413 is offline   Reply With Quote
Old 06-06-2010, 06:39 PM   #4
maruksai
Member#: 233276
2009 2.5i Hatch
Is there anyone on here that has high mileage on a hard driven subie?
Old 06-06-2010, 07:03 PM   #5
2.5ReallySexy
Member#: 167943
ya rev limiter is set at a safe limit for your car. But maintainting your car is all on how often you check or change your oil and such.
2.5ReallySexy is offline   Reply With Quote
Old 06-06-2010, 07:12 PM   #6
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Engine wear - or the expected mileage out of a car is a function of mileage, nr of winters, maintenance, average RPM, peak RPM, the distribution of engine load over total engine's operating time, number of startups, minimum temperature, maximum temperature, commute distance and hours, traffic conditions, intervals between consecutive startups, quality of roads driven, altitude, elevation, air pressure, and humidity.
Add to that the impact of the driver's age, health, skill, marital status, temper, the personnality of your significant other and the number of kids. To make things worse, a lot of the aforementioned variables are mysteriously correlated with the others (a temperamental driver with a bitchy wife and screaming quadruplets might vent on the gas pedal more than a 85yo zen retired hippie).
Bottom line is that you won't get a satisfactory answer. Search the forum for mileage tales. Lot of cars driven like they've been stolen with litle problems and big mileages. Lot of stories of babied cars which kept having issues too.
Old 06-06-2010, 07:28 PM   #7
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
I had 195k when I spun a rod bearing on this run, I ride the limiter at most events
dstan is offline   Reply With Quote
Old 06-06-2010, 08:01 PM   #8
flightwatch
Member#: 231058
2013 Genesis Coupe
Awesome post
flightwatch is offline   Reply With Quote
Old 06-06-2010, 09:12 PM   #9
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
YouTube- Turner Field.AVI
Yeah dude that's a bit much.
Old 06-06-2010, 09:14 PM   #10
cmiovino
Member#: 134005
2004 WRX Premium
In general, I'd assume if you treat it right through regular maintenance and even some preventive maintenance (replacing things before they call to be replaced) you should get a good 150-200K out of a Subaru engine, or really any car. Pair that with babying it, and I think you have a good recipe for success.
Now, no maintenance and babying it... yep, gonna lead to problems. Maintenance and gunning it all the time means more maintenance, which if you're following Subaru's guidelines maybe be not enough maintenance for the driving conditions... hence why engines sometimes fail.
cmiovino is online now   Reply With Quote
Old 06-06-2010, 10:51 PM   #11
dstan
Member#: 120386
tell me when I should have gone to 3rd in the slalom, I knew something was wrong 2 runs earlier.
better to die in a parking lot than I-85 in Atlanta.
Old 06-07-2010, 07:23 PM   #12
99GTlimited
Member#: 243664
1999 Legacy GT
Quicksilver Metallic
simple rule to engines: Higher rotational speed - higher friction
treat your car accordingly, just make sure you have an adequate amount of clean (enough) oil, for the most part that is all i would worry about with a stock set-up
99GTlimited is offline   Reply With Quote
Old 06-07-2010, 09:15 PM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Yea me
Old 06-07-2010, 09:33 PM   #14
chazly413
Member#: 151079
2005 2.5RS RBP
Please just make sure you do your high revving when the engine is warmed up. Cold, thick oil is what destroys engines.
Old 06-07-2010, 09:43 PM   #15
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
The engine only produces power to a certain rpm, anything after that is just wasting gas & creating friction
Old 06-07-2010, 10:57 PM   #16
Mechkiller31st
Member#: 38474
1998 Impreza Wagon L
Brilliant Red
120K on my 98 2.2L... drag raced, Road Coarsed, Auto-x, and wangan (lots of it). i have a 4EAT and yes i shift it like a manual when driving hard.
replaced Head Gaskets (due to them being blown) at 78K miles. replaced with cometics, no problems since.
transmission works just fine
while on the highways doing high speed runs yes i have pinged the rev limiter a bit... but i never ride it.
car revs to 6200RPM
Mechkiller31st is offline   Reply With Quote
Old 06-08-2010, 09:59 AM   #17
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Well said.
As Bluefoton said, there's really no way to answer your last question; there are just too many variables. In basic terms, the answer to your first question is NO, it's not bad to redline the engine, even on a daily basis. That assumes, as others have said, that the engine is being properly maintained. With that said, extended high RPMs is hard on the engine, but I don't imagine that's what you're doing on a daily basis.
Is that some sort of JDM-tite-y0 term for street racing? Is wangan as awesome as touge?
That's not really true. You want to rev past peak HP so that when you shift and RPMs drop you maximize the average HP.
Pat Olsen
Old 06-08-2010, 10:57 AM   #18
chazly413
Member#: 151079
2005 2.5RS RBP
Urban dictionary calls it high speed runs on a highway..
Old 06-08-2010, 11:29 AM   #19
vrusso
Member#: 207074
2015 STI
You know you're jealous
160k Redlined daily. Runs Great!
vrusso is offline   Reply With Quote
Old 06-08-2010, 12:01 PM   #20
grafton
Member#: 187936
07 WRB STi
i try not not bounce of the limiter but i get very close to it every day
grafton is offline   Reply With Quote
Old 06-08-2010, 12:09 PM   #21
JazzyJake
Member#: 153476
2005 VF39 6spd FXT
Take note.
Also: A redline a day keeps the carbon away!
There's a difference between driving spirited, which will help keep things inline, and genuinely beating on it, which will just bend crack crush and destroy your expensive toy.
JazzyJake is offline   Reply With Quote
Old 06-08-2010, 10:22 PM   #22
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
More issues arise when a car is driven irregularly (IE not often, and not hard) than if a car is driven hard regularly.
Old 06-08-2010, 10:32 PM   #23
dstan
Member#: 120386
I know I should have short shifted in my video but I was against the dreaded 89 civic and once I was in the slalom I was not shifting.
The motor that was damaged is in for a DSP build, with a higher limiter on the tune
Old 06-08-2010, 10:55 PM   #24
Mechkiller31st
Member#: 38474
Brilliant Red
Pat Olsen
figured i would get a little flame for that use of word but oh well.. basically yes I-94 at about 2-3AM in the morning having a little high speed fun (though 114 limited isnt exactly high speed)
the main point i am trying to make is that i have in my opinion beat the piss out of both my trans and motor and have suffered very little. though mind you i do not promote nor condone street racing and/or its lifestyle
Quote to get flamed for
"if they didnt want or expect me to drive over the posted speed limit they wouldnt have allowed my vehicle to do it in the first place"
Old 06-08-2010, 11:13 PM   #25
cmiovino
Member#: 134005
2004 WRX Premium
I can attest to this. My car's been sitting for about 1-2 weeks. It's leaking oil kinda bad. If I drive it, it doesn't leak. It makes no sense.
High HP high reving subarus, what oil pump & thoughts on aftermaket oil pan & baffle? D Money Built Motor Discussion 66 05-17-2009 12:13 PM
high-reving built 2.0L ImprezaRSfan! Built Motor Discussion 20 07-16-2006 12:57 AM
High reving Honda owners, explain something. Rev Off-Topic 148 01-03-2006 04:36 AM
Is it any harmful for car to take off the front grill? cinemaster Interior & Exterior Modification 24 02-23-2005 04:41 PM
Is this normal/harmful notraceready Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-23-2005 02:41 PM
