05-05-2010, 01:23 AM | #476 |
Member#: 164551
SWIC
Vehicle:2006 Brotastic STi Land of beer and laws |
Facility-Goodspeed Scottsdale,AZ
Tuner- Clark Tuner Fuel- 91 AZoct beyond crappy Mods Cosworth Shortblock Cosworth Manifold Stage 2 Ported Heads Kelford 272/272 Hotcams Borg Warner S259 .70 60LB 850cc PE Injectors Aero Fuel Rails Aero 1000cc Fuel Regulator APS DR525 FMIC Perrin EL Headers (With Leak)
05-06-2010, 11:37 PM | #477 |
Member#: 157787
Tri-State
Vehicle:04 WRX STi 411/420 WRB |
Special thanks to Rob at NLM and Dave Brown my tuner from MSPT FTMFW!!
Facility: No Limit Motorsports Type of Dyno: Dyno Dynamics Baseline # for a stocker at the dyno: unknown Boost: 22psi Fuel: Pump Target AFR: 11.1 SAE Corrections: unknown Mods: FP Green 3"Inlet 8cm DW 850cc Injectors Bosch 255lph Pump Aeromotive FPR Innovate AF/R Greddy Profec-B EBC Cobb Accessport V2 APS D/R525 FMIC APS Fuel Rail APS TGV Deletes APS 3.5 Downpipe APS 70mm CAI APS Turbo inlet Tanabe Medallion CBE Modded to fit DP GTspec U/L Headers UR Uppipe Tial 44mm Wastegate Tial 50mm BOV 11psi Spring Crawford Air/Oil separator V2 Grimmspeed 8mm Phenolic Spacer Unorthrodox Pulley set NGK Iridium 1 step colder plugs |
05-18-2010, 02:48 PM | #478 |
Member#: 190569
Vehicle:2000 P1 Blue |
Subaru Impreza P1
Year registered 2000 Engine Spec Earthing kit ECU TEK engine remap and license mapped for VPOWER Turbosmart supersonic BOV TSL Tubular unequal length exhaust headers TSL Decat TSL Downpipe TSL center section TSL firestorm back box TSL Silicon Hose`s Green panel filter Walbro uprated fuel pump Spec R Polished Alloy Alternator Cover Spec R Polished Alloy Battery and Fuse Cover Scoobyclinic Dyno Printout 320bhp/325lbl/ |
05-27-2010, 06:59 PM | #479 |
Member#: 170678
PRSIC
Vehicle:07 WRX Limited Satin White Pearl |
Car: 07 USDM WRX Limited - about 30K miles at time of tune
Facility: Sporty Dyno (tuned by Gadiel) Type of Dyno: Dynojet Baseline # for a stocker at the dyno: 180-190 Boost: peak around 17psi Fuel: 93 octane Target AFR:11.5 Peak HP at RPM: 308whp @ 6000rpm Peak Torque at RPM: 326wtq Mods: VF39 STI (Spec-C) TMIC Invidia Down Pipe Greddy SP2 CBE SPT Intake with Heat Shield Hallman Manual Boost Controller Walbro Fuel Pump HKS SSQV Denso Iridium Spark Plugs Ecutek reflash |
05-31-2010, 07:32 PM | #480 |
Member#: 175031
NWIC
Vehicle:2009 FXT Chamelia Red |
Facility: Portland Race Engineering
Type of Dyno: Dyno Dynamics Baseline # for a stocker at the dyno: 175WHP Boost: 16.5 Fuel: 92 Octane (Shell V-Power) Target AFR: 11.5 SAE Corrections: N/A Peak HP at RPM: 230WHP @ 4,600RPM Peak Torque at RPM: 270 WTQ @ 4,200RPM Mods: 2.5L Hybrid, TD04, GPMoto EQ Length Headers 4-2, Custom 3" Dowpipe, Custom 3" Cat-Back, STi Pinks, 255 Walboro, Silcone Intake Tract, GPMoto 4.5" Shortram, AVO Top-Mount, APS BOV, Prova AOS, TurboSmart MBC, Exedy Stage2 Thick Clutch, Stock Tranny. Note* Car was Protuned before max HP/TQ was Aqcuired so it had some heat soak and Air Filter is 3 years old and DIRTY! AEM Dry Filter in mail. Couldve squeezed another 5-10whp out of it on this day. Wish i had a scanner to put Dyno Sheet up :/. Looks awesome. |
06-06-2010, 09:30 PM | #481 |
Member#: 216903
TXIC
Vehicle:1991 Miata White |
Car: 2007 WRX TR
Facility: Corr Performance Type of Dyno: Dyno Dynamics Boost: ~16 psi Fuel: 93 Oct Target AFR: Rich Mods: ERX Catted DP, Invidia CBE, and Cobb AP OTS Stg 2 NOTE: Temperature was 90F (and rising) with 65% relative humidity. Baseline from another Scooby (same year) done last year in March on the same dyno.... Below is Cobb OTS Stg 2 (Rev. 1.03) chart... Video of the pulls... |
06-15-2010, 06:47 PM | #482 |
Member#: 199039
South East
Vehicle:11 Sti Closed Deck 15 wrx CVT |
Parts list: Tuned by TOPSPEED Vf30 Spt intake Sti pink injectors Walbro 255 fuelpump Step Colder Plugs Indivia V3 down pipe Hks carbonfiber ti exhaust Sti Tmic GMS turbo inlet AND the motor has never been rebuilt and has 185000 miles on it! I guess im blessed! also it was 103 degrees outside while being tuned.. Last edited by SubaruWrxSTR; 06-30-2010 at 04:15 PM. |
06-23-2010, 02:35 PM | #483 |
Member#: 249830
I am a complete newb to Subarus, but I was under the impression that, especially the old iron blocks, were capable of really high HP levels (IE 700 plus whp).
I saw one list on this forum but the most powerful cars were in the 400 range. 400 would make for a very fun car and an excellent track weapon, but were are the high hp monsters? Thank you |
06-23-2010, 03:00 PM | #484 | |
Member#: 43393
MAIC
Vehicle:2014 Audi a6 Daytona Gray |
http://forums.nasioc.com/forums/show...0#post31115320 |
06-24-2010, 09:31 AM | #485 |
Member#: 249830
Why is it not listed in the official hp ranking?
06-24-2010, 09:37 AM | #486 |
Member#: 164830
SCIC
Vehicle:2002 WRX G61 III OVE 58e |
Your question is unclear. Why is what not listed? What do you mean when you say "official hp ranking?" Are you talking about the official road dyno list thread? Try and be more specific when asking questions so we can provide a thorough answer.
06-24-2010, 02:04 PM | #487 |
Member#: 249830
yes, official hp ranking=road dyno list.
06-24-2010, 02:24 PM | #488 |
Member#: 164830
SCIC
That list is for enthusiasts who have done a road dyno log. A road dyno is a log of a WOT run in a specific gear on the road and it's put into a spreadsheet to calculate horsepower. The reason you don't see these plots in that thread is because they went to a chassis dyno.
06-24-2010, 03:19 PM | #489 |
Member#: 249830
Yes, I data log my GT2 often.....the bottom line is what kind of power are these cars putting down?
I am not interested in semantics or argumentation, just hp numbers. Actually, hp levels are less accurate than 60-130 #'s for really measuring performance, but for now I am interested in how much power these cars are putting down. For example if you asked me what P cars are putting down on stock blocks nowadays, I would respond "in excess of 750 rwhp with no blown engines." |
06-24-2010, 03:40 PM | #490 | |
Member#: 164830
SCIC
I can't say that I'm %100 sure, but I have seen/heard/read that there are EJ motors out there that are putting out more than 750 hp. |
06-24-2010, 03:52 PM | #491 |
Member#: 43393
MAIC
I would say, cautiously, 400 whp is the threshold of bad things on stock internals. Some model years are more tolerable than others.
06-24-2010, 04:30 PM | #492 |
Member#: 249830
06-24-2010, 04:46 PM | #493 |
Member#: 164830
SCIC
06-24-2010, 04:48 PM | #494 |
Member#: 164830
SCIC
06-24-2010, 08:46 PM | #495 |
Member#: 43393
MAIC
06-24-2010, 09:27 PM | #496 |
Member#: 164830
SCIC
Nobody is getting sensitive. All I'm doing is trying to point out the importance of your point made. If you got a problem with that, then I don't know what to tell you.
06-25-2010, 08:11 AM | #497 |
Member#: 43393
MAIC
Thats good, my bad. I know many subie owners are sensative to people pointing out limitation to outsiders.
06-29-2010, 11:04 PM | #498 |
Member#: 126107
TXIC
Vehicle:2004 STi silver |
Car: 2004 STi
Facility: Engine Logics Type of Dyno: Dyno Dynamics Boost: 23.5 peek 22 redline Fuel: 93 Oct Target AFR: 11.8 Mods: perrin gt3076r rotated mount with perrin front mount perrin fuel rails, 816cc injectors &255L pump SMC 100% alcohol injection kit gruppe-s ceramic coated equal length header perrin twin 2.25" exhaust Tial 44mm waistgate exedy twin ceramic metalic clutch plus tien mono flex W/edfc, sway bars, anti lift, lots off bushings, pitch stop, pads and rotors, break brace, short shifter, and some other stuff i probobly forgot about. NOTE: Temperature was over 90F in the dyno bay. |
07-01-2010, 03:23 AM | #499 |
Member#: 54826
SCIC
Vehicle:2006 WFC #420 SGM, Church tuned |
06 wrx 90k miles
Tuned by Shawn Church of Church Automotive Testing in Wilmington, CA Dyna pack 16.6psi on stock td04 91 octane Mods: -K&N Short Ram intake -3" bellmouth DP -3"-2.5" tapered Apexi N1 catback Non-related mod: -Emissions air pump system delete Baseline for stock wrx ~190 End result 255.4 whp, 318 lb_ft |
07-01-2010, 05:54 PM | #500 |
Member#: 215535
NWIC
Vehicle:2002 WRX Sport Wagon Aspen White |
Car: 2002 WRX Sport Wagon
Facility: Kito Auto Sport (Seattle) Type of Dyno: Mustang Dyno Boost: ~15 psi Fuel: 93 Oct Target AFR: 11.5 Mods: Invidia Catted DP, Helix Catless Up-pipe, STI CatBack, STI Top Mount, SPT Intake w/HeatShiled Video in the works..! Last edited by Ecyrb | SLC; 07-01-2010 at 06:04 PM. |
Similar Threads | ||||
Post your OLD ride and your NEW ride. | MF-DIF | Member's Car Gallery | 1291 | 03-02-2016 11:43 PM |
Post your dyno results from today. (Mach V) | banzai | Mid Atlantic Impreza Club -- MAIC | 70 | 03-28-2006 10:08 PM |
hey baic folks, post your dyno results | LEOSPEED | Bay Area Impreza Club Forum -- BAIC | 16 | 11-25-2003 02:22 AM |
Utec dyno plots and target A/F ratios and some tuning advice. | nmyeti | Engine Management & Tuning | 39 | 10-15-2002 02:29 AM |
Post your dyno results here! | Darryl | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 11-10-2001 05:40 PM |
