Welcome to the North American Subaru Impreza Owners Club Thursday September 9, 2010
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 03-09-2010, 03:02 PM   #1
SubieNeeks21
Member#: 178661
04 PSM WRX VF43'ed
Bren Tuned
Default 04 wrx won't start
I drive an 04 wrx and last night driving normally i put it into second gear and it just cut out like a fuel cut or something.
I swapped the stock fuel pump back in because i couldn't hear my walbro 255 pump running. I know i have 3/4 of a tank but the gauge reads empty.
Should i get a new fuel pump relay?? anyone have any idea of what this might be???
Mods i know this is a double post but i always seem to get a quicker response posting it up in nesic, please let this fly. thanks
SubieNeeks21 is offline   Reply With Quote
Old 03-09-2010, 04:12 PM   #2
downest
Member#: 194343
1990 Honda CRX B18C1
Rio Red Fade
Sounds like you messed up the float thing when you put the stock pump back in, pull it back out and check if it's bent or stuck on something. Was the Walbro dead? Sometimes the clip doesn't seat all the way down, even though it feels like it does, you could always bench test it real quick to see if it's working.
downest is offline   Reply With Quote
Old 03-09-2010, 04:17 PM   #3
SubieNeeks21
Member#: 178661
04 PSM WRX VF43'ed
Bren Tuned
ill pull the pump back out and check it. Im guessing it wasn't dead since i swapped the stock one in and that didn't work either (it worked fine when i took it out of the car). how can i bench test the walbro? its only about 5 months old..
Old 03-09-2010, 07:21 PM   #4
wit2003
Member#: 104395
2000 Escalade/04 WRX
Wagon/87 Monte Carlo SS
View Member's Myspace Profile
when was the last time you replaced your fuel filter? on the 04 its cheap enough to get a new one and try
wit2003 is offline   Reply With Quote
Old 03-09-2010, 08:34 PM   #5
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
Assuming that you have no CELs and that the car is turning over when you turn the key to start then you probably do have a fuel problem.
If I were a betting man I would say that the internal filter above the fuel pump has lost it's O ring. Remove the pump housing again, check the half plastic-half yellow zinc barrel above the pump. If you can see any O ring that has breached from it's groove your fuel pump is just working hard to pump fuel from the tank, back into the tank through the burst O ring.
We just saw this yesterday for the second time. Seems like a problem that we'll see more of.
Let us know if that helps.
DSG-
dentsport is offline   Reply With Quote
Old 03-09-2010, 09:21 PM   #6
Craig A.
Member#: 122519
2004 Super 16g'd WRX
DSG, the 04 has the fuel filter in the engine bay, not the tank. Is there an additional one in the tank on my car?
Craig A. is offline   Reply With Quote
Old 03-09-2010, 10:24 PM   #7
Wookie768
Member#: 90055
2005 WRX
that happend with my car but it was the utec that caused it to die out like that and then wouldnt start, i swaped fuel pumps and still wouldnt start till i put the stock ecu on
Wookie768 is offline   Reply With Quote
Old 03-09-2010, 11:04 PM   #8
wit2003
Member#: 104395
DSG-
that was my car Thanks again guys.
Old 03-09-2010, 11:37 PM   #9
SubieNeeks21
Member#: 178661
04 PSM WRX VF43'ed
Bren Tuned
there is a filter in the tank, attached to the pump..
thanks guys, i got it running.
I disconnected all the connectors, relay, and fuel pump controller and also
made sure all my grounds were good. Put it back together and it turned rite over.
Must have been a loose connection or a bad ground.
Old 03-10-2010, 05:50 AM   #10
Craig A.
Member#: 122519
Ya learn something new every day. Thanks for the added knowledge.
Old 03-10-2010, 12:29 PM   #11
bren wrx
Member#: 59454
E46 M3/E36 M3/RC51
tuning subies in MA
bren wrx is offline   Reply With Quote
Old 06-10-2010, 12:33 PM   #12
96accord
Member#: 145105
How many grounds did ya check? Can ya let me know which ones?
-Jeff
Old 06-10-2010, 05:51 PM   #13
nhmtns
Member#: 94283
'05 OBXT - Stage 2
Min bil är svart
This happened to my '06 WRX a few years back. I was in the middle of nowhere on a back road in Maine and it just shut off. Flagged down a truck and got a ride to a "repair shop" that got it to work again. The guy said he found an O ring from a snowmobile that fit. Don't know how long it lasted because I traded the car in a week later.
nhmtns is offline   Reply With Quote
Bookmarks
04 WRX won't start/ rough idle MARKSTIV8 Factory 2.0L Turbo Powertrain 8 05-05-2010 07:24 PM
04 WRX won't start; fuel pump won't stop priming styng88 Factory 2.0L Turbo Powertrain 20 09-19-2008 09:12 PM
Help please- WRX won't start Brewmaster Factory 2.0L Turbo Powertrain 2 06-14-2002 08:48 PM
WRX won't start Dandand Factory 2.0L Turbo Powertrain 17 08-06-2001 10:37 PM
Message Board Statistics All times are GMT -4. The time now is 03:37 AM.
