Old 08-19-2010, 01:59 PM   #1
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Default Limited EFR 7670
EFR 7670 Installed
Recent Dyno EFR7670 IWG 8/4/2012
////old stuff below ////
New tune, updated graphs 9/13/2010
Shop: Mike Jones
Ambient Temp: 71.4 F (78.6 F)
Elevation: 200 feet
Weather: Partly Cloudy (Sunny)
Car: 2007 STI LMT
Dyno Info: Dynocom
Transmission: Stock 6-speed
Gear: 4th gear
Peak at RPM: 508 WHP
Peak Torque at RPM: 439 WHP
Baseline hp/tq for a stock on same dyno:
Turbo: Regular 35R with ATP T4 1.06 Housing
Target Boost: 25 PSI
Fuel: 92 pump with 50/50 meth
Engine/Power Modifications: MPS Fully build 2.5 engine JE custom pistons, MPS Long Rods, Stock crank, 11mm oil pump. Heads are +1mm BC valves and springs, Kelford 272 cams 11.5 lift, ports are not touched.
Fuel: Single Walbro 255 with ID1000 injectors and P&L Fuel rails with FPR @ 45 PSI
ECU: AEM with DSS3 V9
Driveline Modifications: ACT street clutch
Engine oil: Castrol 5w50
Old 08-19-2010, 02:00 PM   #2
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
PUMP
PUMP / METH
Old 08-19-2010, 02:31 PM   #3
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
nice graph and nice double thread
Joking
Old 08-19-2010, 02:44 PM   #4
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Just another routine 500hp MP tune.
Old 08-19-2010, 02:46 PM   #5
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
Is this the standard 35R or HTA trim?
cellgeek101 is offline   Reply With Quote
Old 08-19-2010, 05:19 PM   #6
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
dom will post the graph! This is standard 35R
Old 08-19-2010, 06:42 PM   #7
k mier
Member#: 98000
05 sti e85@420hp
...um, yea, where's the graph?
Who did the twinscroll kit?
k mier is offline   Reply With Quote
Old 08-19-2010, 06:46 PM   #8
juanmedina
Member#: 133146
07 FPgreen 7.37@95
I think, covert performance
Old 08-19-2010, 07:16 PM   #9
frogmonk
Member#: 74489
'04 FXT/05 Baja Tur
'71-FF1/05 Saab-92X-Aero
Are you still using stock fuel lines?
frogmonk is offline   Reply With Quote
Old 08-19-2010, 07:38 PM   #10
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Old 08-19-2010, 07:52 PM   #11
Loubaru
Member#: 155489
07 STi
I'm assuming this is their de-stroked 2.35l? Great power for pump gas!
Loubaru is offline   Reply With Quote
Old 08-19-2010, 07:55 PM   #12
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
2.5 block
Old 08-19-2010, 08:28 PM   #13
cellgeek101
Member#: 143941
04 STI JBP
2.5 block and you're still spinning to almost 9k....Good for you! Im assuimg all supporting mods for the heads are done.
Old 08-19-2010, 08:35 PM   #14
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
^^Is everyone really so ADD they don't even read the specs before they post?
Engine/Power Modifications: MPS Fully build 2.5 engine with +1 valves and Kelford 272 cams
MP's facilities where they assemble the motors look like surgical rooms, what more do you need to know. I thought it was one of the 2.35 motors also!
Krang is online now   Reply With Quote
Old 08-19-2010, 08:37 PM   #15
cellgeek101
Member#: 143941
04 STI JBP
Not ADD thank you....just don't see many tuners revving out to past 8.5k thank you even with supporting mods.
Old 08-19-2010, 09:18 PM   #16
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Yes he made it, and did horrible job with no support for his product at all, I had to spend money to fix his kit.
Stay away from Covert performance!
Old 08-20-2010, 10:32 AM   #17
syoung0298
Member#: 84772
2005 GDB STI
great numbers.. how much timing at peak torque and redline?
syoung0298 is offline   Reply With Quote
Old 08-20-2010, 12:31 PM   #18
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
In the end Bariga it worked out for you, more time and money than expected but how does it spool dont see a graph
never mind just saw the graph, was hoping that it would hit harder a little sooner
ASU is offline   Reply With Quote
Old 08-20-2010, 02:10 PM   #19
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
race gas would fix all of that
Old 08-20-2010, 02:24 PM   #20
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Wow can we get any specs on block? Are heads PnPd? whats the lift on the kelfords? What kind of oiling mods have been done? What weight oil are you using? Did MPS make the rotated and fmic kit?
This thing must be nasty! Looks clean in there.
Props to you and Dom!!!
rexworx is offline   Reply With Quote
Old 08-20-2010, 03:23 PM   #21
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
That thing makes great power but seems to take a while to get there.
godforbid67 is offline   Reply With Quote
Old 08-20-2010, 04:03 PM   #22
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
^^^I was thinking the same thing especially since it is twin scroll.I know its not Doms fault I respect his tuning abilities completely.
john 1badSTI is offline   Reply With Quote
Old 08-20-2010, 05:25 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
why does everyone think that twinscroll is some kind of miraculous spool up machine. It helps but doesn't do miracles. Keep in mind he's on relatively big cams if they are the 272's I'm thinking of.
Keep in mind that twinscroll makes things more efficient but doesn't mean that the runner lengths and diameters are aimed for decreasing spool up
Old 08-20-2010, 05:27 PM   #24
EMS
Member#: 14116
VERY nice power at high RPM, the combination of Kelford 272 and big turbine housing seems to work very well!
EMS is offline   Reply With Quote
Old 08-20-2010, 05:30 PM   #25
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
I am running bigger custom kelford avcs cams than 272's with a single scroll hta86/.82 and see over 20 psi by 4100 so I am not going to point the finger at the cams being the reason for laggy spool-up.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 607 10-11-2015 09:50 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 04:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 03:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 11:28 AM
