Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 07-05-2010, 03:48 PM   #1351
PAImportTuner
Member#: 141669
A EJ205 with
E316G
xsnapshot any p0244 codes?
PAImportTuner is offline   Reply With Quote
Old 07-06-2010, 03:08 AM   #1352
ForesterWTi
Member#: 173892
2005 3.0R SpecB 1of1
grandma gold
Just curious...
I went looking around to see who sells an H or HL side wheel, this all was sparked by looking for a VF29 and a VF23 to dabble with . I REALLY like the VF29 (V6 STi's turbo?) it's pretty much our TD04 but puts out more CFM's. Look at this link: http://www.clubwrx.net/forums/engine...oe-td04-2.html (Post #27,#29) This curve is SIIICK! I think that the VF23 is wicked in terms of "small turbos". This is a sleeve bearing turbo with a 467 comp wheel and P18 Turbine Housing. IHI VF 24/28/29 ----- 410 CFM at 14.7 PSI <--- estimated. IHI VF 24/28/29 -- 425 CFM at 18 PSI <--- estimated. Forced Performance has a 3000GT/Stealth 13G turbo BUT for $1390, and offer wheel combos including: Mitsubishi 15G-HL and Mitsubishi 19T-HL BUT for $525. Haha, now I know that those prices are just out of this world, but Scooby921 had a shop build his 19T in his TD04...
what do you all think about a 15T-HL upgrade for the TD04???
I really do want that epic fattt midrange ooomph
Cheers,
~Wolf
WT
ForesterWTi is offline   Reply With Quote
Old 07-06-2010, 03:41 AM   #1353
rubinm
Member#: 63483
2005 STi HTA68'd+e85
^ ^ HTA68. haha.
rubinm is offline   Reply With Quote
Old 07-06-2010, 04:45 AM   #1354
ForesterWTi
Member#: 173892
grandma gold
Originally Posted by rubinm View Post
^ ^ HTA68. haha.
lol your killing me! You have yours in a 2.5 STi, I'm still making the best of the open deck 03-03 2.0L wrx platform. By now you should know, I don't take the path most chosen; I'd rather make my own . BTW I'm still in the boat if you want a ride in the Pink Vader .
Cheers,
~Wolf
WTi
Old 07-06-2010, 07:52 PM   #1355
xsnapshot
Member#: 170973
2004 WRX 4EAT
nope. I have an MBC, and have tuned out any control the ECU "thinks" it has over the boost. I've also set it to jump to the high det fuel map at ANY drop in IAM.
Wolf, I'm not sure what your reasoning for posting that link was. The small 16G I have, has identical spool, but is going to make WAY more power than the VF29. On the dyno in the link you posted, the VF29 is making TD04L-13T horsepower numbers, but its making peak torque around the same time as a 20G.
xsnapshot is offline   Reply With Quote
Old 07-06-2010, 08:27 PM   #1356
rubinm
Member#: 63483
Cheers,
~Wolf
WTi
the HTA68 is an awesome turbo on the 2.0. i'd say moreso than the 2.5l. its a perfect match.
yeah i'd like a ride on the GF8, i wont be in the boat for a few weeks tho. you gonna be around?
Old 07-06-2010, 09:16 PM   #1357
AllAWD
Member#: 17079
And you know this because?
For all the hype, I'm just not believing they came out with a miracle. HTA68 is not spoolng as fast as a 16g on the 2.0L and most people interested in the 19t want that early torque punch.
I'm really interested in that Blouch 16gXT for the 2.0L. If it spools like the small 16G, it would be golden.
AllAWD is offline   Reply With Quote
Old 07-06-2010, 09:28 PM   #1358
rubinm
Member#: 63483
you're kidding right?
the 16gXT is Blouch's answer to FP's HTA68. they are direct competitors.
FP's success with billet HTA wheels prompted Blouch to respond with their "XT" turbos.
either will rock a 2.0 and give you plenty of punch.
go look at the graphs of 2.0's with HTA68's and you'll see what the "Hype" is about.
Old 07-06-2010, 10:36 PM   #1359
xsnapshot
Member#: 170973
2004 WRX 4EAT
well crap. The station I filled up at today had crap gas. Must've been mostly normal gas. My ECU is at full -25% correction to idle at 14.7. (its targeting 15.2 at idle, so it needs even more taken out...).
Here goes a full tank worth of extremely conservative driving
Old 07-06-2010, 11:20 PM   #1360
PAImportTuner
Member#: 141669
A EJ205 with
E316G
xsnapshot, Wolf is trying to reinvent the god damn wheel man. He is bench market testing and theorizing. I can't belive he still thinks his turbo is good in any way shape or form no low end, no middle, little high end.. BUT at least it works right.
Wolf, I'm all for doing your own thing. But your killing me about the VF turbo it's non rebuildable.. unless you want to pay $800+ for a new CHRA.
Only option this thread has is:
-Grimspeed porting or similar porting TD04(maybe even clipping) http://www.grimmspeed.com/catalog/pr...products_id=42
31lb/min-Blouch 19T upgrade
34-35/min-Any company small 16g
39-41lb/min-Any company Evo3 16g
????-Blouch 16gXT
49lb/min- FP HTA68
Funny it's order from fastest spooling to most power as well as from lowest price to highest.
Old 07-07-2010, 01:34 AM   #1361
rubinm
Member#: 63483
^ ^ forgot the HTA68
Old 07-07-2010, 03:22 AM   #1362
PAImportTuner
Member#: 141669
A EJ205 with
E316G
Old 07-07-2010, 08:33 AM   #1363
AllAWD
Member#: 17079
I think the HTA68 is more in line with the 18g-XT or 20g-XT
The 16g-XT flows less (42 lbs/min vs 47 lbs/min) and uses a 7cm^2 housing vs a 10cm^2 housing. I've seen the plots, I've talked to my local tuner. Spool on the HTA68 is not faster than a 16gEVOIII on a 2.0. Dyno plots are like the bible, you can find something to prove anything you want.
16gEVOIII vs HTA68:
http://www.ctsubie.com/forum/showthread.php?t=11494
hint: on a 2.0 the 16g wins on that plot
Old 07-07-2010, 12:23 PM   #1364
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
People are still talking about the HTA68 on the 2.0? Jesus.
xsnapshot, you got **** luck my friend.
Old 07-07-2010, 01:25 PM   #1365
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
49lb/min- FP HTA68
its 47 lb/min.....
and the flowrate of the wheel means very little here. FP used it to sell the turbo......and notice they took all mention of "16g" out of the name....even though its a 16g with a different wheel in it, although they do say that on their site.
the hta68 makes the power of a 38-40 lb/min turbo just like every other big 16g.
Old 07-07-2010, 03:49 PM   #1366
rubinm
Member#: 63483
^^ thank you Ron. the HTA68 is very much a competitor to every other big 16g.
the fact that it was ever compared to the 18 and 20g's was simply due to FP's advertising of its flow rates.
Old 07-07-2010, 03:59 PM   #1367
Phatron
Member#: 36033
CEO PhatBottiTuning
I dont think it was a coincidence that they didnt name it an HTA 16g. The 47 lb/min number was advertised for a reason....just like the "16g" was left out of the name for a reason. On paper it should kill all 18g's and 20g's on top end power. reality is another story.
Straight from FP's description
"These units are constructed from Genuine MHI 16g turbochargers which are reconfigured to 68HTA specs by Forced Performance. "
http://store.forcedperformance.net/m...Code=WRX-Turbo
Old 07-07-2010, 04:26 PM   #1368
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Old 07-07-2010, 07:03 PM   #1369
AllAWD
Member#: 17079
So it costs more than an EVOIII16g, spools slower on a 2.0 and makes the same power. Therefore, it's the best option
It really is a better option for a 2.5, but not on a 2.0 without different fuel (e85, meth, race fuel).
Originally Posted by OrbitalEllipses View Post
19T wheel $180
TD04HL wheel $237.50
Total in parts: $417.50 + shipping
no profit
I've seen them cheaper on ebay, but not sure I trust that.
Old 07-07-2010, 07:10 PM   #1370
Phatron
Member#: 36033
CEO PhatBottiTuning
i would never ever ever "upgrade" to a hta68 over a vf.
unless you're talking about a td04 equipped 2.5L, but even then just get a used vf turbo for $400 and call it a day.
I have an 02 wrx and an 06 sti and been through many setups on both and i wouldnt put anything less than a 49 lb/min turbo on either of them.
although i finally got the td04 back on my wrx to try and break the 12.4 sec 1/4 record.
I only did 1 pull.....made 220whp at 12psi on the road dyno. hoping to hit 300whp at 20psi.
Old 07-07-2010, 07:12 PM   #1371
SilentDoomWgn
Member#: 246729
03 wrx wgn
blue
^^ from what i read the 7cm^2 hot side will limit your overall on a 2.5l.
how ever i got my 16g-xt today heres some pics
http://www.facebook.com/album.php?ai...8&l=87ed0ac08c
SilentDoomWgn is offline   Reply With Quote
Old 07-07-2010, 07:18 PM   #1372
Phatron
Member#: 36033
CEO PhatBottiTuning
you know 18g's and 20g's can come with 7cm right?
and the fp green?
all the way up to the AMR t60R......
its the 16g compressor housing thats the restriction IMO.
you can shove a gt35 comp wheel in there....doesnt mean its gonna flow 62 lbs/min.
Old 07-07-2010, 07:54 PM   #1373
knuts
Member#: 116814
2003 wrx wagon
blue
Will you be getting an E85 tune for this?
knuts is offline   Reply With Quote
Old 07-07-2010, 08:29 PM   #1374
knuts
Member#: 116814
2003 wrx wagon
blue
Results with the HTA68 on the 2.0l are definitely a mixed bag. When pushed to higher boost levels on E85 it seems to be a decent option. Here are results at 5000' (Longmont, CO) with a 1.32 CF.
[IMG][/IMG]
This was with a FMIC at 22psi peak boost. Even at a more reasonable CF of 1.16 (316 whp), this is a pretty decent result. I have not seen any data for an E316G at this level in Colorado with similar CF on a DD dyno.
Here is another example with an STi TMIC at 20psi peak at 6000' (Colorado Springs) with 1.15 CF
[IMG][/IMG]
...and for comparison here again is my best result with the Deadbolt TD04L-19T at 22 tapering to 18 psi with APS TMIC and 1.15 CF at 6000' (Colorado Springs).
[IMG][/IMG]
The HTA68 is lagging my TD04 by only 500 rpm at 200 lb-ft (4200 rpm vs 3700). So, +15% peak power for 500 rpm later spool. Hmmm... it's good to have different options!
Old 07-07-2010, 11:12 PM   #1375
SilentDoomWgn
Member#: 246729
03 wrx wgn
blue
na E85 is only at i believe 2 stations here in albuquerque. the 3rd one closed a few weeks back. if it ever becomes mainstream i will for sure, was part of the reason for the 820cc.
sadly im strapped for cash now so i gotta wait till august to get it tuned.
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 09:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 09:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 11:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 02:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 08:19 PM
