Welcome to the North American Subaru Impreza Owners Club Friday August 22, 2014
Old 07-06-2010, 04:48 PM   #1
Sinister7
Member#: 139685
2006 WRX Sedan
SGM
Default 04 6mt into 06 wrx
I'm going to start pulling parts off of a 2004 STi.
I get the full drivetrain, and brake components.
I understand that I'll need to pull a fair amount of stuff for this.
Here's my list so far. TELL ME if I need to add more to it!
Clutch Master Cyl, Clutch line, clutch, flywheel, thrust bearing, transmission + linkage, transmission subframe, shaft, r180, axles and hubs (f/r), brembo calipers, oem rotors, aftermarket dccd (probably DCCDPro w/ STi cluster adapter), STi cluster.
I can reuse my goodrich ss lines, correct?
What else do I need? Please give me specifics!!
Sinister7 is offline   Reply With Quote
Old 07-08-2010, 01:39 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Put this on the shelf in case you need spares in the future. Yes you can reuse your brake lines. There is no thrust bearing, but there is a throwout bearing.
Now is just installing. Be creative and find ways to make installation easier. That tranny is heavy.
Old 07-10-2010, 07:38 PM   #3
Sinister7
Member#: 139685
2006 WRX Sedan
SGM
My understanding is that I have to use the clutch master cylinder because the 06 WRX is a push style vs the 04 STi's Pull Style clutch.
Old 07-10-2010, 08:40 PM   #4
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
let me know how this goes...I might be doing something similar
Obababoy is offline   Reply With Quote
Old 07-11-2010, 12:53 PM   #5
Sinister7
Member#: 139685
2006 WRX Sedan
SGM
I'm a little disappointed to see how few people are chiming in on this.
Old 07-12-2010, 08:26 AM   #6
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
I know this is the right section but I would post another one in transmission section of technical...can I ask how much you paid for the sti?
Old 07-12-2010, 12:00 PM   #7
Sinister7
Member#: 139685
2006 WRX Sedan
SGM
posted into the other section...
I'm paying 3750 for the full swap including brembos
Old 07-16-2010, 12:19 AM   #8
dustyrocket
Member#: 226042
2006 WRX
Gray
I am like 80% throguh with this same swap!
Yea, That's a good list. Don't forget you might need new front axels if the new transmission has stubs. You can probably take your 06 axels to a dealer and swap them for free(that's what I did). It was no fun finding out my axels wouldn't work, half way through the swap.
You also might ahve an issue with the shifter linkage. I can't get mine to sit at the right angle. Not sure what the problem is, I'm still trying to figure it out. It sits like its where 6th should be when in neutral, so it makes getting it into reverse kind of difficult sometimes. Good luck!
If you have anyquestions, I'm happy to help!
dustyrocket is offline   Reply With Quote
04 STi into 06 WRX Sinister7 Transmission (AT/MT) & Driveline 6 03-24-2010 07:38 PM
6mt into 06 WRX tdoc2651 Transmission (AT/MT) & Driveline 3 04-25-2009 02:43 AM
04 JDM sti 6MT swap into 06 wrx lagodcm Transmission (AT/MT) & Driveline 20 04-06-2009 11:46 AM
04 6mt into 00 RS GC8 Chassis DatDude Transmission (AT/MT) & Driveline 6 02-13-2008 09:46 AM
04 TS tails into 06 WRX? bdon22 Interior & Exterior Modification 2 04-02-2007 08:48 AM
