Old 01-17-2010, 11:33 PM   #451
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Originally Posted by chimchimm5 View Post
Did Subaru add a "RCA" to the new GR impreza? If not, I wonder why?
No. Because they think that what they're doing is the best for normal drivers. They don't give a crap what we think.
Old 01-18-2010, 01:06 AM   #452
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Default Re: Whiteline Roll Center Adjustment Kit? Do you like it?
Actually I was thinking more along the lines of better geometry is better.
But I agree. The stock setup, compared to the RCA, would promote more understeer which is preferred for the mass market.
chimchimm5 is offline   Reply With Quote
Old 01-18-2010, 04:38 PM   #453
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
No, but they did add a lot of caster =)
The GR has what, ~6 deg of caster from the factory!?
AcquaCow is offline   Reply With Quote
Old 01-31-2010, 11:28 PM   #454
Whiteline Jim
Member#: 212668
2008 Sti
G’day everyone,
Stevenkelby, I’m told by the customer service and product development guys that there’s actually a limited amount of stock on its way as we speak to both the UK and USA distribution warehouses and that they should be there pretty soon.
The range covers most of the common applications and the easiest way to work out what’s what is via the following interchange...
Existing KLC39 spherical bearing applications covered by new KLC139 ball link
“ KLC47 “ “ “ KLC147
“ KLC002 “ “ “ KLC102
Web site will be updated soon with the new numbers but you can use above as a guide in the meantime.
chimchimm5, good question re stock springs and ROCK kit and I’d say the answer is yes. Largely because of Ty’s point about the stock design being a compromise for normal drivers and safety first. Not to say fitting an ROCK will make it unsafe but that the OEM’s are sensitive to anything that detracts from understeer always. In a way, the factory designed the geometry this way in the first place so the stock function is what they actually wanted.
Hope that helps.
Cheers
Whiteline Jim
Whiteline Jim is offline   Reply With Quote
Old 05-16-2010, 09:01 PM   #455
c4t
Member#: 244182
02 WRX WRB sold
07 STI OBP sold
So is it safe to say that if a purchase this kit now it should be the new version and I shouldnt have any problems?
like this ones i found on ebay?
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_1228wt_939
c4t is offline   Reply With Quote
Old 05-16-2010, 09:04 PM   #456
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
But why flea bay and why not one of NASIOC vendors?
R-
labcoat is offline   Reply With Quote
Old 05-26-2010, 12:14 AM   #457
protyne
Member#: 229171
08 STI
Is there any indication on the packaging that the RCA is now V2? Or no vendors would be carrying anymore V1 by now?
protyne is offline   Reply With Quote
Old 05-26-2010, 08:11 PM   #458
STi-MAN
Member#: 70252
05 STI
blue
^ no one should be carrying v1 i would thinkg.. any ways look through this thread.. theres plenty of information how to differentiate between the 2
STi-MAN is offline   Reply With Quote
Old 05-30-2010, 01:59 AM   #459
Whiteline Jim
Member#: 212668
2008 Sti
G’day everyone,
protyne, I think Sti-MAN is correct, there’s unlikely to be any of the older version out there in the market but just in case you need to check, have attached an image of what the latest version looks like.
The key difference is a much more pronounced mid section flat area on the ball joint with WHITELINE laser engraved on it. This is probably the best way of telling the difference.
Cheers
Whiteline Jim
[email protected]
Old 05-30-2010, 07:17 AM   #460
fastwrx25
Member#: 126441
03 bugeye
finally installed these with new tires and alignment.
love the handling! great kit, ball joint fitment nice and snug.
Old 06-27-2010, 10:17 PM   #461
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
update: several track days and some street driving and they haven't budged. good stuff
rjrutzky is offline   Reply With Quote
Old 06-28-2010, 05:10 PM   #462
bzbuzz
Member#: 116052
2011 STI ( Sold )
do we transfer the stock washer for whiteline ball joint? washer goes between control arm and ball joint castle nut.
bzbuzz is offline   Reply With Quote
Old 06-28-2010, 05:40 PM   #463
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Yes, transfer the flat-washer and it is placed as you stated.
Big-E is offline   Reply With Quote
Old 06-28-2010, 08:10 PM   #464
bzbuzz
Member#: 116052
2011 STI ( Sold )
yeh i just transfered that thanks! =)
one thing.. while i was putting wl ball joint back to control arm, the lower metal ring on ball joint felt off and the boot on the bottom's got slightly ripped.. is this ok?
Old 06-28-2010, 08:41 PM   #465
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
In general, no. The rip will eventually allow grease to leak out and water and dirt to get in.
Unfortunately, that ring will come off when you pull the traverse-link upwards too fast to effectively seat the ball-joint so you can install the washer and castle-nut. The boot has to be pushed up the shaft of the ball-joing by hand and the traverse-link pulled up (pushed up) slowly all-the-while making sure you're looking at that ring.
Put it together and leave it for now. Contact your favorite WL vendor and see if he/she can get you another single ball-joint. It may take a while, but from what I understand it can be done.
Old 06-30-2010, 12:28 AM   #466
bzbuzz
Member#: 116052
2011 STI ( Sold )
may I use some epoxy to seal the bottom side?
Old 06-30-2010, 12:53 AM   #467
bzbuzz
Member#: 116052
2011 STI ( Sold )
plus.. i just got an alignment with this Whiteline ball joint and tie rod installed.
i got -2.0 FL and -2.1 FR cambers. i had -1.8 both side before.
this mod cause more negative cambers? this is stock camber bolts with tokico d-spec with rce yellow springs.
Old 07-01-2010, 03:14 AM   #468
ZLODEY
Member#: 92535
2005 Impreza WRX STi
WR Blue
Lightbulb
corrosion is really a big problem for whiteline stuff (they don't know what it is in Australia )
here you could see my sway bars after 3 European winters + 3 of 4 spherical end-links should be replaced after only ~3000km one season because of a terrible clunking
ZLODEY is offline   Reply With Quote
Old 07-01-2010, 03:21 AM   #469
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
My winter conditions are probably worse than yours in terms of corrosion. The salt here has destroyed a lot of Whiteline parts, but I have to say that the Roll Center Adjustment Kit is none the worse for the wear. No visible corrosion at all after 2 winters.
Old 07-01-2010, 03:36 AM   #470
fastwrx25
Member#: 126441
03 bugeye
yeah wl finish is no good.
try these rallitek endlinks http://www.rallitek.com/RalliTEK-HD-...ndlinks/p-4270, they should hold up better since they are sealed.
Old 07-01-2010, 04:02 AM   #471
ZLODEY
Member#: 92535
WR Blue
the worst thing is even not a looks, but because of serious corrosion swaybar is moving from side to side :|
Old 07-01-2010, 04:24 AM   #472
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The swaybar is moving side to side because a swaybar always moves side to side when you use spherical bearing endlinks.
Old 07-01-2010, 04:37 AM   #473
ZLODEY
Member#: 92535
WR Blue
I mean it moves 3-5cm ~1-2" to each side, IMO it's not normal...
Old 07-01-2010, 09:08 AM   #474
fastwrx25
Member#: 126441
03 bugeye
you can try something like this...might help
locking collars in the diameter of your sway bar, by the rsb clamps.
http://www.amazon.com/Climax-Metal-H2C-100-Collar-Finish/dp/B000P0OFGUhttp://www.amazon.com/Climax-Metal-H2C-100-Collar-Finish/dp/B000P0OFGU
Old 07-01-2010, 03:28 PM   #475
bzbuzz
Member#: 116052
2011 STI ( Sold )
my whiteline sway bars are rusted like crazy as well.. also RCE yellow spring..
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Suspension/Brakes/Handling 4 12-03-2009 09:34 AM
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Tri-State Area Private Classifieds 3 12-03-2009 09:34 AM
Brand new in Box - Whiteline Roll-Center Adjusting Kit & Kartboy Pitch Stop Mount! CALIBAN Suspension/Brakes/Handling 6 03-06-2009 05:33 PM
fs: 169 BRAND NEW Whiteline Roll Center adjuster kit fastwrx25 Suspension/Brakes/Handling 3 07-29-2007 03:53 PM
