Old 06-25-2010, 06:23 PM   #1
.HaVoK.
Member#: 229726
'09 2.Slow
Default Tire pressure light?
I bought aftermarket wheels and tires for my '09 2.5i and my "Check Tire Pressure" light has been on ever since. Is there any way to turn it off?
.HaVoK. is offline   Reply With Quote
Old 06-25-2010, 09:07 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
yeah, put the correct pressure in the tires. There should be some sort of reset mechanism, search.
also, post in the correct forum.
yarrgh is offline   Reply With Quote
Old 06-25-2010, 09:14 PM   #3
djinn
Member#: 212818
2010 Impreza 2.5i
Did you swap the TPMS over to the aftermarket wheels?
djinn is offline   Reply With Quote
Old 06-25-2010, 10:02 PM   #4
jeonster
Member#: 198854
2013 WRX
Black Tape.
Our cars don't have a reset mechanism.
Or you can open up your cluster and disconnect the wire.
jeonster is offline   Reply With Quote
Old 06-25-2010, 11:58 PM   #5
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
This, you need to do it. or you can just pull the light bulb behind the cluster
PARANOID56 is offline   Reply With Quote
Tire Pressure Light Flashing DubyaSTi Tribeca Forum 3 11-17-2008 09:53 AM
08 Spec.b Tire pressure light after putting after maket wheels Taras Tire & Wheel 15 08-14-2008 01:11 PM
Tire pressure light in 2008 WRX Troa Service & Maintenance 9 07-06-2008 06:56 PM
new rims and tire pressure light on ornge04gt Newbies & FAQs 12 04-06-2008 10:33 PM
low tire pressure light wont go off Shootist Tribeca Forum 4 09-10-2006 06:12 PM
