Old 05-05-2010, 01:23 AM   #476
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Facility-Goodspeed Scottsdale,AZ
Tuner- Clark Tuner
Fuel- 91 AZoct beyond crappy
Mods
Cosworth Shortblock
Cosworth Manifold
Stage 2 Ported Heads
Kelford 272/272 Hotcams
Borg Warner S259 .70 60LB
850cc PE Injectors
Aero Fuel Rails
Aero 1000cc Fuel Regulator
APS DR525 FMIC
Perrin EL Headers (With Leak)
ASU is offline   Reply With Quote
Old 05-06-2010, 11:37 PM   #477
joSTIzel
Member#: 157787
04 WRX STi 411/420
Special thanks to Rob at NLM and Dave Brown my tuner from MSPT FTMFW!!
Facility: No Limit Motorsports
Type of Dyno: Dyno Dynamics
Baseline # for a stocker at the dyno: unknown
Boost: 22psi
Fuel: Pump
Target AFR: 11.1
SAE Corrections: unknown
Mods:
FP Green 3"Inlet 8cm
DW 850cc Injectors
Bosch 255lph Pump
Aeromotive FPR
Innovate AF/R
Greddy Profec-B EBC
Cobb Accessport V2
APS D/R525 FMIC
APS Fuel Rail
APS TGV Deletes
APS 3.5 Downpipe
APS 70mm CAI
APS Turbo inlet
Tanabe Medallion CBE Modded to fit DP
GTspec U/L Headers
UR Uppipe
Tial 44mm Wastegate
Tial 50mm BOV 11psi Spring
Crawford Air/Oil separator V2
Grimmspeed 8mm Phenolic Spacer
Unorthrodox Pulley set
NGK Iridium 1 step colder plugs
joSTIzel is offline   Reply With Quote
Old 05-18-2010, 02:48 PM   #478
forest4ever
Member#: 190569
2000 P1
Subaru Impreza P1
Year registered 2000
Engine Spec
Earthing kit
ECU TEK engine remap and license mapped for VPOWER
Turbosmart supersonic BOV
TSL Tubular unequal length exhaust headers
TSL Decat
TSL Downpipe
TSL center section
TSL firestorm back box
TSL Silicon Hose`s
Green panel filter
Walbro uprated fuel pump
Spec R Polished Alloy Alternator Cover
Spec R Polished Alloy Battery and Fuse Cover
Scoobyclinic Dyno Printout 320bhp/325lbl/
forest4ever is offline   Reply With Quote
Old 05-27-2010, 06:59 PM   #479
luismiguel
Member#: 170678
Chapter/Region: PRSIC
07 WRX Limited
Car: 07 USDM WRX Limited - about 30K miles at time of tune
Facility: Sporty Dyno (tuned by Gadiel)
Type of Dyno: Dynojet
Baseline # for a stocker at the dyno: 180-190
Boost: peak around 17psi
Fuel: 93 octane
Target AFR:11.5
Peak HP at RPM: 308whp @ 6000rpm
Peak Torque at RPM: 326wtq
Mods:
VF39
STI (Spec-C) TMIC
Invidia Down Pipe
Greddy SP2 CBE
SPT Intake with Heat Shield
Hallman Manual Boost Controller
Walbro Fuel Pump
HKS SSQV
Denso Iridium Spark Plugs
Ecutek reflash
luismiguel is offline   Reply With Quote
Old 05-31-2010, 07:32 PM   #480
Flyin_Hayn
Member#: 175031
2005 PSM STi
Stage2 303awhp / 331awtq
Facility: Portland Race Engineering
Baseline # for a stocker at the dyno: 175WHP
Boost: 16.5
Fuel: 92 Octane (Shell V-Power)
Target AFR: 11.5
SAE Corrections: N/A
Peak HP at RPM: 230WHP @ 4,600RPM
Peak Torque at RPM: 270 WTQ @ 4,200RPM
Mods: 2.5L Hybrid, TD04, GPMoto EQ Length Headers 4-2, Custom 3" Dowpipe, Custom 3" Cat-Back, STi Pinks, 255 Walboro, Silcone Intake Tract, GPMoto 4.5" Shortram, AVO Top-Mount, APS BOV, Prova AOS, TurboSmart MBC, Exedy Stage2 Thick Clutch, Stock Tranny.
Note*
Car was Protuned before max HP/TQ was Aqcuired so it had some heat soak and Air Filter is 3 years old and DIRTY! AEM Dry Filter in mail.
Couldve squeezed another 5-10whp out of it on this day.
Wish i had a scanner to put Dyno Sheet up :/. Looks awesome.
Flyin_Hayn is offline   Reply With Quote
Old 06-06-2010, 09:30 PM   #481
Base9se
Member#: 216903
1991 Miata
Car: 2007 WRX TR
Facility: Corr Performance
Boost: ~16 psi
Fuel: 93 Oct
Target AFR: Rich
Mods: ERX Catted DP, Invidia CBE, and Cobb AP OTS Stg 2
NOTE: Temperature was 90F (and rising) with 65% relative humidity.
Baseline from another Scooby (same year) done last year in March on the same dyno....
Below is Cobb OTS Stg 2 (Rev. 1.03) chart...
Video of the pulls...
Base9se is offline   Reply With Quote
Old 06-15-2010, 06:47 PM   #482
SubaruWrxSTR
Member#: 199039
11 Sti Closed Deck
15 wrx CVT
Parts list: Tuned by TOPSPEED
Vf30
Spt intake
Sti pink injectors
Walbro 255 fuelpump
Step Colder Plugs
Indivia V3 down pipe
Hks carbonfiber ti exhaust
Sti Tmic
GMS turbo inlet
AND the motor has never been rebuilt and has 185000 miles on it! I guess im blessed! also it was 103 degrees outside while being tuned..
SubaruWrxSTR is offline   Reply With Quote
Old 06-23-2010, 02:35 PM   #483
Pericles
Member#: 249830
I am a complete newb to Subarus, but I was under the impression that, especially the old iron blocks, were capable of really high HP levels (IE 700 plus whp).
I saw one list on this forum but the most powerful cars were in the 400 range.
400 would make for a very fun car and an excellent track weapon, but were are the high hp monsters?
Thank you
Pericles is offline   Reply With Quote
Old 06-23-2010, 03:00 PM   #484
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Thank you
I guess you haven't looked very hard. Here is a 647whp one for sale.
http://forums.nasioc.com/forums/show...0#post31115320
Old 06-24-2010, 09:31 AM   #485
Pericles
Member#: 249830
Why is it not listed in the official hp ranking?
Old 06-24-2010, 09:37 AM   #486
SVT_WRX
Member#: 164830
G61 III OVE 58e
Your question is unclear. Why is what not listed? What do you mean when you say "official hp ranking?" Are you talking about the official road dyno list thread? Try and be more specific when asking questions so we can provide a thorough answer.
SVT_WRX is offline   Reply With Quote
Old 06-24-2010, 02:04 PM   #487
Pericles
Member#: 249830
yes, official hp ranking=road dyno list.
Old 06-24-2010, 02:24 PM   #488
SVT_WRX
Member#: 164830
G61 III OVE 58e
That list is for enthusiasts who have done a road dyno log. A road dyno is a log of a WOT run in a specific gear on the road and it's put into a spreadsheet to calculate horsepower. The reason you don't see these plots in that thread is because they went to a chassis dyno.
Old 06-24-2010, 03:19 PM   #489
Pericles
Member#: 249830
Yes, I data log my GT2 often.....the bottom line is what kind of power are these cars putting down?
I am not interested in semantics or argumentation, just hp numbers.
Actually, hp levels are less accurate than 60-130 #'s for really measuring performance, but for now I am interested in how much power these cars are putting down.
For example if you asked me what P cars are putting down on stock blocks nowadays, I would respond "in excess of 750 rwhp with no blown engines."
Old 06-24-2010, 03:40 PM   #490
SVT_WRX
Member#: 164830
G61 III OVE 58e
Again, then you need to be a bit more thorough when asking questions if you want a specific, thorough answer. If all you were interested in is how much HP numbers these cars are making, you should have just said so. Your question indicates otherwise.
I can't say that I'm %100 sure, but I have seen/heard/read that there are EJ motors out there that are putting out more than 750 hp.
Old 06-24-2010, 03:52 PM   #491
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I would say, cautiously, 400 whp is the threshold of bad things on stock internals. Some model years are more tolerable than others.
Old 06-24-2010, 04:30 PM   #492
Pericles
Member#: 249830
Thanks you.
Old 06-24-2010, 04:46 PM   #493
SVT_WRX
Member#: 164830
G61 III OVE 58e
Old 06-24-2010, 04:48 PM   #494
SVT_WRX
Member#: 164830
G61 III OVE 58e
Key point here is marked in bold.
Old 06-24-2010, 08:46 PM   #495
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
That was the question he asked. Don't get sensitive.
Old 06-24-2010, 09:27 PM   #496
SVT_WRX
Member#: 164830
G61 III OVE 58e
Nobody is getting sensitive. All I'm doing is trying to point out the importance of your point made. If you got a problem with that, then I don't know what to tell you.
Old 06-25-2010, 08:11 AM   #497
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Thats good, my bad. I know many subie owners are sensative to people pointing out limitation to outsiders.
Old 06-29-2010, 11:04 PM   #498
shawns_sick_STi
Member#: 126107
2004 STi
Car: 2004 STi
Facility: Engine Logics
Boost: 23.5 peek 22 redline
Fuel: 93 Oct
Target AFR: 11.8
Mods: perrin gt3076r rotated mount with perrin front mount
perrin fuel rails, 816cc injectors &255L pump
SMC 100% alcohol injection kit
gruppe-s ceramic coated equal length header
perrin twin 2.25" exhaust
Tial 44mm waistgate
exedy twin ceramic metalic clutch
plus tien mono flex W/edfc, sway bars, anti lift, lots off bushings, pitch stop, pads and rotors, break brace, short shifter, and some other stuff i probobly forgot about.
NOTE: Temperature was over 90F in the dyno bay.
shawns_sick_STi is offline   Reply With Quote
Old 07-01-2010, 03:23 AM   #499
generalganja
Member#: 54826
2006 WFC #420
SGM, Church tuned
06 wrx 90k miles
Tuned by Shawn Church of Church Automotive Testing in Wilmington, CA
Dyna pack
16.6psi on stock td04
91 octane
Mods:
-K&N Short Ram intake
-3" bellmouth DP
-3"-2.5" tapered Apexi N1 catback
Non-related mod:
-Emissions air pump system delete
Baseline for stock wrx ~190
End result
255.4 whp, 318 lb_ft
generalganja is offline   Reply With Quote
Old 07-01-2010, 05:54 PM   #500
Ecyrb | SLC
Member#: 215535
2002 WRX Sport Wagon
Car: 2002 WRX Sport Wagon
Facility: Kito Auto Sport (Seattle)
Type of Dyno: Mustang Dyno
Boost: ~15 psi
Fuel: 93 Oct
Target AFR: 11.5
Mods: Invidia Catted DP, Helix Catless Up-pipe, STI CatBack, STI Top Mount, SPT Intake w/HeatShiled
Video in the works..!
Ecyrb | SLC is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
