Old 06-13-2010, 07:01 PM   #1
gonzo1
Member#: 243589
2005 Impreza WRX
Default I want 300hp from a 05 wrx 2.0
I just purchased a 05 wrx 2.0. Has a cold air intake, hks bov, and 3" exhaust, added some hp. What upgrades can I do to get it up to 300hp?Any links? From minor to major upgrades so I can move along on this project and decide. Thanx
gonzo1 is offline   Reply With Quote
Old 06-13-2010, 07:03 PM   #2
xEionx
Member#: 192474
1995 s14 zenki
black
a tune should help.
xEionx is offline   Reply With Quote
Old 06-13-2010, 07:05 PM   #3
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
16g or 18g with supporting mods and a tune
Brother EddieJ. is offline   Reply With Quote
Old 06-13-2010, 07:05 PM   #4
ShaneInHisRoom
Member#: 148737
If you want 300 to the crank, that's fairly simple. What you have if it's Stage 2 is about 300CHP after you tune for it. If you want 300WHP, you'd want a bigger turbo, injectors, and fuel pump.
ShaneInHisRoom is offline   Reply With Quote
Old 06-13-2010, 07:07 PM   #5
Subr-man
Member#: 169211
into a gearhead."
Goin' Back Old Skool
injectors, larger top mount, vf39 turbo, upgraded fuel pump, a tune, and get rid of the BOV you will actually improve on perfromance if you do
Subr-man is offline   Reply With Quote
Old 06-13-2010, 07:13 PM   #6
Brother EddieJ.
Member#: 181617
2004 wrx
read this: http://forums.nasioc.com/forums/show....php?t=1602235
Old 06-13-2010, 07:28 PM   #7
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
300 whp or 300 hp? All the mod recommendations in this thread so far are completely meaningless without know which you want.
Byzantium is offline   Reply With Quote
Old 06-13-2010, 07:49 PM   #8
gonzo1
Member#: 243589
2005 Impreza WRX
300hp. What does everyone think about the Cobb stage1? STI injectors ok for upgarade, plug and play? Walbro fuel pump? To get it tuned just any dyno shop will do? And what does flash ecu mean, tune? If not can we flash ecu ourselves? Thanx guys
Old 06-13-2010, 07:59 PM   #9
Byzantium
Member#: 207826
85k 2002 WRX
Well, my advice is: Stop trying to spend money and start researching. Do so for several months without spending a dime. To be honest at your stage you are asking for a train wreck.
Old 06-13-2010, 08:03 PM   #10
crash60068
Member#: 209218
2005 WRB WRX 4EAT
93 MR2, 2008 Yaris
yea you can flash it yourself. since we have the same cars just do that setup and then youl be at 300hp but not at the wheels
crash60068 is offline   Reply With Quote
Old 06-13-2010, 08:07 PM   #11
HSBabyFace
Member#: 130204
14 JKUR
What he said
HSBabyFace is offline   Reply With Quote
Old 06-13-2010, 08:09 PM   #12
kevosnowsti
Member#: 202097
2001 Subaru 2.5rs
BRP
No, no he will not get 300bhp from stage 1.
kevosnowsti is offline   Reply With Quote
Old 06-13-2010, 08:11 PM   #13
sanremo_russ
Member#: 56465
2004 WRX - VF34
SRR
I would go talk to your local tuner and see what he recommends...
sanremo_russ is offline   Reply With Quote
Old 06-13-2010, 08:12 PM   #14
Brother EddieJ.
Member#: 181617
2004 wrx
stage 1 265 crank
stage 2 285 crank according to cobbs OTS map. custom tune, no idea
Old 06-13-2010, 08:23 PM   #15
crash60068
Member#: 209218
2005 WRB WRX 4EAT
93 MR2, 2008 Yaris
sorry il rephrase then NOT a stage 1. i meant a stage 2 plus an UP and/or a few other small mods then you will be right around that 300bhp
Old 06-13-2010, 08:31 PM   #16
MrBlue
Member#: 34978
2006 WRX
Gray
Stickers... lots and lots of stickers.
MrBlue is offline   Reply With Quote
Old 06-13-2010, 08:52 PM   #17
gonzo1
Member#: 243589
2005 Impreza WRX
Byzatium! That's why people come here right?! To get advice from enthusist that have been thru this process "experience". Im grateful for you advice but I'm sure there has been others that have been thru this and have done it. Thanx crash I know what u meant. Well I'm going to look into it more. Cobb Stage 2 upgrade looks good. Anyone think it's not the right way? Should I just vf39, sti inj, fuel pump, sti intercooler, sound better? Will a different stage clutch make a difference? Thanx
Old 06-13-2010, 08:59 PM   #18
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Cobb tune sucks.
Jubert69 is offline   Reply With Quote
Old 06-13-2010, 09:06 PM   #19
Subr-man
Member#: 169211
into a gearhead."
Originally Posted by Brother EddieJ. View Post
I am assuming you are telling the OP to read it and not me?
11. So if I am making the same boost pressure, why does it matter if its leaking a little?
--Because even if you are hitting target boost, your turbo is having to work harder to get there. A harder working turbo produces a hotter air charge, as its higher in its efficiency range (or worse, completely out of it). This means less dense, which will produce less energy when ignited. This also means higher chance of detonation, which even if its very light, will result in your ECU pulling timing. Also bad. Lastly, hotter air in=hotter air out. Higher EGTs. Even if only slightly. = less performance!
Old 06-13-2010, 09:08 PM   #20
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
You still haven't said if you want 300 CRANK hp, or 300 WHEEL hp.
No, STi pinks are not "plug and play."
FOR 300 CRANK HP:
Catless up-pipe, catless turbo-back exhaust, ECU tune
FOR 300 WHEEL HP (stretching):
Catless up-pipe, catless turbo-back exhaust, VF30/34/39 turbo, STi "pink" injectors, STi (or larger) TMIC, Walbro pump, ECU tune
FOR 300 WHEEL HP (easy 300):
Catless up-pipe, catless turbo-back exhaust, EVO316G, 650cc injectors, STi (or larger) TMIC, Walbro pump, ECU tune.
To answer your inevitable question: No. A generic turbo from eBay is NOT a good idea.
General advice: No one likes loud BOVs anymore. It isn't 1999.
CKxx is offline   Reply With Quote
Old 06-13-2010, 09:19 PM   #21
wrx_evo_jetta
Member#: 70283
FOR 300 CRANK HP:
Catless up-pipe, catless turbo-back exhaust, VF30/34/39 turbo, STi "pink" injectors, Walbro pump, ECU tune
Catless up-pipe, catless turbo-back exhaust, EVO316G, 650cc injectors, Walbro pump, ECU tune.
But there is a new Fast and the Furious movie coming out man!!!
wrx_evo_jetta is offline   Reply With Quote
Old 06-13-2010, 09:29 PM   #22
gonzo1
Member#: 243589
2005 Impreza WRX
Thanx guys for the advice. I want 300whp, sorry. That sounds great ckxx. Looking at the stretching. Do you recommend more air like sti intercooler or differEnt? Or is stock ok with cold air intake? How would I get STI injectors to plug?
Old 06-13-2010, 09:30 PM   #23
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
One thing to add to 300whp (stretching): bigger TMIC or FMIC
Old 06-13-2010, 09:32 PM   #24
gonzo1
Member#: 243589
2005 Impreza WRX
Great wrx-evo-jetta! When does it come out and more drifting?
Old 06-13-2010, 09:35 PM   #25
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I suggest you spend 30 min browsing around 2.0L technical section for more information. Read Unabomber's FAQ section.
either pink JDM top feed injectors or 06-07 WRX injectors are direct bolt on (flow about 555cc).
05 wrx 2.0 conv. to 06 wrx 2.5 Questions??? LT_DAN0690 Subaru Conversions 3 07-05-2009 01:19 PM
Fs: (Nc) Cobb Acessport V.2 for 02 - 05 wrx 2.0 (In Box) Kingdlee Engine/Power/Exhaust 10 04-27-2008 01:35 PM
V2 Accessport for 02-05 WRX 2.0 (2 weeks old) Drink Engine/Power/Exhaust 3 02-19-2007 01:39 PM
Advice on next mod??? Help from Local Seattle WRX 2.0 owners!! dhalley North West Impreza Club Forum -- NWIC 20 08-29-2006 11:49 AM
Is EM upgrade or utec need for Uppipe on 05 WRX 2.0 l Boosto Newbies & FAQs 2 08-02-2005 11:57 AM
