Old 06-25-2010, 08:00 PM   #1251
05ASPINREX
Member#: 190454
2005 wrx stage II
white like my bitch
wooooooooooooo
05ASPINREX is offline   Reply With Quote
Old 06-25-2010, 10:27 PM   #1252
SHARP_DAL
Member#: 183247
2005 WRX
^^ nice setup but where's the turbo?
SHARP_DAL is offline   Reply With Quote
Old 06-26-2010, 01:02 AM   #1253
PAImportTuner
Member#: 141669
A EJ205 with
E316G
please tell me that EWG setup is not for a stock td04?
PAImportTuner is offline   Reply With Quote
Old 06-26-2010, 01:48 AM   #1254
SilentDoomWgn
Member#: 246729
03 wrx wgn
blue
Originally Posted by PAImportTuner View Post
I thought all these PT19T turbos were already ported? Hence why ForesterWti said they were a better deal since Blouch you have to pay for porting? I do remember him saying this.
no he actually dose not offer pnp at all what so ever. the only option he did offer was ceramic coating. atleast that is what he told me when i called him a few weeks back to see.
SilentDoomWgn is offline   Reply With Quote
Old 06-26-2010, 09:15 AM   #1255
rcodea
Member#: 225115
09 WRX
^^^correct, no porting offered
Wolf was refering to the H/HL/TE04 turbin wheels, not porting. Blouch charges extra for these wheels and machining, were was PT offered your choice for the same price.
~Ryan
rcodea is offline   Reply With Quote
Old 06-26-2010, 11:39 PM   #1256
PAImportTuner
Member#: 141669
A EJ205 with
E316G
~Ryan
gotcha
Then if this is the case I would want to port the wastegate port and also do compressor outlet and turbine inlet porting if your using the stock suby td04 housings with the turbine wheel upgrade.
Old 06-27-2010, 09:17 AM   #1257
knuts
Member#: 116814
2003 wrx wagon
blue
Default Caution: IWG porting trade-off
Porting the turbine inlet and compressor outlet should be of some benefit, but I would caution against porting the wastegate. Doing so would likely increase the boost taper seen by rcodea in the upper range (currently from 21 psi peak to 16 @ 6600 rpm with MBC). To maintain higher boost in the upper range, it'll be necessary to increase the EBCS WG duty cycle to close down the WG as rpm increases above 5000 rpm. Porting the WG would have the opposite effect and possibly make it more difficult to maintain higher boost in the upper range.
The exhaust housing outlet diameter was enlarged by PT to accommodate the larger H wheel. This resulted in an outlet area increase of ~ 15%, and should be enough to accomodate the higher flow capability of the 19T compressor wheel. Porting the WG may offer some benefit in the mid range where there is an excess of exhaust manifold pressure (relative to that required to achieve target boost), but for reasons stated above, will be a trade-off that may increase midrange performance at the expense of top-end.
knuts is offline   Reply With Quote
Old 06-27-2010, 09:51 AM   #1258
rubins
Member#: 80669
02 WRX
Rally Blue
Originally Posted by rubinm View Post
Perhaps this guy delivered your box?
Classic!!!
rubins is offline   Reply With Quote
Old 06-27-2010, 10:14 AM   #1259
rcodea
Member#: 225115
09 WRX
WOlf, what is the story? how did you do last night?
~Ryan
Old 06-27-2010, 11:02 AM   #1260
rcodea
Member#: 225115
09 WRX
well, no time for porting, maybe another day.
got it on, though it took me 2hrs to get one of the turbine-to-uppipe nuts off...actually stripped the stud and had to re-tap it. maybe when I have some time, I’ll pull the turbo, and make all the necessary portings to help it breath, and replace the stud.
I did make note though, the uppipe gasket is much larger in diameter of the uppipe or turbin inlet. not sure if this is normal, or if this is just a larger-than-stock gasket.
I need to get an air-oil separator on this car. I am not a subaru guru, but there was a bit of oil film on the turbo inlet when I took the stock td04 off yesterday. It seems to be much worse than any other time I have had the turbo off. Once I get that done, I’ll clean the whole system using the new SeaFoam spray. great stuff.
~Ryan
Old 06-27-2010, 07:39 PM   #1261
apg39
Member#: 176612
1990 GL wagon
Obviously you guys have heard of the TD04HLA-19T? The twinscroll version of the TD04 from JDM Gen 4 Legacy? Came on the manual transmission cars only.
I've just installed it all on my EJ205 Forester GT, goes pretty well but I'm yet to see what real numbers it can pull. First tune got 212whp & 331nm at 16psi. Was aiming for 18psi but had to wind it back due to issues with the wastegate, need an upgraded actuator basically. Graphs are in my gallery thread.
I'm guessing this turbo is basically a single scroll version of mine?? Can't really find much info on the TD04HLA-19T.
apg39 is offline   Reply With Quote
Old 06-27-2010, 08:57 PM   #1262
PAImportTuner
Member#: 141669
A EJ205 with
E316G
I heard of the twin scroll td04.. I tried looking for it. It's the g'damn unicorn of subaru turbos
Old 06-27-2010, 09:55 PM   #1263
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
heres his twinscroll td04 link so everyone doesnt have to search
i'd crap myself if i spent money on a twinscroll kit and made 212whp......and thats 212whp on a dynapack none the less.....and hit full boost by 3800rpm.
http://forums.nasioc.com/forums/show....php?t=2012457
Originally Posted by apg39 View Post
Old 06-27-2010, 11:13 PM   #1264
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Being from Australia, he probably didn't spend the kind of money retrofitting for twin scroll that we have to. Remember, they get JDM models that are already equipped twinscroll.
OrbitalEllipses is offline   Reply With Quote
Old 06-28-2010, 12:48 AM   #1265
SilentDoomWgn
Member#: 246729
03 wrx wgn
blue
yeah that seems late on the power. He did say he needed a upgraded actuator. if it opens at will, wouldn't you see weird boost? i have no idea how a twinscroll is affected by that but i would like to see it after its fixed.
is the pre-turbo exhaust all leak free?
Old 06-28-2010, 02:58 AM   #1266
apg39
Member#: 176612
1990 GL wagon
I had to do all the sump, headers, up pipe, downpipe, bracket, oil & coolant lines. Wasn't easy.
That is the smoothest they could get the lines, he did a few 18psi runs but it looked like a heart monitor going right up & down. Waste gate is halfway between cracked & not cracked, it noticeably fluctuates at higher rpm too. Afaik there isn't any exhaust leaks but they would have picked it up.
I'm also only using a WRX TMIC which I'm pretty sure is holding the flow back a little. I'll eventually wrap the headers & have to make a custom heatsheild for the turbo to keep the hot side hot.
Old 06-28-2010, 08:43 PM   #1267
rubinm
Member#: 63483
2005 STi HTA68'd+e85
and........ ForresterWTi goes silent.
what happened did it explode??
rubinm is offline   Reply With Quote
Old 06-28-2010, 09:14 PM   #1268
xsnapshot
Member#: 170973
2004 WRX 4EAT
Just thought I should chime in to say James honored his word and gave me a full refund.
He really gets an A+ for business integrity and honesty in my book.
xsnapshot is offline   Reply With Quote
Old 06-28-2010, 10:59 PM   #1269
SHARP_DAL
Member#: 183247
2005 WRX
^^ I just got my replacement turbo... I'm now thinking that USPS messed up the first one.. The box is destroyed when I got it an there was some shaft play when I first received it.. This version the shaft play is almost non existant and the box and packaging was much better..
Anyhow.. the turbos going on this weekend.. I feel like a cripple driving my car with no boost... minivans have been cutting me off and giving me attitude for accelerating too slow...
Old 06-28-2010, 11:14 PM   #1270
xsnapshot
Member#: 170973
2004 WRX 4EAT
^nice. Glad its rebuilt and all.
I actually haven't driven my car at all since the first failure, but have been driving my Ford Explorer instead. I'm REALLY craving some decent acceleration, but I didn't want to put back in either of my stock turbos, since one is bad, and the other has been sitting for so long.
I did discover that a 190 hp V6 Explorer CAN do a burnout, albeit short and not that exciting
Old 06-29-2010, 05:24 PM   #1271
rcodea
Member#: 225115
09 WRX
i am smoking again...not nearly as bad yet though...and i am not sure its the turbo...may be the engine...need to get a catch can to eliminate the possibilities....
reason i think this may help is because of the massive amount of blow by i have noted since owning the car. any time i take the intercooler off, there is a small amount of oil in the 'hump' tube between the intercooler and throttle body. i have found this any time i take the intercooler off, no matter what turbo i have, or condition of that turbo.
the smoking started today, coming home from work. it has not smoked since getting this turbo on this past Saturday. i have done freeway, city, agressive driving, etc. I am at the point of swapping the wastgate actuator and adjusting it to the needed 15psi. i was planning on putting the MBC on it tonight and start making adjustments and logs to get to my goal of 20psi through redline.
valve stems have never been an issue, and remember, the leak check showed no leaks at all.
~Ryan
Old 06-29-2010, 06:08 PM   #1272
xsnapshot
Member#: 170973
2004 WRX 4EAT
~Ryan
well if its the turbo, you'll know soon enough I'm guessing.
Does it just smoke visibly at idle? (Decel, accel, etc?)
The thing is, a catch can is only going to solve problems of oil vapor getting through the crankcase/valve cover breather vents and into the inlet. If its coming through valve stems, or burning oil, etc, then a catch-can wouldn't help anyway.
Old 06-29-2010, 07:20 PM   #1273
PAImportTuner
Member#: 141669
A EJ205 with
E316G
x2 updates
Old 06-29-2010, 10:20 PM   #1274
rcodea
Member#: 225115
09 WRX
right now it is just smoking at idle. this is the same way it started with turbo #1...progressed over the next 300 miles to the point of looking like a blown motor, but running like a top.
stems, burning oil, rings, etc would not progress like this...not be this drastic of a change.
a catch can will help me troubleshoot to make sure its not massive blowby
~Ryan
Old 06-29-2010, 10:24 PM   #1275
rcodea
Member#: 225115
09 WRX
i need to seriously think about how/why my car is killing so many turbos...something cant be right...doesnt smoke with the stock td04 i have...so the best thing i can do is let it get worse, then change to the stock td04 and see what happens.
~Ryan
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 08:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 08:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 10:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 01:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 07:19 PM
