Old 07-01-2010, 04:42 PM   #151
knutsford
Member#: 250847
2002 WRX Rally Pig
Originally Posted by Byzantium View Post
You mean cold air vs short ram air? I'm personally partial to cold air intakes simply because the air is slightly cooler (with a heat shield on a short ram air it's pretty close), less engine bay clutter, and in my experience, it seems like the filter doesn't get as dirty as fast (with the splash guards in place of course).
I run a SRI right now but only because my FMIC doesn't allow for a CAI and I haven't bothered to have any custom intercooler piping made up to correct for that.
So basically the picks you want to make are basically a CAI or a SRI with a heatshield.
Be prepared, noob question: How would I know if my FMIC would allow for CAI?
knutsford is offline   Reply With Quote
Old 07-01-2010, 04:48 PM   #152
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
What FMIC do you have?
Byzantium is offline   Reply With Quote
Old 07-01-2010, 05:14 PM   #153
knutsford
Member#: 250847
2002 WRX Rally Pig
The guy I got it from said it was a HUGE FMIC.
Old 07-01-2010, 05:32 PM   #154
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
No offense, but that doesn't help us at all. We need to know exactly which one it is. However, almost (ALMOST) any FMIC can accomodate a CAI, but it may have to be custom-made.
I have the AVO FMIC, and any CAI for it would have to be custom (even then I'm not sure it would be possible).
Audiosavvy is offline   Reply With Quote
Old 07-01-2010, 07:00 PM   #155
knutsford
Member#: 250847
2002 WRX Rally Pig
Thats funny because I thought the same thing when I saw that he said it was a HUGE FMIC. It's cool but doesn't help me learn about it. Same with the turbo back, for whatever reason it only went to the midpipe and had nothing from the axle back when I got it. Needless to say it was very loud and made people turn their heads even more.
I will see what I can find out though. Thanks to you all for the advice.
EDIT: I talked to the guy's at KAS and they said that it looks like an ESS FMIC but not 100% sure.
Old 07-01-2010, 07:17 PM   #156
Byzantium
Member#: 207826
85k 2002 WRX
Post a picture, hood up, of the front of the car.
Old 07-01-2010, 07:31 PM   #157
knutsford
Member#: 250847
2002 WRX Rally Pig
Hope those work for you, if you goto my photobucket there are a bunch more pics up.
Old 07-01-2010, 10:21 PM   #158
Byzantium
Member#: 207826
85k 2002 WRX
That's one of the many generic TurboXS FMIC replicas. No, you cannot run a CAI with that piping. And it's installed wrong because it should have fit without having to cut the foglights out.
Old 07-02-2010, 04:26 PM   #159
knutsford
Member#: 250847
2002 WRX Rally Pig
Ah well that sucks. In any case my friend and I are going to patch the holes where they cut the fogs out.
So it looks like its SPT piping with an HKS filter so I might just get a better filter and stick it on and potentially make a heat shield for it.
Old 07-02-2010, 04:29 PM   #160
Byzantium
Member#: 207826
85k 2002 WRX
That will work.
Old 07-09-2010, 10:15 AM   #161
balls2dawalls
Member#: 248432
06 VF39 WRX TR
San Remo Red
Hey all,
So I have a 4" TurboXS bellmouth DP, 3" exhaust from there back, Cobb SRI, and I have an OS tune from a local guy scheduled for august 8th. I plan to have a gauge cluster installed by then: AFR, boost, and oil pressure. I'm also wanting to install an MBC to turn the boost up. My 06 WRX feels slow as hell haha. What kind of boost is recommended for my stock turbo that will be quicker, more efficient, yet still not too bad for the car. Also what kind of power am I expecting from these mods?
balls2dawalls is offline   Reply With Quote
Old 07-09-2010, 12:46 PM   #162
Davenow
Member#: 23676
If you are just going to run 93 pump gas, with no intercooler upgrade (which the 06 WRX DESPERATELY needs), I would run no more than 17PSI. With an STI TMIC 19PSI sounds like a nice round number, as long as you are tuned for it.
Many people will tell you an MBC is evil and will blow your car up. It can, UNLESS you tune for it.
If you get the MBC, then have the car tuned for the new higher boost level, it will be perfectly safe. Use a GOOD mbc, I highly recommend Hallman.
Old 07-09-2010, 01:27 PM   #163
Davenow
Member#: 23676
Also, if the AFR gauge you have is not a wideband, take it out and sell it. It is completely useless, 100%, tells you NOTHING. It simply cant read where you need to be. When it says full rich, you can be DANGEROUSLY LEAN.
Old 07-09-2010, 02:46 PM   #164
balls2dawalls
Member#: 248432
06 VF39 WRX TR
San Remo Red
So a noon question to elaborate on your replies (thank you by the way)... What is the difference between a wideband and an AFR gauge? I actually was actually thinking about 18 lbs with an STi TMIC. is it really necessary to replace the stock turbo for what I'm going for? I feel like I should stick with what I've mentioned for now. If I'm gonna go FMIC, new turbo, fuel, etc... I should do all of that at once at a later time. I don't want to blow too much money on performance and not be able to replace my 5 sp when it blows (I've got a stage 3 BS clutch that came with the car)
Old 07-19-2010, 01:19 PM   #165
cityazndan
Member#: 250739
1. HP at the WHEELS (whp) or hp at the CRANK (chp)? ~300whp
2. What type of dyno are you going to be shooting for this number on? Not sure...I think I'm gonna get it tuned at Andrewtech or DPS.
3. If possible, tell us what shop it is. Someone may know how high or low that particular dyno reads. DPS or Andrewtech
4. Where do you live? If not a well known city, what is the elevation?
Maryland
5. What kind of gas will you be using? (octane level)
93 Octane
6. Are you opposed to a FMIC?
Eh...if I can hit 300whp without it, I rather stay TMIC.
7. It's an DD Auto.
Current Upgrades:
Perrin Uppipe, Perrin Downpipe, Cobb AP2 (on the way), Cobb Intake (on the way)
cityazndan is offline   Reply With Quote
Old 07-19-2010, 03:44 PM   #166
rexblake
Member#: 178426
2010 S4
Gray
Fill out your profile. We need to know model and year. Also, call the shop you are getting tuned at and ask. They will have a much better idea than we will.
Maryland
93 Octane
7. It's an DD Auto.
Current Upgrades:
Old 07-19-2010, 04:17 PM   #167
Davenow
Member#: 23676
Maryland
93 Octane
7. It's an DD Auto.
Current Upgrades:
Andrewtech's dyno is just like TurboXS's dyno (it may actually be the same dyno, Im not sure) It reads fairly high.
You can do 300whp on their dyno with an IHI turbo on 93 octane with a good intercooler and 22 or so PSI. MUCH easier if its a 2.5L car. The 2.5L cars hit 300whp without much more than stage 2
If you are on a 2.0L, go with an EVOIII-16G and a GOOD tmic. This means turboXS or better. No ebay, xCC, godspeed, $400 tmic.
If you are on an STI, go with a full turboback, an up pipe, ported/polished exh manifold and call it a day.
If its a 2.5L WRX, do the same, but go to an IHI turbo.
Old 07-20-2010, 12:21 AM   #168
cityazndan
Member#: 250739
i have a 2004 wrx auto tranny...so i got the 2.0l block. with the new turbo, comes all the stuff you need to upgrade like injectors, fuel pump, etc. no exhaust to hit 300whp?
Old 07-20-2010, 12:43 AM   #169
Byzantium
Member#: 207826
85k 2002 WRX
Andrewtech does not have a dyno nor do they tune (though there is someone who knows how to tune there). They will send you to TurboXS, which is down the street from them. [edit: Dave beat me to it]
DPS does not have a dyno either from what I remember.
Old 07-27-2010, 12:06 PM   #170
cityazndan
Member#: 250739
TurboXS got back to me and listed the parts.
Engine Managemnt
Full TurbobackExhaust
Intake
550cc Injectors
Walbro Fuel Pump
18g Turbo
Upgraded Top Mount Intercooler
does that sound about right? or is it a bit overkill (i think just the fuel pump would be fine, i have access to 93 gas)....and I prolly need to reinforce/upgrade my tranny. Valvebody, cooler, (one other thing...maybe the clutchpacks themselves?)
Old 08-06-2010, 10:21 AM   #171
thirdlobe
Member#: 218012
07 STI
Guys,
I am looking at picking up a 2004 WRX from a member off this board. Here are some of the mods that he has listed:
Motor & exhaust:
-Stock turbo 2.0L
-godspeed FMIC kit
-tial bov
-forge boost controller
-perrin inlet hose
-k&n cold air
-4" downpipe to full 3" hks hi-power. No cats no o2's. (i have the stock exhaust to go with car)
He claims to have made 235whp 240wtq on 17psi. I dont know what type of dyno he used but he is located in CT.
I live in FL where we dont have emissions and 93 oct fuel. I will be dyno'ing at a place called AWD Motorsports because they are one of the few places in my area with a 4WD Dyno Jet dyno.
I would like to get 350 horsepower on a daily driven car with reliability. I am traditionally a Honda guy and have been for more than 8 years but as my life has it I have a family now and in need of a 4 door car. I really enjoy the messaging that Subaru has with safety and reliability so thats why I choose to go this route.
So with all that being said... Any help, would help immensely.
Thank,
Phil
thirdlobe is offline   Reply With Quote
Old 08-06-2010, 01:03 PM   #172
rexblake
Member#: 178426
2010 S4
Gray
If they recommend it it's not overkill. They are experts when it comes to knowing what it takes to make xx amount of hp on their dyno. Go with what they say.
Originally Posted by thirdlobe View Post
Guys,
Motor & exhaust:
-Stock turbo 2.0L
-godspeed FMIC kit
-tial bov
-perrin inlet hose
-k&n cold air
Thank,
Phil
Are you wanting 350whp or crank hp? 350chp would be pretty easy to do reliably. 350whp is going to take a lot of work to make it reliable.
Also, if you have a budget for the build, that would be helpful to know as well.
Old 08-06-2010, 01:08 PM   #173
thirdlobe
Member#: 218012
07 STI
I am looking for 350whp. I do have a budget of about 3500 to get there with the mods that are already on the car.
Thanks,
Old 08-06-2010, 01:09 PM   #174
Byzantium
Member#: 207826
85k 2002 WRX
Guys,
Motor & exhaust:
-Stock turbo 2.0L
-godspeed FMIC kit
-tial bov
-perrin inlet hose
-k&n cold air
Thank,
Phil
235 whp is very plausible for that setup if it's tuned (did he say?). That FMIC is a bit out of place and could be bit detrimental to driving performance. If you're looking for 350 whp, good luck with your reliability goal without building your engine and transmission. If you meant 350 chp (275 whp), assuming the car doesn't have high mileage amd wasn't abused (in general the engine being in good shape), easily done.
Old 08-06-2010, 01:20 PM   #175
thirdlobe
Member#: 218012
07 STI
235 whp is very plausible for that setup if it's tuned (did he say?). That FMIC is a bit out of place and could be bit detrimental to driving performance. If you're looking for 350 whp, good luck with your reliability goal without building your engine and transmission. If you meant 350 chp (275 whp), assuming the car doesn't have high mileage or was abused (in general the engine being in good shape), easily done.
I am looking for 350whp. I was reading in the FAQ's and they said that 400whp was the point where these motors need to be built and thats why I thought 350whp would be fine.
The car has a V.8 STI 6 speed tranny in it now.
What do I need to hit 350-375 HP? pipchick Newbies & FAQs 51 02-04-2016 11:19 AM
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-15-2010 12:49 AM
what do I need to hit 250whp? juvenescence Newbies & FAQs 27 10-07-2009 11:47 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 07:43 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 11:11 PM
