Old 06-14-2010, 07:51 PM   #1
meathooker
Member#: 211820
2005 sti
Default 04 fxt to gc sedan
my wife wrecked our fxt so i was thinking about having a little fun (or headache) and doing a swap for a rally car.
i like the gc sedan (redundant?) ... has this been done?
are do i need to stick with a 95+ so i have obd2 or ????
any help/advice/warnings would be appreciated!
thanks!
meathooker is offline   Reply With Quote
Old 06-15-2010, 09:41 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
could go either way
A: 96 or newer, testing will be via odb-2 only no sniffer so you CAN (some times they look for the cat) get away with out a cat all together
B: 95 or older no plug in required but the sniffer will be so if you want to run catless you end up swapping exhausts once every two years to pass (it only takes 3-4 hrs total) .. but this allows you to run a standalone ecu
what your swapping from-to is of little consequence
only thing i can think of is that you will may need to swap the gas tanks to keep the ecu happy
warning-a 2.5 into a GC puts you squarely into unlimited class which should be called "unlimited costs class"
have you thought about a basket case 98 forester instead of a GC
keep me in the loop i can help a lot and i am local
Old 06-15-2010, 04:28 PM   #3
meathooker
Member#: 211820
2005 sti
Originally Posted by Jaxx View Post
could go either way
would the 2.0 wrx motor be better for classing? i'm borrowing a dsm caged "rally" car from a buddy now and i dont think i could go with a na car at this point...
my fam has a cabin in valley county so i could get it registered up there ... should negate the emission issue correct? if so, what would be the easiest for wiring?
thanks for the info, and i will be bugging the hell out of you for questions!
are you the guy with the green wagon that lives s of nampa?
Old 06-15-2010, 04:53 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
don't know for sure what the rules allow on that .. maybe
if your doing a rally car vs a daily or show car they are both pretty easy, making it pretty is the hard part
nope i have the flat black sedan that spends most of its time hiding under a cover
Cant get Vag-com cable to flash my 04 FXT andy87t2 Open Source Reflashes 6 06-13-2009 12:35 AM
Question about how much MT oil to add to my 04 FXT stockdad Transmission (AT/MT) & Driveline 4 09-20-2007 04:31 PM
WTB: NC Short Shifter to fit 04 FXT lowell787 Private 'Wanted' Classifieds 0 07-08-2007 02:02 PM
FS MA: White GC Sedan Door/Pass STM GC Fender/Front diff/RS Steering wheel/Endlinks Aphex28 Private 'For Sale' Classifieds 15 06-28-2006 02:12 PM
FXT swaps in to GC/GM/GF -- threads/pics/stories? Siper2 Subaru Conversions 43 07-25-2005 01:30 PM
