Old 07-10-2010, 11:17 PM   #1
FasterPanda
Member#: 251648
2004 WRX
Red
Default 04 WRX to 07' trans swap
I was wondering if anyone can help me out here, I heard that this is possible and would like to do it to ensure that my car will be able to handle the new 2.5 shortblock I'm swapping into it.
FasterPanda is offline   Reply With Quote
Old 07-10-2010, 11:34 PM   #2
dscoobydoo
Member#: 57152
---- Subaru fleet
garage ( 5 and counting)
Other than the 04 WRX and the 07 have different ratios, and you have to address that issue, they do bolt up.
dscoobydoo is offline   Reply With Quote
Old 07-16-2010, 12:35 AM   #3
dustyrocket
Member#: 226042
2006 WRX
Gray
keep in mind that the 07 trans has a 3.7 final drive ratio when you pick out the rear diff you are going to use. You will also need new axels if your 04 transmission has axel stubs. the clutch on your 04 is a pull type, and the 07 is a push type, so you will need a new clutch, new slave cylinder, and probably a new flywheel. If I think of anything else, I'll post it for you
dustyrocket is offline   Reply With Quote
AT to MT trans Swap Electrical Mods required Odyknuck Transmission (AT/MT) & Driveline 0 04-06-2009 03:14 PM
AT to MT trans swap questions and pricing greddy18 Transmission (AT/MT) & Driveline 6 02-13-2008 01:08 AM
complete 04 wrx to 07 sti swap ssweet08 Subaru Conversions 21 01-13-2008 05:16 PM
Testing the waters: NY - 04 STI 6-speed trans swap rayc Drivetrain 22 11-12-2006 12:13 AM
98 Auto to Manual Trans Swap RS25Tuner Subaru Conversions 5 09-23-2004 09:27 PM
