Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 07-08-2010, 10:57 PM   #1
TRBO_BXR
Member#: 75835
1992 dontask
white
Default 07 forester speedo correction?
i am thinking of lowering/sways and going with some decently sticky tires. problem is going by the tire hieght of my stock 215/60/16's of 26.2in(792 revs per mile) versus the BFG KDW2's best 16in at 24.1in(865rpmile). sadly when i had my wrx, i never thought of this when i kept having to shift early on drag runs using 215/45/17's versus stockers. i loved my last sets traction, so i want them on my forester, any way to correct this easily? can i use tantrix(?) and just mess with the signal?
Thanks ahead
TRBO_BXR is offline   Reply With Quote
Old 07-08-2010, 11:38 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
What size KDWs are you looking at? You said the "best 16in", but I don't know what that's supposed to mean.
According to their site, the 225/55-16 is 808 revs/mi, and is good to fit on a 6-8" wheel, so it'll work on your 6.5" wheels. (Assuming you have stockers, of course). 215/60 is a pretty uncommon size, so unless you go with that exact same size (which limits you to basically no performance tires at all), I think that 225/55 is about the best match you're going to find.
Old 07-09-2010, 12:29 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
There are a few companies that make "recalibration boxes" that read the signal from the VSS then transmit a new signal to the ECU/speedometer.
This is just one such company.
http://www.hypertech.com/products-sp...alibrator.aspx
You could try www.ddinstruments.com and see if they have any recommendations for you.
flstffxe is offline   Reply With Quote
Old 07-09-2010, 05:32 PM   #4
TRBO_BXR
Member#: 75835
1992 dontask
white
hmmm tire rack must not list them all or have the wrong specs then. thanks for finding this for me and replying!
thanks flstffxe, if it comes down to it i may still need it!
FS: ATX Cobb AccessPort 08+WRX/STI, 07+Legacy GT, 07+ Forester XT rjacobs TXIC Private Classifieds 3 11-15-2008 09:22 AM
FS: 04-07 impreza rs or 03-07 forester starter haunt NWIC Private Classifieds 1 09-25-2008 04:42 PM
Speedo corrections needed? 6MT into 02 WRX corey_dyck Transmission (AT/MT) & Driveline 3 03-17-2006 08:58 AM
If you go with JDM 6MT + 4.444 ratio, what about speedo correction? casualsurfer Transmission (AT/MT) & Driveline 4 01-11-2005 02:11 PM
Speedo correction Bassem General Forum Archive 4 12-05-2000 06:09 AM
