Old 07-16-2010, 07:28 PM   #1
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
Default AC compressor not staying on long even on max AC?
My 07wrx is acting up a bit with the AC...the compressor does not stay on very long at all...maybe 8 seconds then it goes off for a while then back on...When the compressor does kick in, the air blows cool like it should. Also when I turn on the AC or when compressor kicks in it makes a quick squeak sound...
I changed out my crank pulley 3 years ago and put it back exactly how I had it. Worked fine for 2 years so I don't think its related...
Tips?
Obababoy is offline   Reply With Quote
Old 07-16-2010, 07:35 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Is it blowing cold air? ever checked low pressure line for pressure reading?
txl146 is offline   Reply With Quote
Old 07-16-2010, 07:46 PM   #3
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
When compressor kicks in its cold, when its not its a bit cooler than ambient...Shouldnt the ac compressor be on for more then 8 seconds at a time when I have it on full blast?
Old 07-16-2010, 10:45 PM   #4
BigWater
Member#: 41942
2004 WRX Wagon
Have it check for refrigerant level. Probably too low.
BigWater is offline   Reply With Quote
Old 07-18-2010, 10:22 PM   #5
ep3smoker
Member#: 248857
2004 Wrx wagon
should run at idle for alot longer than 8 seconds. You need to check pressures.
ep3smoker is offline   Reply With Quote
Best place to take my WRX on Long Island? EPrex Tri-State Area Forum 29 07-20-2010 08:47 PM
A/C Compressor kicks on and off, on and off - AC Clutch?? IT's HOT here! ogboot Service & Maintenance 9 06-20-2009 11:18 AM
FS: AC System AC Compressor/Belt/4 AC lines/Bracket the real suby dude Engine/Power/Exhaust 3 03-26-2009 04:51 PM
AC compressor and condensor fan won't come on RSXiMUS Service & Maintenance 2 05-27-2008 12:44 PM
AC Compressor Not Coming On ?? antidote11 General Community 29 11-09-2004 05:11 PM
