#1 |
Member#: 222590
South East
Vehicle:2009 Impreza 2.5i Spark Silver Metallic |
I plan on changing my exhaust on my car. I plan on putting a high flow cat with and agency power exhaust. Would this throw any check engine lights? Also, what if I was to go cat-less would this throw a check engine light?
Also if the catalytic converter that I get is a 2.25" inlet/outlet and my exhaust is 2.5" piping would I still be able to weld the catalytic converter on? Or does it have to be a 2.5" outlet cat?
#2 |
Member#: 187936
MAIC
Vehicle:97 Legacy w12:1CR 05 LL Bean outback |
there is some dyno testing on rs25 i believe that shows no noticeable difference between high flow cat and catless in terms of hp & torque
you want to get a ceramic high flow cat to avoid a CEL, and a good exhaust shop shouldn't have any issues stepping up the pipe size |
#3 |
Member#: 156086
If you're running on the street, go with the high flow cat. Running catless can get you in trouble with the authorities in some areas. You know, tampering with and/or removing emissions equipment. It's not worth the hassle if you get caught.
#4 |
Member#: 102984
MWSOC
Vehicle:2005 2.5RS 4EAT Platinum Silver |
Not worth the hassle to change the cat in the first place. Are you even using different cams?
#5 |
Member#: 185503
MAIC
Vehicle:2004 Impreza WRX PSM |
#6 |
Member#: 102984
MWSOC
What I meant by that was.
The max CFM allowed by the stock cat is more than enough for an engine with stock cams and internals. The major restriction is in the cylinder head, not anywhere. An intake can free up "some" power, but it's definitely not even close enough to having enough flow to justify getting a high flow cat. |
#7 |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
double what Formula91 said, especially with stock exhaust manifold. I would only ever change to a HFC if fitment required it or engine work required it. A catback will possibly be louder with a HFC, likely more raspy and buzzy. track pipe will intensify these effects and guarantee a CEL.
#8 |
Member#: 60082
MWSOC
Vehicle:2004 Forester STI Silver |
Yeah, there's a range of test data out there for both the EJ25 engine and about exhaust in general including specifically cat flow and resulting HP differences.
Without digging around for a while, the gist is the stock cat fits the stock engine well enough. A high flow cat is only a minimal improvement and still requires a full exhaust upgrade and good header if you cared at all about power. The difference between a high flow cat and no cat is negligible. It's not even that much of a difference with a lower flowing cat. Realize that the limitation is mainly on the top end, and our engines are already rolling off in power at that point. You don't really worry about flow until the engine is first capable of pumping that much in the first place, the whole engine: intake, throttle body, intake manifold, heads, cams, header, exhaust pipe, and muffler along with the cat you're so worried about. |
#9 |
Member#: 243393
NESIC
Vehicle:o6 impreza rs silver |
I agree, unless your installing headers, a hi-flow cat is a waste of money, and yes, you will get a cel on the hi-way... I do every time...lol..
| Thread Tools | |
| Display Modes | |
| High flow cat VS No cats...none... | lavid2002 | Newbies & FAQs | 32 | 11-09-2009 10:05 PM |
| High flow down pipe catted on 06? | Skin Irritant | Newbies & FAQs | 11 | 09-11-2008 02:21 PM |
| High Flow vs. OEM fuel pump? | Spitulski | Normally Aspirated Powertrain | 4 | 10-12-2007 11:31 AM |
| Cobb high flow vs. cattless | nineleft | Newbies & FAQs | 33 | 11-10-2006 12:48 PM |
| Hi flow cat vs No cat? | WillysPU | Factory 2.0L Turbo Powertrain | 39 | 11-21-2005 08:56 PM |
