Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 05-05-2010, 11:58 AM   #126
Davenow
Member#: 23676
Originally Posted by wrxsubiemod View Post
^ LOL OK I give up. 20gs cant make 400. OK better start a new thread in the power braggin section and call out the liars
On a HIGH reading dyno, when pushed HARD, a 20G can touch 400 on pump gas.
On a realistic dyno, on pump, pushed normally, you are looking at somewhere around 360-380. On a low reading dyno, you are looking at 300-340. Yes there are dynos that read that low.
If you want a true 400, you need to be looking at a 30R.
Davenow is offline   Reply With Quote
Old 05-05-2010, 08:00 PM   #127
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
best bang for the buck right now for me is to go this route with higher octane fuel. Thanks for every ones help and sorry If I sounded like such a noob im really not just wanted advice. Thanks again
Old 05-05-2010, 08:32 PM   #128
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
ahoy subiemod! for those numbers you will definetly need meth at the min. possibly larger injectors and probably some bc "272's". also on that ppb page you'll notice that there is no description of the 20g other than "special sauce" and later in pauls description says it's a td06. i see your rockin a td05 with the 7cm2 housing. the other red herrring in that thread is paul posted in there stating it's basicly a factory freak as most td06 20g's on pauls dyno (dynojet fyi, but scv is slightly higher elevation) pull about 360-370. for 400 i'd say a dom 3.0xtr minimum.
i hope some of that was somewhat helpful.
are you tuning at hb? reason i ask is jeebus's dyno reads closer to a dynojet.
mongoosaroo is offline   Reply With Quote
Old 05-05-2010, 09:15 PM   #129
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Dude, that was a good answer. Thank you. Im going to YIMI for a tune, they have been helpful every step of the way. I have had problems with HB speed in the past no offense
Old 05-06-2010, 03:36 PM   #130
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
none taken! differnet ways to skin a cat to get similiar results imo. pauls a very knowledgable guy and definetly knows what he is doing. from my experiance his dyno reads about 3% lower than jons (elevation) and as oppose to fuel for spooling paul prefers timing in the low end for spool up. when do you tune?
Old 05-11-2010, 10:08 AM   #131
BirdJ77
Member#: 243365
2008 STi
Have an 08 STi used as a DD. Would like to hit between 300 and 320 whp and not opposed to more if there are suggestions on some mods. Here is the info. Can anyone help me out?
1. 300-320 - whp
2. Dynojet 424 AWD in ground dyno.
3. IAG Peformance. Jorge will be doing tune.
4. Baltimore, MD
5. 93 Octane
6. Not opposed to FMIC but will be keeping stock turbo for a good while so is it really needed? If so I'm not opposed to it but like others have said, I'd like to keep the change in my pocket.
Current mods:
Cobb AP Stage 2 93 oct
Invidia Catted DP
Maddad Whisper Cat Back
GT Spec Gen II header - 2 or 3 weeks to install
Tial MVS 38mm WG -2 or 3 weeks to install
Up Pipe - 2 or 3 weeks to install
AEM CAI
1 step colder plugs
Grimmspeed 160 degree thermostat
Looking to get tuned sometime in June. Probably not going for a balls out tune as this is a DD. I also know I need the tune for EWG. Once that is installed I will be limping on a map until I can get tuned. Just looking to see some opinions on what I might realistically hit. Thanks guys.
BirdJ77 is offline   Reply With Quote
Old 05-11-2010, 11:43 AM   #132
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
1. 300-320 - whp
4. Baltimore, MD
5. 93 Octane
Current mods:
Invidia Catted DP
AEM CAI
1 step colder plugs
On that dyno- those mods with a professional tune will make those numbers.
Audiosavvy is offline   Reply With Quote
Old 05-12-2010, 08:57 AM   #133
BirdJ77
Member#: 243365
2008 STi
Thanks Man. I kinda figured it would but I'm nowhere near realing knowing exactly what I'm doing besides from what I read and fumble F whatever project it is. Saying I wanted to go another 20 to 30 whp what would you think would be the next logical step?
Old 05-12-2010, 12:37 PM   #134
rexblake
Member#: 178426
2010 S4
Gray
Higher octane, E85 or water/meth.
Old 05-12-2010, 08:43 PM   #135
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
what does a stock sti read on that particular dyno?
Old 05-14-2010, 08:14 PM   #136
roman23pierce
Member#: 243717
Newbie here, went tuning last nite, max out on my injectors, abt 93%, but the tuner told me dat, the injectors shown irregular figures, it cld be a prob wit the injectors or the AF sensor, coz my AF sensor shows no difference in figures, even if i go full throttle.
There's a few prob nw, my meth kit was nt performing as good, the flow aint dat good, i predict the hoses got stuck somewhere, rectify (i tink)
Then there was a knocking sound, somewhere underneath the driver seat (righthand driving), it was actually due to the 3 inch downpipe knocking onto the stock mid lateral bar (i tink dats wat they call it), rectify it by lengthen the bracket.
So due to the above mention probs, my tuner told me that he will re-tune it once everything is rectify, so guys any advise on the above mention probs?
In the beginning of the tunning, it was running well, good flow of meth, boosting at 1.55 bar, full boost at 4100rpm.
According to my tuner, if i cld run perfectly as the above mention, i cld get about 300whp. Is this true? On road tunning.
Tunning on Open source.
Mods:
Blouch Big Evo 3 16G, Tomei equal length extractor and up pipe wrap wit thermo wrap, 3 inch downpipe, (red color) Sti intake manifold, MY07 Wrx 560cc top feed injectors, sard fuel regulator, Walbro fuel pump, coolingmist meth kit, using juran funnel cool air intake through stock air box using drop in hurricane filter, TGV delete, samco hoses, titanium fuel rail, Sti dumbvalve, MY08 Sti top mount intercooler, HKS oil cooler, Blitz ATF cooler. Open Source Tuning.
Juz install 750cc DW last nite.
roman23pierce is offline   Reply With Quote
Old 06-01-2010, 12:30 AM   #137
Cracka J
Member#: 247513
dark
Generalistically speaking what kind of power can i expect out of a VF34 turbo set up? With a 2.0
Cracka J is offline   Reply With Quote
Old 06-12-2010, 06:25 PM   #138
junior1023
Member#: 223393
2015 WRX
Dark Grey Metallic
Just seeing if anyone knows what kinda power I could/should expect from this set up onced tuned (just a ballpark?) 2002 WRX
Cobb short ram intake
SR*S catback exhaust
Invidia catless downpipe
Up-pipe (TBD)
STI topmount IC (would this even make much a difference to justify the cost?)
junior1023 is online now   Reply With Quote
Old 06-12-2010, 10:06 PM   #139
rexblake
Member#: 178426
2010 S4
Gray
That's almost exactly like my stage two setup. Obviously it's going to depend on the dyno, but figure between 200-250 at the wheel.
Old 06-12-2010, 10:57 PM   #140
TiredGXP
Member#: 245040
2010 Legacy GT
I have a 10 LGT that is a DD. I'm looking for 280 to 300 whp. Enough for now at any rate, we'll see how the addiction goes .
1. 280-300 - whp
2. Airboy Road Dyno (not sure if there even is an AWD dyno in Edmonton these days).
3. Me - pending a Romraider definition for this ECU. Possibly AccessTuner Race
4. Edmonton, AB ~2,200 ft
5. 91 Octane - it's what we have around here. There may be 18 locations in the entire province with 94 octane ethanol blend; it's not common enough to risk tuning for it.
6. Want to keep the TMIC. With the low, front mount turbo on the 10 LGT, heat soak *may* be less of an issue from earlier models.
Current mods:
STi STS
Proposed mods:
TMIC
TBE (none currently available)
Coolingmist CMGS-FS water/meth injection
This is probably a project for next summer. I haven't been able to find much info on the VF54, so not sure how far that turbo can be pushed.
TiredGXP is offline   Reply With Quote
Old 06-21-2010, 10:24 AM   #141
balls2dawalls
Member#: 248432
06 VF39 WRX TR
San Remo Red
Sooper noob to soobies here
06 WRX TR
1. I'd like 300-350 whp reliably!!! It's my dd
2. No idea what dyno I'd be using!! I'm in central, IN though. I essentially want 100-150 whp over stock. This thing is slow!
4. Central Indy or Purdue
5. 93 octane year round
6. Definitely not opposed. I like the Perrin stealh FMIC
Current mods
3" nameless catback. No resonators 0.o super loud
Cobb intake
Stage 3 clutch
Short shifter bushings
Tien s-techs -__-
You can see my trend here. I wanna go cheap, and I wanna go fast. But obviously, I always put the bet of the best into my cars and remain reliable on a day to day basis, hence why I don't want insane amounts of power.
Sent from my iPhone using Tapatalk
balls2dawalls is offline   Reply With Quote
Old 06-21-2010, 10:31 AM   #142
balls2dawalls
Member#: 248432
06 VF39 WRX TR
San Remo Red
It'd also be nice to know a good order to do my modding, that way I progress my way up and the car is never down for a long period of time, and I start experiencing my results afte each mod. Make sense? My ideas (although I know nothing) are to do STi ball-bearing turbo, DP, and up-pipe all at once. Then MBC, Cobb AP, and AFR/boost guages. Those should be some significant improvements, and this gives me time to do my little exterior mods here and there as well. I was thinking then headers/fmic/bov/fuel pump/rails/injectors. That last wave I just stated will probably be a year or two from now lol, but this wrx just seems so sluggish on stock turbo
Old 06-21-2010, 04:54 PM   #143
gonzoactive
Member#: 77976
Default Performance:Cost:Reliability
I thank Defiant Autospeed for their post.
Has anyone made a chart showing performance:cost: reliability to get a relative idea of how much fun I can afford?
gonzoactive is offline   Reply With Quote
Old 07-01-2010, 01:49 AM   #144
knutsford
Member#: 250847
2002 WRX Rally Pig
World Rally Blue
Hey so I have a 2002 WRX and it has the following mods on it:
FMIC
Tial Wastegate
HKS Superflow Intake
Perrin Up pipe
Perrin Down Pipe
Unknown 3" Exhaust turbo back with custom axle back setup with a 4" outlet
2.0L
Stock Turbo as well.
Lowered on Perrin springs as well just fyi.
Basically I am just wondering what kind of numbers I can expect this to put down?
knutsford is offline   Reply With Quote
Old 07-01-2010, 01:52 AM   #145
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
FMIC
Tial Wastegate
Perrin Up pipe
Perrin Down Pipe
2.0L
Not exactly an idea setup. I would recommend removing the FMIC and the HKS intake.
What dyno?
Byzantium is offline   Reply With Quote
Old 07-01-2010, 01:15 PM   #146
Davenow
Member#: 23676
meh I wouldn't remove the FMIC< I would just turn the boost up another 2PSI and take advantage of the cooling.
The intake, I would tune the car, and if the fuel trims are stable, I would build some sort of heat sheild for the intake, and keep it.
As for what kind of numbers, you are looking at numbers slightly over a normal stage 2 setup, assuming you run the typical 17-18PSI. With a FMIC I would run 19-20.
But at the normal boost pressures, on an semi high to AVERAGE dyno, you are looking at something in the 220-225 range. Up the boost another 2PSI and you should hit mid to upper 230s no problem (on the same dyno that is).
On a heartbreaker, more like 200. On a WAY high reading dyno, lower 240s.
Old 07-01-2010, 02:57 PM   #147
knutsford
Member#: 250847
2002 WRX Rally Pig
World Rally Blue
Mustang Dyno at Kito Auto Sport in Seattle.
The car was like this when I got it, all I have done is get the custom axle back put on. It will get tuned next Thursday so I will be sure to post on here what it does.
If not the HKS intake? Suggestions as to what I should get?
Thanks.
Old 07-01-2010, 03:05 PM   #148
Byzantium
Member#: 207826
85k 2002 WRX
Well the entire strong point behind the stock turbo is it's responsiveness, something that's being sacrificed by the FMIC he's running. Somehow I doubt he's running enough boost to take advantage of the FMIC, even if he "turns it up 2 psi".
As for the intake, HKS intakes are of awful build quality and the filters they use might as well not even be put on with how well they work.
http://www.mkiv.com/techarticles/filters_test/2/
Old 07-01-2010, 03:23 PM   #149
knutsford
Member#: 250847
2002 WRX Rally Pig
World Rally Blue
@Byzantium
Thanks the article was very helpful and informative. I had no idea Apexi was so much better quality than the other better known brands.
What are your thoughts on cold air vs "hi-flow" intakes?
Old 07-01-2010, 03:37 PM   #150
Byzantium
Member#: 207826
85k 2002 WRX
@Byzantium
You mean cold air vs short ram air? I'm personally partial to cold air intakes simply because the air is slightly cooler (with a heat shield on a short ram air it's pretty close), less engine bay clutter, and in my experience, it seems like the filter doesn't get as dirty as fast (with the splash guards in place of course).
I run a SRI right now but only because my FMIC doesn't allow for a CAI and I haven't bothered to have any custom intercooler piping made up to correct for that.
So basically the picks you want to make are a CAI or a SRI with a heatshield.
What do I need to hit 350-375 HP? pipchick Newbies & FAQs 51 02-04-2016 10:19 AM
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
what do I need to hit 250whp? juvenescence Newbies & FAQs 27 10-07-2009 10:47 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
