Old 07-15-2010, 12:29 AM   #1
cokal
Member#: 225185
Default Installing a Tranny & Engine question
Evening!
Getting ready to upgrade (remove and replace) my stock tranny to handle my 'work in progress' EJ25 DOHC motor w/ turbo. The car is a 2004 Impreza Outback Sport wagon. The crossmember has been modified for the turbos exhaust
Has anyone tried bolting the tran to the engine 1st and then installing it into the car? If so, could you please share some of the highs and lows?
Thanks!!
Ken
cokal is offline   Reply With Quote
Old 07-15-2010, 10:49 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I try NOT to install them like so because of the extreme weight. Mounting points can break threads off the engine or tranny if you don't use good points. I normally just install engine or tranny separately.
Old 07-15-2010, 12:35 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
The assembly is long when bolted together. The engine bay is wide but not so long......the angle required makes installation a pain. Doable....but not fun or easy.
Jay
Old 07-15-2010, 09:07 PM   #4
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
I've done both. It took 3 of use to install the engine/tranny combo for the reasons listed above. We used a 2 ton engine crane and it was tight, but doable.
I would recommend installing them separately.
beaviscih is offline   Reply With Quote
Old 07-16-2010, 07:55 AM   #5
Rokkit
Member#: 84181
NASA #530 GTS2
If you have the equipment and help I'd recommend installing them as a unit. It's how it's done at the factory - only down side is it needs to be installed from the bottom of the car... not through the top of the engine bay
Rokkit is offline   Reply With Quote
Old 07-16-2010, 09:51 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I'd only recommend doing it if you've got access to a lift. I've done it this way by lifting the car way up and lowering it down onto the engine/gearbox assembly that's on a stack of pallets. The engine assembly was attached to the crossmember in advance, along with the tranny mount. Then once you lower the car onto it, you climb under and just bolt up the crossmember (with steering rack already attached).
Old 07-16-2010, 11:08 AM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
never had any issue with installing a 3.3 and trans at the same time.
the entry angle is crazy, though. Watch your rad support
Old 07-16-2010, 02:18 PM   #8
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
The easiest route is, pull your old motor out first then drop the tranny, and reinstall in reverse order (tranny and then motor). It's easier to line the motor up with the tranny/clutch using an engine lift, then lining up the tranny with the motor/clutch from under the car. It's more difficult trying to install them connected.
Tranny & Engine Mount Combo $149 Shipped, Cusco LSDs, Clutch Specials Gruppe-S Drivetrain 4 11-27-2006 07:33 PM
Mating tranny to engine question Starkiller Transmission (AT/MT) & Driveline 20 04-13-2006 05:07 PM
New Group N Tranny & Engine Mounts AWDPilot Private 'For Sale' Classifieds 6 10-14-2004 03:04 AM
Any harm done by installing STI tranny & engine mounts? Sandkicker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-01-2004 05:35 PM
Scoobysport question & engine question SubaruImpreza_power Newbies & FAQs 0 05-19-2003 08:18 AM
