Old 06-15-2010, 11:31 AM   #1
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
Default Is oil on spark plug boots normal?
This is the third time I have changed my plugs and I noticed a bit of oil in the spark plug hole. The plug boot seems to be sealing it away from dripping down into the plug itself, however, I don't remember this much oil the last two times I changed plugs.
I have not noticed any symptoms of burning or loss of oil, or any change in performance of the motor in general. I have seen pics other's engines and it looks like there may be oil there too, but I can't really tell.
Is this just a side-effect of having a flat-4 engine?
mslstixx is offline   Reply With Quote
Old 06-15-2010, 03:02 PM   #2
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
time to replace the valve cover and spark plug gaskets.
Very easy to do youself
http://www.rs25.com/forums/f105/t512...t-install.html
dstan is offline   Reply With Quote
Old 06-15-2010, 05:07 PM   #3
o'doyle
Member#: 246566
2004 2.5ts
dstan nailed it. when you redo your valve cover gaskets, take care that you get the little rubber o-rings seated properly, or you'll have to do it all over again. Lesson learned on my old Accord. I'd HATE to have to do this twice on my subie--since you already have to do it twice
While you're in there, it might be a good time to check/adjust valve lash... Just a thought.
Last edited by o'doyle; 06-15-2010 at 05:08 PM. Reason: meh, check lash while you're there...
o'doyle is offline   Reply With Quote
Old 06-15-2010, 05:12 PM   #4
o'doyle
Member#: 246566
2004 2.5ts
Originally Posted by dstan View Post
Actually, now that I've had a look, this is *way* easier than the Accord's plug gaskets were. Those were very thin & perfectly rounded rings that fit in a teeny rubber channelóbadly. I'd do these all day in my Impreza before ever dealing with that again on an old Accord.
Old 06-15-2010, 09:50 PM   #5
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
Upon researching, valve cover gasket makes a lot of sense. I didn't realize that there was also a spark plug gasket, so thanks!
This looks pretty easy to do, thanks for the link dstan!
Old 06-16-2010, 12:06 PM   #6
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
Got the valve cover and spark plug gaskets at the dealership, but they say there are no rocker cover washers for a MY06 2.5i. Hopefully the rest of the writeup on rs25 is accurate to my model year.
Old 06-16-2010, 04:41 PM   #7
dstan
Member#: 120386
I am pretty sure yours are built in
Old 06-19-2010, 01:52 PM   #8
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
Thanks again for the help, guys! On my 2.5i there are in fact no rocker cover washers, because the bolts are outside the gasket, thus there is no need for them.
Getting everything out was pretty easy, but I ended up having to remove the fuel rail guard to get the valve cover back in. Otherwise it was a straightforward process. Cost about $65 in parts total (from the dealership).
Old 06-19-2010, 05:33 PM   #9
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Just to let you know, Rockauto has a little kit with valve cover gaskets, spark plug gaskets, and the little rubber grommets that go into the bolts holes. Got it for something like $30 shipped. Quality Felpro gaskets. I would highly recommend.
T Wrex--OH is offline   Reply With Quote
Old 06-19-2010, 06:05 PM   #10
razrielle
Member#: 205698
Im surprised the torque is so low on those things
razrielle is offline   Reply With Quote
Old 06-19-2010, 07:12 PM   #11
o'doyle
Member#: 246566
2004 2.5ts
...just enough to squish the gasket & make it do its job
Old 06-20-2010, 11:11 AM   #12
BangR
Member#: 167558
1998 Forester
black
Is there spark plug gaskets on a MY 01 EJ25 SOHC?
BangR is offline   Reply With Quote
Old 06-20-2010, 08:18 PM   #13
dstan
Member#: 120386
umm yes
Old 06-21-2010, 02:12 AM   #14
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Had the same problem on my '06 2.5i and had it covered by warranty....just before it ran out
semaj is offline   Reply With Quote
Old 06-21-2010, 09:36 PM   #15
BangR
Member#: 167558
1998 Forester
black
umm yes
Let me clarify, I know there are the funnel shaped boots on top, but there is nothing that goes in between the plug and the head is there?
Old 06-26-2010, 11:24 AM   #16
doser
Member#: 174046
I just saw the same thing today. I took the plug boots off to see if there was water in them. Instead I found oil. It was just at the top of the boot. There was enough there to drip.
I was looking in the first place because the car(2004 Impreza) just went through a flooded street, and now it does not run. It turns over, and will run for small bits of time, but acts like a cylinder isn't firing. If I put it in gear it dies.
doser is offline   Reply With Quote
Found oil on spark plug wires rubberman Service & Maintenance 6 10-25-2011 02:38 PM
Oil on spark plug boots - WTF? poison Normally Aspirated Powertrain 14 03-16-2008 03:54 PM
Oil on spark plug boots (even after new valve cover gaskets) FujiHeavyFreak Service & Maintenance 2 08-14-2005 12:30 PM
help oil on spark plug wires and scoobie Normally Aspirated Powertrain 6 04-11-2005 10:27 PM
Oil on spark plug wires normal HighTachPrez Normally Aspirated Powertrain 1 05-21-2003 02:36 AM
