Old 07-01-2010, 04:28 PM   #1
Sti77
Member#: 93673
2004 WRX STi
Java Black
Default 4G63 vs EJ25
I owned a 2004 STi when they first hit the shores and spent ~$10k in APS parts, labor, and tuning to hit the 400awhp mark. Second baby showed up and I had to sell it a year later.
Following summer I picked up a 2004 EVO and did some minor mods - CAI, TBE, fuel pump, and a tune and hit the 295awhp mark. Third baby showed up and I had to sell it a year later.
Now I'm not having any more kids and want to pick up a another one but I'm having a struggle. This car will be a third, stored car, that will be modified heavily over the years. Still streetable, but I'd like to break the 600awhp mark. I spend a lot of time here and at evolutionm and over time I have found it shocking the difference in power gains mod for mod between the two.
Here are some examples of stock turbo and motor evos making over 400awhp when running E85.
http://forums.evolutionm.net/evo-dyn...rbo-hp-tq.html
Looking here, many 35R EJ's are making just over 400awhp, some even on built motors. My point isn't to start a flame war, but to understand what mechanically is causing the difference? Is it soley turbo placement and engine layout? I did a search but the only thread was from 2002.
I really love the subaru - the sound, refinement, look, tranny, etc. is awesome. However, I can improve the performance of the EVO for a fraction of the price.
Thanks for any insight...
Oh, and I'm not a big fan of the 4B11T/EVOX, so that is out.
Sti77 is offline   Reply With Quote
Old 07-01-2010, 04:41 PM   #2
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
This has been covered. A lot. do a search.
4G:
Iron block = stronger
I4 = better spool
EJ:
aluminum block, even semiclosed, isn't as strong
H4 = LONG exhaust path to turbo as well as for IC
More displacement is nice.
But if you are going to build something.... either way its gonna be a built motor, so who cares about stock anything. STi tranny is better, other drivetrain parts are a wash.
Buy what looks better.
DiscoGsus is offline   Reply With Quote
Old 07-01-2010, 04:43 PM   #3
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
IIRC the 4G63 Evos have a 10cm^2 turbo hotside too. Whereas ours is what, 7cm^2?
Old 07-01-2010, 04:46 PM   #4
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
this!
The evo turbo is as big as 20G and is Twin Scroll. Give me a 20G and I promise my car will make 400whp on E85 and trap 126-128mph. Just like the fastest stock turbo EVOs. If someone is looking 500whp + and EVO is a must
Old 07-01-2010, 04:48 PM   #5
corzy666
Member#: 177840
2000 swapped RS
White 330whp
I think a evo 8 or 9 with a built 4g63 would be better suited for you.
The things you like about the Suby
-Sound: with a 600whp subaru you will need equal length or twinscroll, so the boxer sound will most likely be gone.
-Refinement/Look: they both look somewhat similar :P
-Transmission: you would probably have to put straight cut in either.
And for the price it would be way easier/cheaper to achieve your goals with a 4g63.
corzy666 is offline   Reply With Quote
Old 07-01-2010, 04:54 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I-4 has nothing to do with spool.
Realistically these motors are VERY different, so much they aren't even worth comparing.
Rod ratio, bore/stroke ratio, compression ratio, cylinder head port symmetry, block strength, combustion chamber shape, charge and discharge coefficients, flowrates, thermal efficiencies...
due to layout of the engine however, they can have quicker spool and an even exhaust pulse much more easily than an EJ. Those are big for comparing the two motors in a street and race application. Their block in OEM form (still 85mm bore) allows for 40+psi boost where as a stock EJ257 is limited to a little over 30 or so. The 4G can run taller lift cams with more aggressive ramp rates. I.E. They can get easy power through lots of boost and big cams.
Comparing stock turbos, the TD05HR-16G smokes any stock subie turbo...but that is a moot point as you're looking for the 600 realm.
Old 07-01-2010, 04:55 PM   #7
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
I believe the only question in the OP is what causes the difference in mod for mod performance?
Answer: VE
Mods you can close now.
OppositeLock is offline   Reply With Quote
Old 07-01-2010, 05:00 PM   #8
mitsutraitor
Member#: 249620
2007 sti
urban gray
It really is comparing apples to oranges. If you really want cheaper hp get a dsm gen1 and go old school. I love the 4g63 but I prefer the fit, finish, and feel of the sti over the evo. just my opinion.
mitsutraitor is offline   Reply With Quote
Old 07-01-2010, 05:06 PM   #9
BenGSX
Member#: 210061
Eh.. Spent 10 years in the DSM/Evo Arena.. Now I drive an 11 second scoob..
4g63>ej.. Stronger block, better flowing head, greater VE.. Etc etc etc..
But really who cares?
Either route can net similiar results built properly.. Until you start to cross that 1000 hp threshold.. There are plenty of mid 1k HP 4g63's.. Not so many ej's..
So as long as you arent shooting for 1500 hp.. Again.. Who cares? Pick the vehicle that suits you better.. Personally I love my Suby..
BenGSX is offline   Reply With Quote
Old 07-01-2010, 05:27 PM   #10
Corinator
Member#: 211974
2004 WRX STi PTE6466
2002 Sentra SE-R Spec V
I would just sell my STi and get a 03/04 mustang cobra and for 10k get a 3.4L whipple supercharger and all the supporting mods and be churning out 800 ponies on E85. Just my opinion lol. Also a great deal more reliable.
Corinator is offline   Reply With Quote
Old 07-01-2010, 06:27 PM   #11
PuffKevinFizzle
Member#: 207021
99 OBS
^^Dont do this.
PuffKevinFizzle is offline   Reply With Quote
Old 07-01-2010, 07:25 PM   #12
fourmicah
Member#: 128760
2017 STI
^^^ what he said.
fourmicah is offline   Reply With Quote
Old 07-01-2010, 07:33 PM   #13
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Originally Posted by PuffKevinFizzle View Post
^^Dont do this.
Originally Posted by fourmicah View Post
^^^ what he said.
PuffKevinFizzle and fourmicah have apparently never experienced brute v8 power before... a 3.4 whippled cobra will make you wet your pants if done right
power per dollar a v8 is the way to go... also take a look at a c5 zo6 ...you can get them for about 20-25k if you look around. A zo6 handles pretty good and will rape bolt on sti's/evos ...trust me, ive seen first hand over 100 times
All4bSpinnin is offline   Reply With Quote
Old 07-01-2010, 07:45 PM   #14
PuffKevinFizzle
Member#: 207021
99 OBS
^^Apparently you dont realize his question was not about how sweet v8 supercharged whipple nipple blah blah mustangs are. So lets keep it on topic.
Old 07-01-2010, 07:59 PM   #15
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
actually, do this
if you want massive power and reliability the 03-04 cobra is awesome, and after the maximum motorsports grip kit, brembos, and some 17x11 with 315/40/17 all the way around, your handling and braking will not be an issue
once again its all about preference
i'd take the 4g63 and stroke it
feint05 is offline   Reply With Quote
Old 07-01-2010, 08:03 PM   #16
kevosnowsti
Member#: 202097
2001 Subaru 2.5rs
BRP
the 4g63 is stronger and can handle much more boost.
man, sometimes I wish I would have gotten an Evo, I'd already have the power I wanted without spending thousands.
kevosnowsti is offline   Reply With Quote
Old 07-01-2010, 08:14 PM   #17
bertune
Member#: 107290
bertune is offline   Reply With Quote
Old 07-01-2010, 08:17 PM   #18
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Quit screwing around and buy a real track car. ZO6.
C J is offline   Reply With Quote
Old 07-01-2010, 08:55 PM   #19
Copper Rex
Member#: 53721
35R Bugeye
[email protected]
^^^ Wat he said. buy a zo6 and slap a turbo kit on it. 600+ WHP @ 10lbs of boost...lol. no replacement for displacement. all jokes aside tho. im a proud owner of a 35r ej, and from the route ur tryin to go and my personal experience go with the EVO.
Copper Rex is offline   Reply With Quote
Old 07-01-2010, 09:01 PM   #20
spooln407
Member#: 97054
MY05 WRX
4th gen toyota poopra easy power
and what the guys above me said. supercharged/turbocharged Z06s are ridiculous =D
spooln407 is offline   Reply With Quote
Old 07-01-2010, 09:21 PM   #21
Sammidavis
Member#: 189756
2000 Gc8 v7 STi Swap
[email protected] s366 2.35ltr
Here is a good compare this is a video of a small 2-3rd pull
This is my 00 RS sti swapped ej207 2ltr fully built 278/274 cams s366 powered VS my friends fully built motor 280/280 cams 4g63 eclipse also running a s366 turbo and we are both running the almost exact boost 23-24psi on 98 pump
Cars perform amazingly similar
this is not a street race just a pull on a closed road out of town
Sammidavis is offline   Reply With Quote
Old 07-01-2010, 09:50 PM   #22
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
^^^ Ej207>ej257 ^^^
CKxx is offline   Reply With Quote
Old 07-01-2010, 10:29 PM   #23
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
rev limit vs torque?
they end up being equal no? well, in stock form.
bored out 207 w/ big port heads > bored out 257 w/ usdm heads.
257 w/ 207 heads = win.
i will own an evo someday but will be parking it next to my subaru. i am certainly looking forward to building a dsm or an 4g63 in race car form.
Old 07-01-2010, 10:38 PM   #24
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
if you get an EVO your life will be alot easier
if you get the subaru, atleast you can come on here and bitch when it blows up
Old 07-01-2010, 10:55 PM   #25
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
maybe he should get a lexus ^^^.
did you move yet steve? i wanna make sure we do some pulls in my car before you bounce.
4g63 vs the EJ e[tx] Built Motor Discussion 15 06-10-2009 04:28 PM
EJ25 sohc vs EJ25/22 Frankenmotor jamesbissland Subaru Conversions 3 09-30-2006 05:11 PM
EJ22 vs. EJ25 advance Normally Aspirated Powertrain 9 05-25-2001 07:35 AM
EJ20 vs EJ25 (Turbo vs Turbo) MagicMT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-23-2001 11:52 AM
Putting the EJ20/22 turbo vs EJ25 turbo debate to rest! Andre Vandenberg Technical Forum Archive 42 06-04-2000 07:53 PM
