Alaskan Impreza Club
Old 06-18-2010, 01:23 AM   #251
iLuv-Bo0st
Member#: 198200
2006 STI
An it is just full 3 inch no bellmouth right ? Does it make a big difference?
iLuv-Bo0st is offline   Reply With Quote
Old 06-18-2010, 01:33 AM   #252
Brando5185
Member#: 189926
2006 GC 5.7L
Yeah just the 3 inch non bellmouth. Never had a bellmouth dp so don't know if there is a difference.
Brando5185 is offline   Reply With Quote
Old 06-18-2010, 01:40 PM   #253
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
ok if your running a external waste gate then the HKS dp is perfect, if your using a internally gated turbo a bellmouth will relieve turbulence behind the turbine wheel where the HKS because of its flat flange on the wastegate side may cause turbulence behind the turbine wheel.
tribalwrx is offline   Reply With Quote
Old 06-18-2010, 01:46 PM   #254
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
You can also look at divorced downpipes that break the wastgate gases off completly at first. http://www.rallysportdirect.com/shop...atted_Full.jpg
One way or another you can do what you want to with the pipe you have but you may find gains in spool time and power with a better downpipe.
P3Auto is offline   Reply With Quote
Old 06-18-2010, 02:19 PM   #255
iLuv-Bo0st
Member#: 198200
2006 STI
Hmmm okay so maybe I should upgrade my downpipe get an intake fuel injectors fuel pump then a tune ? Or run the 20g with injectors and fuel pump current downpipe and upgrade downpipe later?
Old 06-18-2010, 02:26 PM   #256
907wrx
Member#: 165451
02 wrx
907wrx is offline   Reply With Quote
Old 06-19-2010, 04:09 AM   #257
iLuv-Bo0st
Member#: 198200
2006 STI
K well now I've kinda been cinvnced to just go with a gt 35 r and slowly build it. How much is a average price for one ofthese and injectors ? Should I do front mount intake fuel pumpand injectors for now then get it tuned and get the gt35r after that since those are supporting mods ?
Old 06-21-2010, 01:49 PM   #258
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
You can do it all at the same time if you want. I would still stick with the Blouch turbos : http://www.blouchturbo.com/ their GT35 style model will still have the best spool from what I have seen.
Old 06-22-2010, 08:38 PM   #259
mashedpaters
Member#: 167462
2003 wrx
sedona red
if you have any ideas and the time to help I would greatly appreciate it. Otherwise, no big deal.
in short, stage 2 custom os tuned, 2003 wrx 66,xxx miles. 2 years with the tune everything is good until a long day of auto-x, car feels sluggish. I logged and there is a lot of knock correction. its not particularly lean and the iam is fine, so I'm thinking vacuum leak. I also just got P1443 code which I've had before, not sure if the evap control stuff is related to the knock. any suggestions or ideas?
mashedpaters is offline   Reply With Quote
Old 06-22-2010, 08:48 PM   #260
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
This is sort of one of those "my foot hurts whats wrong with me" questions. Without more details and seeing the car its always tough.
Start with the basics...
Check for boost leaks especially between the intercooler and throttle body. Hot days and heat soak will lead to some slight knock.
You mentioned the IAM stays at 16? Not seeing a lot of rough correction is good. Seeing some FBKC is not always good but depending on how much and where its happening on the map may not always be a cause for concern. Log FBKC, Calculated load, RPM to start with and report back with the numbers.
Evap system failure could cause some problems but typically it doesn't. Don't get crazy until you rule out the simple stuff.
Old 06-24-2010, 05:20 PM   #261
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
BTW--- P3 Import Autowerks can tune almost anything from 2000+ ... We are a VAST dealer and also can work with Revo to tune VW, Audi, Porsche, and BMW!
Old 06-26-2010, 03:25 PM   #262
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
How serious if a front crank seal is leaking?
kyletakahero is offline   Reply With Quote
Old 06-26-2010, 03:34 PM   #263
tribalwrx
Member#: 32993
vf39 Best trap 110
really depends on how bad, but in general its not a good thing and should be fixed right away
Old 06-28-2010, 03:28 PM   #264
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Don't run out of oil and if its getting all over the timing belt plan on replacing that at least. We can fix you up if you need it.
Old 06-29-2010, 04:44 AM   #265
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
lets talk speed density...
greenspeed is offline   Reply With Quote
Old 06-29-2010, 05:47 AM   #266
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
do they tune anti lag or speed density? rumors rumors rumors...clarify,plz.
Marlons101 is offline   Reply With Quote
Old 06-29-2010, 06:23 PM   #267
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Anti-lag on 32 bit ECUs has been attempted by some of the best. I have some maps that sort of make it happen but the results have not been marketable. For 16bit ECUs there is code that has been adapted and it includes speed density. The anti-lag function is moderate.
I do have tunes for speed density only on 32bit ECUs. They work well.
The ultimate solution is a full plug and play stand alone ECU. So if your really serious and have about $2500 to spare we can get started.
If anyone ever works out anti-lag on the stock 32 bit ECU they will be forever known..Its like the holy grail for the US STI. It can be done it will just take the right motivation to do it. I would pay dearly for even a piece of the code if anyone can show me it.
Old 06-29-2010, 06:38 PM   #268
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Tell me more about speed density on 32bit. Are we talking canned STi tunes or ANY 32bit? The former has been released on Romraider, but the latter hasn't been done AFAIK.
retrac is offline   Reply With Quote
Old 06-29-2010, 06:52 PM   #269
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
I have working STI speed density tunes. I think I could port it to other 32 bit systems such as a Legacy GT, it might take some time. Do you want to play lab rat?
Old 06-29-2010, 07:07 PM   #270
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Yes45!
Old 06-29-2010, 07:21 PM   #271
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Is there a reason you feel you need speed density on your car? Besides the cool factor...
You will need to come out when I get some free time and we can start pulling the code apart and comparing.
Old 06-29-2010, 07:42 PM   #272
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Because I'm used to speed density tuning, the fact that I can do any intake, and the smoothness when it's tuned right.
Old 06-29-2010, 07:55 PM   #273
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Why do you suppose Subaru decided to ues a MAF sensor?
Also will you be running over the stock MAP sensor limit of 22.5PSI?
Old 06-29-2010, 08:02 PM   #274
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Subaru used a MAF because it's better for average joes and can account for variables easier than speed density. Yes it'll be maxed, upgrade and rescale is forthcoming.
Old 06-29-2010, 08:27 PM   #275
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Thats interesting that you see it that way. I see it the other way around.
We have another option if you want to jump on the Cobb AP boat. The Racetuner Pro software allows for speed density tunes but I have to check and see if it goes for Legacy GT as well...Sent an email today to find out.
I have the scaling for the AEM 3.5 bar MAP sensor, thats what I use in case I feel like running 50PSI...lol
Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune Unabomber Engine Management & Tuning 16 11-06-2014 02:12 PM
Bend, Oregon Tuners Carartist North West Impreza Club Forum -- NWIC 52 10-05-2010 10:07 PM
Tuner is asking me what compression I am using. Ryan314 Built Motor Discussion 7 04-24-2010 05:44 PM
('93-'01) sorry to ask if asked, how do u search ? christurismohk Impreza Forum 1 06-07-2001 10:11 PM
