Old 06-10-2010, 02:09 AM   #1
kcpaz
Member#: 194611
1998 Legacy GT
Mexico Blue (not red)
Default Fuel Line Question. '98 LGT w/EJ205 swap
Okay, sorry if this is a newbie question, but I have been searching for an hour and haven't found the answer.
I'm trying to verify that I hooked up the fuel lines properly, and the pictures that I took for reference aren't helping me. Can someone confirm which line goes to which between the chassis hard lines, and the engine hard lines. I know the top two on the engine are feed/return, and the bottom is EVAP, but I'm not sure which is which for the feed/return. As far as the chassis side, I have no idea but I "think" the top is EVAP, and the bottom two are feed/return. Can someone who has done a swap in this car help?
kcpaz is offline   Reply With Quote
Old 06-10-2010, 01:33 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
follow the line, it should feed into the fuel rail. if it does start, swap the around; you only have two lines to deal with.
FuJi K is online now   Reply With Quote
Old 06-10-2010, 02:56 PM   #3
kcpaz
Member#: 194611
1998 Legacy GT
are the chassis lines on the Legacy the same as the WRX? Basically what I need to know is which chassis hard line is the EVAP line on the Legacy?
Old 06-10-2010, 03:07 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
chassis, as in where they are mounted on the strut tower?
if so yes.
Feed=middle line
Return=top line
evap=dinky little bottom line
just follow the lines to the fuel filter.
Old 06-10-2010, 04:29 PM   #5
kcpaz
Member#: 194611
1998 Legacy GT
Yes, the lines behind the shock tower. According to the pictures I took of the WRX chassis lines, the bottom line (black) goes to the fuel filter, then from the fuel filter to the top line on the engine. The top line (grey) on the chassis goes to the middle line on the engine, which means the middle line on the chassis (blue) is for the EVAP system.
Here are the pictures I took of both cars before I started anything. The hard lines on both chassis are colored the same way, so I would think they would hook up the same way, but I want to make sure before I start pumping fuel into the charcoal canister
Old 06-10-2010, 04:33 PM   #6
kcpaz
Member#: 194611
1998 Legacy GT
his is how I have it hooked up right now, and from what I can tell in my old pictures, it's the same as the WRX.
Old 06-11-2010, 02:08 PM   #7
kcpaz
Member#: 194611
1998 Legacy GT
can anyone verify that I got this right?
Old 06-11-2010, 03:44 PM   #8
kakarotoni
Member#: 156240
02 WRX
06 Impreza
yes its right, just start the car up already. You wont hurt it if its wrong, it just wont start. But it looks correct. Always label lines in correct order with a piece of masking tape and a marker so you dont have to run into this problem again.
kakarotoni is offline   Reply With Quote
Old 06-11-2010, 05:00 PM   #9
kcpaz
Member#: 194611
1998 Legacy GT
Thanks, and yes, next time, I will be sure to take better pictures so it's clear.
Quick fuel lines question devil13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-12-2006 11:03 PM
Fuel line question LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-24-2006 05:50 PM
What would you pay for a '98 LGT w/wrx Swap and broken Tranny? sleepy98 Subaru Conversions 18 11-08-2005 10:06 AM
Evaporation Line/ Fuel Line questions Mnstr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-13-2002 03:17 PM
Fuel line question Aspen Normally Aspirated Powertrain 2 02-01-2001 12:55 AM
