Old 05-14-2006, 07:19 PM   #1
S.G.D
Member#: 36448
Default 02-03 vs 04-05 boost solenoid?
does anyone know if an 02 WRX Boost control solenoid will work with an 04 motor?
the part numbers are different:
16102AA360 for 04-05
16102AA160 for 02-03
S.G.D is offline   Reply With Quote
Old 05-15-2006, 10:15 AM   #2
S.G.D
Member#: 36448
no one
Old 05-15-2006, 10:51 AM   #3
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
As far as I know, they supercede as well inlet/outlet and mount positions are different. But they should still work the same. Only other thing I can think of is the connector is slightly different on new models.
Ver.III is offline   Reply With Quote
Old 05-16-2006, 09:22 PM   #4
agterlik
Member#: 41626
SPB We make people
quit teh internet
I think it would. The year of the motor is not really the deciding factor, the ecu and bulkhead harness are and even then as long as you have a way to hook up the wires you should be good to go.
agterlik is offline   Reply With Quote
Old 05-17-2006, 02:20 PM   #5
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Yes, they will work fine.
jamesfacts is offline   Reply With Quote
Old 05-19-2006, 02:52 PM   #6
trustSTI
Member#: 100673
04 STi
Aspen
I bought the BCS off of an '04 Sti to put on my '02 WRX. Slightly different mounting bracket, so i had to mount it with the connecter facing down. Other than that, no differences.
-Joe
trustSTI is offline   Reply With Quote
Old 05-19-2006, 04:16 PM   #7
S.G.D
Member#: 36448
thanks everyone!
Old 07-14-2010, 06:52 PM   #8
Spec R
Member#: 187752
99 RS/X5/Volt
I came up on this topic on a search. my 02 BCS took a dump, and I ended up buying a used 04 BCS. can anymore people please verify the above info?
thanks in advance, sorry for the thread revival!
Spec R is offline   Reply With Quote
02/03 vs.04/05 vs. 06/07 GTPowered4.6l Newbies & FAQs 3 04-24-2008 08:51 PM
02/03 vs 04/05 struts, wrx AlpoRS Brakes, Steering & Suspension 1 06-03-2006 10:51 PM
Rear Strut/Spring Differences 02-03 vs 04-05 i-max Brakes, Steering & Suspension 3 03-23-2006 05:05 PM
02-03 Vs 04-05 ousd2ndbncdr Newbies & FAQs 34 06-10-2005 03:33 PM
02/03 vs. 04/05 WRX ECU and wiring connectors different? (pics) xcntrk75 Subaru Conversions 4 03-18-2005 08:01 PM
