Old 06-09-2010, 09:24 PM   #26
liljon350
Member#: 197068
2006 WRX evo316g'd
WRB 293whp/322tq 12.8@108
I got tuned at precision by cleo as well
http://forums.nasioc.com/forums/show...hlight=evo316g
liljon350 is offline   Reply With Quote
Old 06-09-2010, 09:28 PM   #27
Clark Turner
Member#: 178047
02 WRX STI Spec C
This turbo makes 270 to 300whp with good exhaust, Intercooler and intake. If you get higher, Its simply the dyno reading in comparison to another dyno. On 100 octane, I can get an easy 310 to 340whp depending on mods and if I can get the boost up to 25.
After that.. The turbo is done. The great benifit of this turbo is the cost, Its power on pump gas in comparison to the VFs and they spool really fast.
Clark
Old 06-09-2010, 11:26 PM   #28
downpipe12
Member#: 212666
2002 WRX Wagon,
Black, EVOIII16G+Meth
I've been reading up on pre-turbo water injection on some various websites, especially the aquamist forum, where one member in particular has used it with great success. the main benefit seems to be in cases where a particular turbo is really maxed out, because the effects of pre-turbo injection essentially change the compressor map.
i realize there are challenges and difficulties with this...namely proper atomization and compressor erosion. but I can't help but wonder...
has anyone here used this with a maxed out evo3 16g?
and clark, have you tuned any pre turbo water/meth injection setups?
downpipe12 is offline   Reply With Quote
Old 06-09-2010, 11:34 PM   #29
Clark Turner
Member#: 178047
02 WRX STI Spec C
Every once in a while a guy comes to me with the water/meth kit plumbed like that. I never really saw any benifit to it. The spray needs to go to the combustion chambers to be effective.
C
Old 06-09-2010, 11:58 PM   #30
downpipe12
Member#: 212666
2002 WRX Wagon,
interesting.
i think the two main benefits, in theory, would be
1) an essentially boost-dependent progressive pumpless system.
2) cooling the actual turbo itself, which is said to affect the compressor map.
yet it is hard to find actually studies where anyone compares pre, post, and both. there are so many variables to consider.
Old 06-10-2010, 12:08 PM   #31
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
'91 EJ22T shortblock (STOCK)
'03 WRX heads + intake manifold; D-style ported heads & TGV deletes
'02 WRX ECU/harness MERGED via ECS
modded stock injectors; 820-830cc, Walbro 255 FP
Perrin crank pulley
Perrin BIG MAF
Gimmick turbo inlet
ebay TMIC; port matched y-pipe inlets
Greddy Type RS BOV
SBR/Kinetic Motorsports EVO3-16G-8cm IWG turbo; GM BCS@20psi
SSAC/XSPower 4-1 headers w/ modded uppipe; no flex
x3racing bellmouth DP & SPT catback
Mishimoto Radiator
Crucial Racing 160* thermostat
Dyno pull via 4th gear on JDM 6spd. We fixed the boost spike later. Just lessened the WDC some before peak.
Old 06-10-2010, 07:02 PM   #32
jonpark
Member#: 141449
2007 EvoIII16g WRX
UGM EJ257+05/6speed
Oooooh~ I got the most hp!!!
jonpark is offline   Reply With Quote
Old 06-10-2010, 07:16 PM   #33
SVT_WRX
Member#: 164830
G61 III OVE 58e
^^^^What? You're kidding...right?
SVT_WRX is offline   Reply With Quote
Old 06-10-2010, 07:25 PM   #34
under0athh51189
Member#: 193959
2002 Wrx Wrb wagon
05 Wrx AW 18x10 WFC#295
^^i would just like to point out jonpark that if it wasnt for your 2.5L and the fact that you have AEM alcohol injection set at 10psi then my car at 329whp and 311wtq would have you beat, sorry to burst you bubble. i might even come close when i go back to siegel for a retune with my tial 38mm ewg and do a race gas tune
under0athh51189 is offline   Reply With Quote
Old 06-10-2010, 08:00 PM   #35
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I can get my EVO3-16G-8cm back and do a run on the DynoJet we have in town to make more power on E85!!! lol
Old 06-10-2010, 08:03 PM   #36
SVT_WRX
Member#: 164830
G61 III OVE 58e
I think you mean you have the highest reading dyno sheet. You are not making the most real hp.
Old 06-10-2010, 08:47 PM   #37
Clark Turner
Member#: 178047
02 WRX STI Spec C
It does not matter who has the most actual power.. Dont you realize that? What matters is what that dyno sheet says.. This is why shops crank the dyno up... It sells parts and makes customers happy!
C
Old 06-10-2010, 09:56 PM   #38
under0athh51189
Member#: 193959
2002 Wrx Wrb wagon
^haha exactly
Old 06-10-2010, 11:17 PM   #39
SVT_WRX
Member#: 164830
G61 III OVE 58e
This is just one of several reasons why I created the Airboy/Trap speed/Weight thread. So that enthusiasts that can't afford to go to a chassis dyno all the time can set a goal, look at the results, and tune away to reach that goal. Help the community...not hurt it...that's my motto.
What would really be cool if we had all of these somewhere handy:
Dynojet/Trap Speed/Weight
Dyno Dynamics/Trap Speed/Weight
Dynapak/Trap Speed/Weight
Mustangdyne/Trap Speed/Weight
Yeah!
Old 06-10-2010, 11:56 PM   #40
Clark Turner
Member#: 178047
02 WRX STI Spec C
Yeah.. I agree.. In my profession its a real bitch.. A guy comes to me expecting 350whp on a STG2 STI that in reality makes 275 on pump gas. Even though his car is running 20 psi, Full timing and perfect AFR, He still thinks he is way down on power
C
Old 06-11-2010, 12:53 AM   #41
jonpark
Member#: 141449
2007 EvoIII16g WRX
UGM EJ257+05/6speed
That's cold...
Old 06-11-2010, 12:56 AM   #42
jonpark
Member#: 141449
2007 EvoIII16g WRX
UGM EJ257+05/6speed
Originally Posted by SVT_WRX View Post
This is just one of several reasons why I created the Airboy/Trap speed/Weight post. So that enthusiasts that can't afford to go to a chassis dyno all the time can set a goal, look at the results, and tune away to reach that goal. Help the community...not hurt it...that's my motto.
Yeah!
++++++++++++1
Old 06-11-2010, 01:01 AM   #43
Clark Turner
Member#: 178047
02 WRX STI Spec C
Only if the dyno is turned up
C
Old 06-11-2010, 03:02 PM   #44
p19124
Member#: 130303
2004 wrx
psm
p19124 is offline   Reply With Quote
Old 06-11-2010, 04:30 PM   #45
jonpark
Member#: 141449
2007 EvoIII16g WRX
UGM EJ257+05/6speed
Very Nice 4eat!!!
Old 06-12-2010, 11:05 PM   #46
wrspeed
Member#: 40110
04 STI
131 MPH 4th gear Madness
here we go again with the dyno wars.....we do not mess with our dyno so it can read higher ,in fact look around here do a search and you will find that we address this 2 or 3 times before, we even posted a graph from a dyno dynamic that was said to read 50 to 75whp less than ours that go shock at the results we even had people that got tune on mustangs dynos that where told that it will make way more power on our HI reading dyno and got their dreams shoot down, but hey if whatever lest you guys sleep at night is fair game...... RIGHT?
proven results:
415whp goes 11.5@125mph
480whp goes 10.85@130mph
way too much finger racing and not enough actual facts
wrspeed is offline   Reply With Quote
Old 06-13-2010, 12:45 AM   #47
SVT_WRX
Member#: 164830
G61 III OVE 58e
proven results:
I don't think anybody said anything about fussing with a dyno to make it read higher....you specifically.
Furthermore, if there aren't enough actual facts, why don't you help out and start posting them. Perhaps create a thread like my Airboy/Trap Speed thread and call it Dynojet/Trap Speed. Yes?
Old 06-13-2010, 12:48 AM   #48
Clark Turner
Member#: 178047
02 WRX STI Spec C
what ever sells parts and gets the biz!
Old 06-13-2010, 01:00 AM   #49
SVT_WRX
Member#: 164830
G61 III OVE 58e
There has to be more EVO 16G results out there....where are they
Old 06-13-2010, 01:05 AM   #50
p19124
Member#: 130303
2004 wrx
psm
if i get retuned with meth dose that count as 2 lol
Poll: Shoulld All Posters To This Forum Be Obliged To Post Uncorrected Dyno Results ? macaws Proven Power Bragging 49 04-13-2008 12:16 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
Injen Posted dyno results for their CAI run on a 2004 WRX trustWRX Factory 2.0L Turbo Powertrain 73 01-24-2004 05:07 AM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain 0 11-10-2001 05:40 PM
Message Board Statistics All times are GMT -4. The time now is 02:03 AM.
