Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 07-20-2010, 02:55 AM   #1
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
Default Diy!! Spacers!!!!
This is my entry for the contest, however that doesnt mean it's not usuable for any other reasons.
This is only for the front drivers as the rear door panels do not have enough space.
This was done on an 04, so it should work for 02-07.
If any pictures don't work, or anything is unclear, feel free to PM me. I have no life so I'm free often. :P
I'm really really pressed for time right now, so I'll come back and fix this later if i skimp out.
The final product:
Tweeter mounts:
I know they aren't pretty, but who cares right? noone seems em, so it doesnt really matter.
now, you may feel overwhelmed, lost or confused. I am here to guide you.
materials:
3/4" wood of your choice. I used plywood because it's all I had at hand. MDF would be ideal, but since I don't have my stock speakers on hand (they're back at my dad's, on vacation. frankly, I don't care. )
Screws. Something 1-1/4" is the perfect length to go thru the plywood and into the metal. If something smaller than the stock size, use tinnerman clips. You do not need to worry about putting them the proper way, the clips will hold. Washers can help for sure.
Short screws. To hold your driver to the wood.
measuring tape. for measuring. duh. :P
compass. for drawing circles.
drill. bits in 2 sizes at minimum, for predrilling for the screws, and for jigsaw
jigsaw with wood blades.
primer.
hokay, now to the instructions.
Step 1
Pull off door panels. really simple. 2 screws and a couple clips. not giving instructions for that.
Step 2
take off driver. 3 screws.
Step 3
trace driver onto wood. get the screw holes. Do this 2 times as both front drivers are the same.
Step 4
using the measuring tape, measure out the space needed for the driver to clear. Divide that distance by 2, and measure that out on the compass. draw your circle. drill out a part inside this circle, then cut out the circle with the jigsaw.
Step 5
cut out the outside of the spacer.
Step 6
fit driver to spacer. if it fits well, take spacer off and spray with primer, to avoid rot. screw these together.
Step 7
screw spacer and driver to door after connecting driver to wiring.
put door panel back on.
Step 8
profit!
new ion? is offline   Reply With Quote
Old 07-20-2010, 03:04 AM   #2
silvercookie
Member#: 180033
2005 WRX
cool. now make me some.
silvercookie is offline   Reply With Quote
Old 07-20-2010, 03:05 AM   #3
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
..... I would, but.... what am I gonna get outta it? :P
Old 07-20-2010, 03:07 AM   #4
silvercookie
Member#: 180033
2005 WRX
a hi five and a slap on the ass.
Old 07-20-2010, 03:08 AM   #5
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
... sorry but it's not worth it. :P you still running stock fronts?
Old 07-20-2010, 03:09 AM   #6
silvercookie
Member#: 180033
2005 WRX
Old 07-20-2010, 03:10 AM   #7
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
well I knew you were always changing up the sub, but I wasn't sure.
Old 07-20-2010, 03:13 AM   #8
silvercookie
Member#: 180033
2005 WRX
haha, the magnets on my mids wouldnt even fit through the hole in the door were the stock speakers go. even with spacers. only spacers that would work cause it to hit against the door card.
Old 07-20-2010, 03:18 AM   #9
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
lmao... nice. what you running?
I don't have the money, with school coming up to seriously outfit my car. I got lots of stuff for xmas tho, so i used that.
lots of kenwood.
KFC P707 up front,
powered by a KAC 5204,
KFC X132 in the rears powered by an oldschool orion 240gx given to me... and I'm still working on the sub box... which i forgot to take pics of. its about a day or so from being usable, and then i gotta wait till a friend gets back to finish it.
Old 07-20-2010, 03:23 AM   #10
silvercookie
Member#: 180033
2005 WRX
soundstream trc.6n
Old 07-20-2010, 04:13 AM   #11
Davenow
Member#: 23676
you REAAAAAAAAAAALLLLLLLLLLLLYYYYY need to resize those pics. That alone makes what could be a great thread, a poor one.
Fix that, and you are in business
The forum software shrinks the pics to fit, but the full res pic is there and has to load fully before it can resize it.
Davenow is offline   Reply With Quote
Old 07-20-2010, 12:56 PM   #12
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
yea... how do i do that?
Old 07-20-2010, 01:00 PM   #13
silvercookie
Member#: 180033
2005 WRX
if you use photo bucket, go to the pictuer and you will see a little edit button.
click it, it will bring up the editor, click resize.
resize to 1200x1100 or whatever it is.
save as copy or replace original, either one. and repost the pics.
Old 07-20-2010, 01:02 PM   #14
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
i got sick of photobucket... rehosting resized using imageshack.
Old 07-20-2010, 01:21 PM   #15
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Great write up. Somewhere in this forum, or iwsti there is a hosted drawing for people to use as a template. This may be an excellent cross post since it gives something to trace for those that have a TR minus radio or 2004 STi
Stephen
IA Performance is offline   Reply With Quote
Old 07-20-2010, 01:22 PM   #16
BryanH
Member#: 993
If you are going to run any kind of wood product you really should throw a couple coats of paint or something on there to help them not rot out as there is ALOT of water in the door.
BryanH is offline   Reply With Quote
Old 07-20-2010, 01:35 PM   #17
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
thanks for the posts guys - it's something i'll add... if i can find the template.
Old 07-20-2010, 04:06 PM   #18
Davenow
Member#: 23676
Stephen
You still making spacers? Just curious. I got a set a few years back. Traced them and made spacers to 2 more of my own cars
Old 07-20-2010, 04:19 PM   #19
hanson
Member#: 250070
2007 Impreza WRX
Concillian's measurements are also spot on here:
http://forums.nasioc.com/forums/show...threadid=23933
I used the measuresments to make my spacers and they were perfect!!
hanson is offline   Reply With Quote
Old 07-20-2010, 04:55 PM   #20
wrx_gos_fast
Member#: 218280
2002 WRX Wagon
you may be a redneck if...
wrx_gos_fast is offline   Reply With Quote
Old 07-21-2010, 01:55 AM   #21
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
3/4" fits, so i'll stick with it. thanks tho
if what? you use what's at hand? it's not like i'm holding it together with duct tape!
Old 07-21-2010, 01:57 AM   #22
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
are the 05 door panels really that much different than the 04's down by the speaker?
Old 07-21-2010, 10:48 AM   #23
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
I'd recommend "painting" the wood brackets (mdf or otherwise) with a coat of fiberglass resin, give a light sanding and then spray-painting flat black.
Should weatherseal for the most part and also aleviates the eyesore of a chunk of bare wood screwed to a metal door panel... SO tacky...
couchflambeau is offline   Reply With Quote
Old 07-21-2010, 12:15 PM   #24
new ion?
Member#: 242652
04 2.5 TS sedan
JBP
.... what eyesore? it's not like you see the spacers...
Old 07-21-2010, 07:46 PM   #25
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
I'D know it was there....
LoL... if I have to explain it you wouldn't understand.
DIY Cheap Modified Catch Can yo14jman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 08-02-2010 07:46 PM
FS : FS: Ichiba 25mm Wheel Spacers Tombo Wheels/Tires 3 07-22-2010 07:21 PM
DIY Sunroof Delete Splinter Interior & Exterior Modification 10 07-20-2010 01:58 AM
Home made DIY 6.5" speaker spacers bogey1 Car Audio, Video & Security 6 10-04-2009 03:08 AM
Any DIY on how to make your own speaker spacers?? Alan l. Car Audio, Video & Security 7 05-12-2006 12:17 PM
