Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 05-31-2010, 08:02 PM   #1
kingsubi
Member Sales Rating: (59)
Member#: 19239
With some new things on the horizon I am parting out my time attack build. I have listed prices beside items but all are obo and combined items will get a discount.
Located in Las Vegas, NV.
I will be adding gear as I find it... Prices do not include shipping! Everything listed is for sale - things shown but not listed are not for sale!
PM or post here for more info on condition, picture, etc. Items can fit 93-07 impreza unless indicated.
http://s61.photobucket.com/albums/h58/jsking_555/RSLRA/
Car is sold
OEM parts (modified parts list below):
Aftermarket/Mod. parts (also listed elsewhere)
Interior:
Suspension:
Drivetrain:
Engine:
Exterior:
vvvvvvvvvvvvv SOLD vvvvvvvvvvvv
400 - 1000cc UR top feed injectors with sidefeed conversion fuel rails, low impedance
200 - fuel lines and fittings (-6) for parallel fuel setup with inline fillter.
$5 - Accordion shifter boot
100 - SARD FPR
$50 - Rear jdm beam, 93-01
300 - STI Triple pillow lateral links
060 - Cusco front strut bar, 93-01
100 - Forge atm bov
300 - R180 rear 4.44 R&P and case.
220 - Cusco Engine and Transmission mounts, 5spd
90 - APR GT-II rear spoiler
1000 -EJ205 heads with BC valvetrain and BC 280/280 cams, freshly rebuilt and resurfaced.
$280 - TypeRA Roof vent - 93-01, no interior trim
600 - R180 Cusco Rear LSD diff
090 - Defi-Link 52mm Electronic Boost Gauge
120 - Defi-Link 52mm Electronic Oil Tem. Gauge
140 - Defi-Link 60mm Electronic Oil Pressure Gauge
1500 -Type RA 4.44 5 spd transmission
130 - Defi-Link 52mm Electronic EGT Gauge
150 - Defi-Link 52mm Electronic Fuel Pressure Gauge
170 - Defi-Link 115mm Electronic Tachometer
070 - Defi control unit ver.1
600 - Full Defi set
050 - 6 gauge center holder
250 - Rear sti 5x100 hubs with ARP extended studs
600 - Rear brembos with rotors (5x100) and DS2500 pads
050 - Cusco rear diff brace, 93-01
450 - Sparco Pro2000 driver's Seat - small tear on side from belt, come with slider & bracket
050 - Projector headlights
030 - Blacked out clear corners
170 - Front sti 5x100 hubs with extended ARP studs
175 - Sparco Steering wheel (blue) with adapter
400 - Zerosports reverse cowl fiberglass hood with hood pins, 98-01
900 - Q-Rack 11.5:1 Quick Steering Rack, 93-01
2200 -Prodrive Alcon calipers with Hawk DTC-60 & Prodrive rotors, very low miles
150 - GT-Spec Rear Ladder brace, 93-01
250 - STi alloy control arms, 93-01, or GD wago
100 - Version IV bumper (modified) with lightweight beam, 93-01n
350 - Watanabe RWD center differential, ph1 center diff (<98), comes with front axle stubs.
900 - Advan TCII 17 x 8.5 gold rims, 5x100, in relatively rough shape but true. - PENDING -
160 - Ganador Mirrors, 93-01
900 - FP Green 3” 8cm, internally gated Turbo,
160 - Whiteline heavy duty adjustable -race- 27mm front swaybar, BSF33XXZ
140 - Whiteline heavy-duty adjustable 24mm rear swaybar, BSR36XZ
080 - Whiteline heavy-duty rear swaybar mount
090 - Front adjustable pillow ball endlinks
140 - High-flow/pressure oil pump, modified 12mm
1700 -Perrin rotated GT35 .63 kit with 44mm external TIAL, downpipe with wastegate routing, up-pipe coated.
250 - Greddy Intercooler core
090 - Mine's front under brace, 93-01 -PENDING-
$40 - turbo coolant tank - painted blue
040 - Zerosports thermostat
380 - Zerosports 4-puck Exedy clutch kit, 5spd pull (93-05 turbo wrx), 7.5mm left on disk, comes with 8mm aka lots left!
200 - IXIZconcepts race-modified AOS
$10 - GReddy shift knob
150 - Greddy oil cooler with thermostat, needs core fixed or replaced, comes with -10AN lines
200 - Sparco Speed Passenger Seat - like new, comes with bracket
$20 - oem front swaybar, wagon turbo GD
80 - NRG quick release v.1.5
130 - Front brembo Ferodo DS2500 pads - new in box.
160 - Custom aluminum piping for rotated intake manifold & v-mount
220 - Koyo Radiator (for RX7 FD - works well for V-mount)
325 - Radiator,hoses and piping to make v-mount (the whole thing minus IC!)
100 - GT-Spec Fender Braces 93-01
200 - Schroth 5-pt driver, 4-pt passenger ASM harness
070 - Walbro fuel pump
400 - Cusco Safety 21 8-pt Roll Cage (steel cage with door bars) - 93-01, may fit GD.
400 - Hydra EMS ver.2.17 with wideband (can be used for any non-avcs setup)
1000 - Stance GR+ Pro SS-D valved for 12k/12k springs, come with a set of 10K springs, very low miles. 02-07, 5x100.
300 - GT-Spec Rear strut bar with trunk brace, 93-01
2600 -Built STi EJ257 with H-beam rods, CP Pistons, & ACL bearings - fresh rebuild with new pistons, refurbed crank, & bearings by AQ Motorsprots/Harman Motive
200 - STI Triple pillow trailing arms
[b]
^^^^^^^^^^^ SOLD ^^^^^^^^^^^^^
kingsubi is offline   Reply With Quote
Old 06-02-2010, 12:08 AM   #2
kingsubi
Member#: 19239
added some more parts
Old 06-03-2010, 12:09 PM   #3
1995ImprezaNoob
Member#: 248351
1995 Impreza
Mint Green
Front fenders? If you're willing to part them out from the shell?
1995ImprezaNoob is offline   Reply With Quote
Old 06-03-2010, 08:48 PM   #4
kingsubi
Member#: 19239
sending pm
Old 06-06-2010, 02:41 PM   #5
kingsubi
Member#: 19239
updated list
Old 06-07-2010, 04:42 PM   #6
kingsubi
Member#: 19239
up again
Old 06-08-2010, 04:14 PM   #7
kingsubi
Member#: 19239
up for looks
Old 06-08-2010, 04:19 PM   #8
kingsubi
Member#: 19239
Axles (93-01)
Bugeye grill:
NRG quick release and old-style v-limited cluster:
Old 06-09-2010, 09:09 PM   #9
kingsubi
Member#: 19239
turbo kit sold
Old 06-10-2010, 02:58 AM   #10
bmwpride
Member#: 240027
how much for the pitch mount, it will fit a 97 lgt??
bmwpride is offline   Reply With Quote
Old 06-10-2010, 11:46 AM   #11
kingsubi
Member#: 19239
$80 shipped. yes.
Old 06-14-2010, 02:59 PM   #12
kingsubi
Member#: 19239
up for looks
Old 06-15-2010, 11:02 AM   #13
iarufe98
Member#: 249175
you wouldnt happen to have a set of stock CAT's laying around???
iarufe98 is offline   Reply With Quote
Old 06-15-2010, 12:54 PM   #14
kingsubi
Member#: 19239
nope sorry. just a 3" high flow cat with flanges.
Old 06-15-2010, 05:31 PM   #15
kingsubi
Member#: 19239
rwd diff sold
Old 06-16-2010, 03:47 PM   #16
kingsubi
Member#: 19239
clutch sold.
updated list!
Old 06-18-2010, 03:04 AM   #17
brentos
Member#: 183155
How much for the fuel pump shipped to Calgary, Alberta Canada? And how many k's?
brentos is offline   Reply With Quote
Old 06-18-2010, 12:58 PM   #18
kingsubi
Member#: 19239
maybe 10K km. $70 shipped, for $80 you get the whole pump unit.
Old 06-20-2010, 08:20 PM   #19
kingsubi
Member#: 19239
its sunday!
Old 06-21-2010, 02:42 PM   #20
kingsubi
Member#: 19239
lowered most prices by 50%
Make some offers!
Old 06-22-2010, 09:46 PM   #21
kingsubi
Member#: 19239
taking offers on everything!
Old 06-23-2010, 07:02 PM   #22
kingsubi
Member#: 19239
turbo sold
Old 06-24-2010, 05:40 PM   #23
kingsubi
Member#: 19239
updated
Old 06-25-2010, 06:10 PM   #24
kingsubi
Member#: 19239
more parts sold - lots left!
Old 06-27-2010, 02:23 AM   #25
kingsubi
Member#: 19239
reduced prices and updated the list. Make some offers!
1995 Legacy L shell lots of goodies hybridpatient95 Legacy Specific Parts 7 09-21-2008 10:28 AM
1995 subaru legacy L shell lots of goodies FS NJ hybridpatient95 Private Vehicle 'For Sale' Classifieds 2 09-11-2008 01:20 AM
Parting out my car *Lots of goodies* Cashis Bay Area Impreza Club Forum -- BAIC 15 06-11-2006 01:12 PM
fs:A lot of goodies in NY Parting out my car JERMAINE Private 'For Sale' Classifieds 93 01-31-2005 03:24 PM
Parting out my car!!! lots of goodies... AmirWRX Bay Area Impreza Club Forum -- BAIC 46 04-08-2004 03:39 AM
