Old 06-10-2010, 06:06 AM   #1
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Default Idle bouncing with air conditioner only
On my 05 Baja N/A only with the air conditioner on the rpm's will bounce erratically 3-6 times when you fully let off the throttle (either clutch in or out). This is a fast snap of the rpm's bouncing between 750 to 2000rpm oscillating about 1 second reving an 1 second off.
Another sympton with the air and cruise control on when the cruise decelerates the engine falls flat and snaps back on (neck jerks-not as smooth between on and off throttle).
Once again this is only with the air on and severe bouncing of the rpm's.
WRX03 is offline   Reply With Quote
Old 06-10-2010, 10:59 AM   #2
flightwatch
Member#: 231058
2015 F-150
You could try resetting your ecu to start off with. Also, check that the tps is still good. Check the general condition of the tb to make sure it's in good working order.
It sounds like the ecu isn't opening the throttle plate enough to compensate for the extra engine load. Then when it does, it opens it too far, and it goes back and forth until it comes to a happy medium.
flightwatch is offline   Reply With Quote
Old 06-11-2010, 08:36 AM   #3
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
Also, check your throttle body. If there's gunk in there, the plate can get sticky. Cleaning it is cheap and fairly easy. I use the CRC Intake cleaner from my auto parts place, but use an intake cleaner and a rag to wipe up the goo.
Boxer4Dad is offline   Reply With Quote
Old 06-11-2010, 10:35 PM   #4
ronemus
Member#: 124146
'02 Legacy GT 5MT
Titanium
A gummed up idle air control valve is another possibility; hit it with some carb cleaner when you do the throttle.
ronemus is offline   Reply With Quote
Old 06-12-2010, 02:53 PM   #5
WRX03
Member#: 20744
05 Baja Regal Blue
How about the front O2 sensor?
I cleaned the TB out before my wife took the Baja on a trip but it was a simple spraying the butterfly and the port leading up to the idle valve. After 500 miles it is still doing the same. She is still on her trip so I won't be able to really dig in to it But the "only when the air conditioner is on" is a little confusing. It doesn't following the compressor turning on/off.
Old 06-27-2010, 06:00 AM   #6
WRX03
Member#: 20744
05 Baja Regal Blue
FYI. It was the IAT sensor, I take to mean Intake Air Temperature. It's the sensor mounted in the filter box. ~$65 online.
Old 08-18-2010, 01:32 PM   #7
EVAN&MONICA
Member#: 221802
2001 2.5RS coupe
BRP
Sweet ^ We've been dealing with this since we bought the RS (2.5NA) in feb, same exact problem, same exact conditions!
Happy to see you found the fix, I'll give it a try soon!
EVAN&MONICA is offline   Reply With Quote
my Impreza's idle bounces! 04.STI Normally Aspirated Powertrain 7 02-07-2007 03:58 PM
04 STi idle bouncing. Vtecready Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 09-16-2005 05:12 PM
problem with air conditioner please help boxer04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-25-2005 10:51 AM
('93-'01) rally racing v. air conditioner condenser and radiator Damon Impreza Forum 4 06-01-2001 02:52 PM
help! Water from air conditioner? gumball Technical Forum Archive 6 09-05-2000 12:48 AM
