Old 07-08-2010, 04:49 PM   #1
subbiedoobie08
Member#: 216595
2000 2.5RS SWAP
white
Default clutch pedal installation problem
Im converting my 2000RS from auto to manuel as part of the 04 wrx swap. I took out the dash, bulk wiring harness, ect. I took this opportunity to install my clutch and brake pedal assembly, and i ran into an issue with it not bolting to the existing holes. The holes will not match up right. I will attach some pictures tonight and let you know exactly what im talking about but i thought it would be a clean install. Has anyone ever ran into this issue? Am i gonna have to make new bolt holes on the upper bracket above steering column? (surely not)
thanks so much for any response guys
subbiedoobie08 is offline   Reply With Quote
Old 07-13-2010, 04:52 PM   #2
subbiedoobie08
Member#: 216595
2000 2.5RS SWAP
white
bump anyone?
Old 07-13-2010, 04:55 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
are you trying to use a 02+ peddle box in a 93-2001 car?
Old 07-14-2010, 04:37 PM   #4
subbiedoobie08
Member#: 216595
2000 2.5RS SWAP
white
yes, i just got the pedal box out of the 04 wrx because the RS had an automatic tranny. I think im just gonna drill some holes because the 4 holes around brake booster are fine and so are the two for the slave cylinder, its just the upper bracket holes that dont meet
Clutch Pedal/TOB Problems hangman Transmission (AT/MT) & Driveline 2 06-30-2009 11:23 AM
Clutch Pedal Question/Problem? Falkonite Newbies & FAQs 5 09-28-2008 12:18 PM
dead pedal install problems aveisone Interior & Exterior Modification 13 03-13-2008 10:31 AM
exedy clutch/flywheel install problem wrxgujuwrx Transmission (AT/MT) & Driveline 4 05-19-2004 11:53 PM
exedy clutch/flywheel install problem wrxgujuwrx Transmission (AT/MT) & Driveline 0 05-18-2004 07:41 PM
