Old 08-19-2010, 12:49 PM   #1
saab90089
Member#: 31998
89 900Turbo w/295K
97 Impreza L wagon
Default P0302 CEL - advise/help/expereices
I have had a CEL (P0302-misfire cyc. 2) for a month or 2 now. I can not seem to figure out what is causing the CEL. I would like some advise from anyone as to what may be causing it or how to get rid of it.
Car Information:
1997 Impreza L
2.2ltr N/A
5speed
250K miles
What I have tried so far:
-Replace plugs
-replace wires
-replace coil-pack (when this did not solve the problem I returned the new part)
-replaced ignition module (located on firewall behind airbox - also swapped back when this did not solve problem)
-Replaced cyc. 2 fuel injector
As I stated before none of the above solutions have solved the problem. I feel that I have elminated most of the obvious stuff. I have a few ideas that I will list below, tell me what you think...
Ideas I think may solve the problem:
-replace plugs again: perhaps the problem is solved but plug is fouled?
-replace coolant temperature sensor: I've read here/there this might be the problem?
-Valve Adjustment: to my knowledge the valves have never been adjusted and I wonder if at 250K they could be off enough to cause this? I have also read this was the solution for someone else.
If anyone has any other ideas or suggestions or theories please post.
Thanks,
Ian
saab90089 is offline   Reply With Quote
Old 08-19-2010, 03:29 PM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Replace wires?
PhilSine is offline   Reply With Quote
Old 08-19-2010, 05:50 PM   #3
saab90089
Member#: 31998
89 900Turbo w/295K
97 Impreza L wagon
Originally Posted by PhilSine View Post
Replace wires?
Yes, I have replaced the wires. Forgot to note that in my post - editing that now.
Ian
Old 08-19-2010, 11:03 PM   #4
bhilly82
Member#: 254417
09 Impreza
Peperika
you sure your working on cly 2?
bhilly82 is offline   Reply With Quote
Old 08-20-2010, 09:53 AM   #5
saab90089
Member#: 31998
89 900Turbo w/295K
97 Impreza L wagon
I referenced the coil pack, which had a '2' next to one of the wires. That followed that wire to the plug and figured that was cyclinder #2. This put me to the driver side of the engine, front of the car.
Ian
Old 08-20-2010, 10:40 AM   #6
2.slow
Member#: 196017
2002 wrx wagon
from Identifix:
Vehicle Application: 1996 Subaru Legacy L 2.2L, Vin 3 1996 Subaru Legacy L 2.2L, Vin 4
Customer Concern: Trouble code P0302, number 2 cylinder misfire.
Tests/Procedures: 1. Lower the exhaust system and inspect the exhaust valve and valve guide. Check for carbon buildup on the valve stems and/or valve guides with an exposed length different from the others.
Potential Causes: Valve Guides
Tech Tips: Have seen quite a few of these engines with loose valve guides that cause these exact symptoms.
Diagnostic Codes: P0302
2.slow is offline   Reply With Quote
Old 08-22-2010, 10:57 AM   #7
saab90089
Member#: 31998
89 900Turbo w/295K
97 Impreza L wagon
So I adjusted the valves yesterday but the CEL is still on . The valves did not seem like they needed much adjustment.
I guess i am down to a few 'easy' things left to try: coolant sensor, check/clean electrical connections. If one of those items don't solve the problem then I think it will be something more major with the engine (head gasket, valve seals).
Ian
Old 08-23-2010, 07:07 AM   #8
saab90089
Member#: 31998
89 900Turbo w/295K
97 Impreza L wagon
Tried checking/cleaning electrical connections - nothing really dirty or wring there. Replaced coolant sensor too.
CEL still came back on.
At this point I think it's something wrong with the engine. Perhaps carbon build up, valve guides, or head gasket.
Ian
Old 08-24-2010, 08:30 PM   #9
AaronDoyka
Member#: 255843
1999 Impreza OBS
White/Gray
Default similar problem in cyl 4
I've been having that problem with my cylinder 4. In addition, I have been burning a lot of oil just at startup and when the engine is being driven by the car with the throttle closed.
I have had a lot of buildup on the spark plug, and had a compression and cylinder leakage test done today. I only have 85 PSI of compression on 4, and the leakage is 100% through the exhaust.
I just joined NASIOC today, and am not permitted to start a thread asking for information about getting changing or rebuilding the head, this is the closest thread I've found so far.
Aaron
AaronDoyka is offline   Reply With Quote
Old 08-25-2010, 10:25 PM   #10
chris124816
Member#: 47413
1999 impreza obs
black
i had the same code and went through all the same stuff you have. It turned out to be the Mass air flow sensor.
I thought it seemed weird because the code had nothing to do with the MAF, but i changed it out and it fixed it immediately.
chris124816 is offline   Reply With Quote
Old 08-27-2010, 11:53 AM   #11
saab90089
Member#: 31998
89 900Turbo w/295K
97 Impreza L wagon
I will see if the Mass. Air Sensor from my dads 94 Legacy (2.2NA) matching the one my car. If so we'll try swapping that out and see what happens.
Ian
Old 08-27-2010, 11:54 AM   #12
chris124816
Member#: 47413
1999 impreza obs
black
double check the electric connectors have the same setup. even if the plug is the same size, the connections might be different.
P0302 cel what is it? Billy Mays Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 12-15-2009 06:43 PM
P0302 CEL Stumbling Acceleration kakarotoni Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-29-2008 02:03 AM
P0103 w/ P0302 and P0304 - HELP! roback7 Engine Management & Tuning 4 09-17-2008 08:08 AM
Clutch Advise/Help aenima4six2 Newbies & FAQs 13 12-02-2006 07:22 PM
P0301, P0302, PO130...Please help/look AndyM Normally Aspirated Powertrain 11 12-05-2003 01:36 PM
